gauravsharma0190
interfacing ADC to raspberry
Wed Jan 21, 2015 6:43 am
hello everyone
i want to interface the adc with my pi board ADC0808...
how can i programme in raspberry pi without the wiringpi.....because i programme in AVR and pic which is much differ then this programming.....like advance C language....
if anyone help me i will oblige for this
thank you.
danjperron
Re: interfacing ADC to raspberry
Wed Jan 21, 2015 3:21 pm
If you want to access IO directly look at the example of Gert van Loo & Dom included in
http://elinux.org/RPi_Low-level_peripherals
More or less you need to acces the register in 32 bits mode. the macro decode which IO you want and do the read, and/or bit manipulation, and write the needed value.
Daniel
Redrobes
Wed Jