php and uart serial output
Posted: Sat Jul 21, 2012 8:47 am
Can anyone shed some light on why this wont work on the raspbery pi? i suspect that is has something to do with the way the serial class in php is handling the serial port.
here is a snippet of code
The following code works on a regular mac computer, i changed
$serial->deviceSet("/dev/cu.usbserial-A4009R8Z"); to the above line for the rpi
If i use this code(python 2) or minicom i can send and receive from the serial port
here is a copy of the serial class in case someone can see a problem there?
require("php_serial_class.php"); // /dev/ttyAMA0 ttyS0
$serial = new phpSerial();
$serial->deviceSet("/dev/ttyAMA0"); //SET THIS TO WHATEVER YOUR SERIAL DEVICE HAPPENS TO BE, YOU CAN FIND THIS UNDER THE ARDUINO SOFTWARE'S MENU
$serial->confBaudRate(19200); //Baud rate: 19200 or 115200
$serial->deviceOpen();
import serial
##test=serial.Serial("/dev/ttyAMA0",19200)
test=serial.Serial("/dev/ttyAMA0",115200)
test.open()
test.write("Hello World")
test.close
<?php
define ("SERIAL_DEVICE_NOTSET", 0);
define ("SERIAL_DEVICE_SET", 1);
define ("SERIAL_DEVICE_OPENED", 2);
* Serial port control class
* THIS PROGRAM COMES WITH ABSOLUTELY NO WARANTIES !
* USE IT AT YOUR OWN RISKS !
* Changes added by Rizwan Kassim <rizwank@uwink.com> for OSX functionality
* default serial device for osx devices is /dev/tty.serial for machines with a built in serial device
* @author RÈmy Sanchez <thenux@gmail.com>
* @thanks AurÈlien Derouineau for finding how to open serial ports with windows
* @thanks Alec Avedisyan for help and testing with reading
* @copyright under GPL 2 licence
* do not change this code unless you know what you are getting into. Leaving it as you have received it should work fine!
class phpSerial
var $_device = null;
var $_windevice = null;
var $_dHandle = null;
var $_dState = SERIAL_DEVICE_NOTSET;
var $_buffer = "";
var $_os = "";
* This var says if buffer should be flushed by sendMessage (true) or manualy (false)
* @var bool
var $autoflush = true;
* Constructor. Perform some checks about the OS and setserial
* @return phpSerial
function phpSerial ()
setlocale(LC_ALL, "en_US");
$sysname = php_uname();
if (substr($sysname, 0, 5) === "Linux")
$this->_os = "linux";
if($this->_exec("stty --version") === 0)
register_shutdown_function(array($this, "deviceClose"));
else
trigger_error("No stty availible, unable to run.", E_USER_ERROR);
elseif (substr($sysname, 0, 6) === "Darwin")
$this->_os = "osx";
// We know stty is available in Darwin.
// stty returns 1 when run from php, because "stty: stdin isn't a
// terminal"
// skip this check
// if($this->_exec("stty") === 0)
// else
// trigger_error("No stty availible, unable to run.", E_USER_ERROR);
elseif(substr($sysname, 0, 7) === "Windows")
$this->_os = "windows";
else
trigger_error("Host OS is neither osx, linux nor windows, unable tu run.", E_USER_ERROR);
exit();
// OPEN/CLOSE DEVICE SECTION -- {START}
* Device set function : used to set the device name/address.
* -> linux : use the device address, like /dev/ttyS0
* -> osx : use the device address, like /dev/tty.serial
* -> windows : use the COMxx device name, like COM1 (can also be used
* with linux)
* @param string $device the name of the device to be used
* @return bool
function deviceSet ($device)
if ($this->_dState !== SERIAL_DEVICE_OPENED)
if ($this->_os === "linux")
if (preg_match("@^COM(\d+):?$@i", $device, $matches))
$device = "/dev/ttyS" . ($matches[1] - 1);
if ($this->_exec("stty -F " . $device) === 0)
$this->_device = $device;
$this->_dState = SERIAL_DEVICE_SET;
return true;
elseif ($this->_os === "osx")
if ($this->_exec("stty -f " . $device) === 0)
return true;
elseif ($this->_os === "windows")
if (preg_match("@^COM(\d+):?$@i", $device, $matches) and $this->_exec(exec("mode " . $device)) === 0)
$this->_windevice = "COM" . $matches[1];
$this->_device = "\\.\com" . $matches[1];
return true;
trigger_error("Specified serial port is not valid", E_USER_WARNING);
return false;
else
trigger_error("You must close your device before to set an other one", E_USER_WARNING);
return false;
* Opens the device for reading and/or writing.
* @param string $mode Opening mode : same parameter as fopen()
* @return bool
function deviceOpen ($mode = "r+b")
if ($this->_dState === SERIAL_DEVICE_OPENED)
trigger_error("The device is already opened", E_USER_NOTICE);
return true;
if ($this->_dState === SERIAL_DEVICE_NOTSET)
trigger_error("The device must be set before to be open", E_USER_WARNING);
return false;
if (!preg_match("@^[raw]\+?b?$@", $mode))
trigger_error("Invalid opening mode : ".$mode.". Use fopen() modes.", E_USER_WARNING);
return false;
$this->_dHandle = @fopen($this->_device, $mode);
if ($this->_dHandle !== false)
stream_set_blocking($this->_dHandle, 0);
$this->_dState = SERIAL_DEVICE_OPENED;
return true;
$this->_dHandle = null;
trigger_error("Unable to open the device", E_USER_WARNING);
return false;
* Closes the device
* @return bool
function deviceClose ()
return true;
if (fclose($this->_dHandle))
return true;
trigger_error("Unable to close the device", E_USER_ERROR);
return false;
// OPEN/CLOSE DEVICE SECTION -- {STOP}
// CONFIGURE SECTION -- {START}
* Configure the Baud Rate
* Possible rates : 110, 150, 300, 600, 1200, 2400, 4800, 9600, 38400,
* 57600 and 115200.
* @param int $rate the rate to set the port in
* @return bool
function confBaudRate ($rate)
if ($this->_dState !== SERIAL_DEVICE_SET)
trigger_error("Unable to set the baud rate : the device is either not set or opened", E_USER_WARNING);
return false;
$validBauds = array (
110 => 11,
150 => 15,
300 => 30,
600 => 60,
1200 => 12,
2400 => 24,
4800 => 48,
9600 => 96,
19200 => 19,
38400 => 38400,
57600 => 57600,
115200 => 115200
if (isset($validBauds[$rate]))
$ret = $this->_exec("stty -F " . $this->_device . " " . (int) $rate, $out);
if ($this->_os === "darwin")
$ret = $this->_exec("stty -f " . $this->_device . " " . (int) $rate, $out);
$ret = $this->_exec("mode " . $this->_windevice . " BAUD=" . $validBauds[$rate], $out);
else return false;
if ($ret !== 0)
trigger_error ("Unable to set baud rate: " . $out[1], E_USER_WARNING);
return false;
* Configure parity.
* Modes : odd, even, none
* @param string $parity one of the modes
* @return bool
function confParity ($parity)
trigger_error("Unable to set parity : the device is either not set or opened", E_USER_WARNING);
return false;
$args = array(
"none" => "-parenb",
"odd" => "parenb parodd",
"even" => "parenb -parodd",
if (!isset($args[$parity]))
trigger_error("Parity mode not supported", E_USER_WARNING);
return false;
$ret = $this->_exec("stty -F " . $this->_device . " " . $args[$parity], $out);
else
$ret = $this->_exec("mode " . $this->_windevice . " PARITY=" . $parity{0}, $out);
if ($ret === 0)
return true;
trigger_error("Unable to set parity : " . $out[1], E_USER_WARNING);
return false;
* Sets the length of a character.
* @param int $int length of a character (5 <= length <= 8)
* @return bool
function confCharacterLength ($int)
trigger_error("Unable to set length of a character : the device is either not set or opened", E_USER_WARNING);
return false;
$int = (int) $int;
if ($int < 5) $int = 5;
elseif ($int > 8) $int = 8;
$ret = $this->_exec("stty -F " . $this->_device . " cs" . $int, $out);
else
$ret = $this->_exec("mode " . $this->_windevice . " DATA=" . $int, $out);
if ($ret === 0)
return true;
trigger_error("Unable to set character length : " .$out[1], E_USER_WARNING);
return false;
* Sets the length of stop bits.
* @param float $length the length of a stop bit. It must be either 1,
* 1.5 or 2. 1.5 is not supported under linux and on some computers.
* @return bool
function confStopBits ($length)
trigger_error("Unable to set the length of a stop bit : the device is either not set or opened", E_USER_WARNING);
return false;
if ($length != 1 and $length != 2 and $length != 1.5 and !($length == 1.5 and $this->_os === "linux"))
trigger_error("Specified stop bit length is invalid", E_USER_WARNING);
return false;
$ret = $this->_exec("stty -F " . $this->_device . " " . (($length == 1) ? "-" : "") . "cstopb", $out);
else
$ret = $this->_exec("mode " . $this->_windevice . " STOP=" . $length, $out);
if ($ret === 0)
return true;
trigger_error("Unable to set stop bit length : " . $out[1], E_USER_WARNING);
return false;
* Configures the flow control
* @param string $mode Set the flow control mode. Availible modes :
* -> "none" : no flow control
* -> "rts/cts" : use RTS/CTS handshaking
* -> "xon/xoff" : use XON/XOFF protocol
* @return bool
function confFlowControl ($mode)
trigger_error("Unable to set flow control mode : the device is either not set or opened", E_USER_WARNING);
return false;
$linuxModes = array(
"none" => "clocal -crtscts -ixon -ixoff",
"rts/cts" => "-clocal crtscts -ixon -ixoff",
"xon/xoff" => "-clocal -crtscts ixon ixoff"
$windowsModes = array(
"none" => "xon=off octs=off rts=on",
"rts/cts" => "xon=off octs=on rts=hs",
"xon/xoff" => "xon=on octs=off rts=on",
if ($mode !== "none" and $mode !== "rts/cts" and $mode !== "xon/xoff") {
trigger_error("Invalid flow control mode specified", E_USER_ERROR);
return false;
$ret = $this->_exec("stty -F " . $this->_device . " " . $linuxModes[$mode], $out);
else
$ret = $this->_exec("mode " . $this->_windevice . " " . $windowsModes[$mode], $out);
if ($ret === 0) return true;
else {
trigger_error("Unable to set flow control : " . $out[1], E_USER_ERROR);
return false;
* Sets a setserial parameter (cf man setserial)
* NO MORE USEFUL !
* -> No longer supported
* -> Only use it if you need it
* @param string $param parameter name
* @param string $arg parameter value
* @return bool
function setSetserialFlag ($param, $arg = "")
if (!$this->_ckOpened()) return false;
$return = exec ("setserial " . $this->_device . " " . $param . " " . $arg . " 2>&1");
if ($return{0} === "I")
trigger_error("setserial: Invalid flag", E_USER_WARNING);
return false;
elseif ($return{0} === "/")
trigger_error("setserial: Error with device file", E_USER_WARNING);
return false;
else
return true;
// CONFIGURE SECTION -- {STOP}
// I/O SECTION -- {START}
* Sends a string to the device
* @param string $str string to be sent to the device
* @param float $waitForReply time to wait for the reply (in seconds)
function sendMessage ($str, $waitForReply = 0.1)
$this->_buffer .= $str;
if ($this->autoflush === true) $this->serialflush();
usleep((int) ($waitForReply * 1000000));
* Reads the port until no new datas are availible, then return the content.
* @pararm int $count number of characters to be read (will stop before
* if less characters are in the buffer)
* @return string
function readPort ($count = 0)
trigger_error("Device must be opened to read it", E_USER_WARNING);
return false;
if ($this->_os === "linux" || $this->_os === "osx")
// Behavior in OSX isn't to wait for new data to recover, but just grabs what's there!
// Doesn't always work perfectly for me in OSX
$content = ""; $i = 0;
if ($count !== 0)
do {
if ($i > $count) $content .= fread($this->_dHandle, ($count - $i));
else $content .= fread($this->_dHandle, 128);
} while (($i += 128) === strlen($content));
else
do {
return $content;
/* Do nothing : not implented yet */
trigger_error("Reading serial port is not implemented for Windows", E_USER_WARNING);
return false;
* Flushes the output buffer
* Renamed from flush for osx compat. issues
* @return bool
function serialflush ()
if (fwrite($this->_dHandle, $this->_buffer) !== false)
$this->_buffer = "";
return true;
else
trigger_error("Error while sending message", E_USER_WARNING);
return false;
// I/O SECTION -- {STOP}
// INTERNAL TOOLKIT -- {START}
function _ckOpened()
trigger_error("Device must be opened", E_USER_WARNING);
return false;
return true;
function _ckClosed()
if ($this->_dState !== SERIAL_DEVICE_CLOSED)
trigger_error("Device must be closed", E_USER_WARNING);
return false;
return true;
function _exec($cmd, &$out = null)
$desc = array(
1 => array("pipe", "w"),
2 => array("pipe", "w")
$proc = proc_open($cmd, $desc, $pipes);
$ret = stream_get_contents($pipes[1]);
$err = stream_get_contents($pipes[2]);
fclose($pipes[1]);
fclose($pipes[2]);
$retVal = proc_close($proc);
if (func_num_args() == 2) $out = array($ret, $err);
return $retVal;
// INTERNAL TOOLKIT -- {STOP}
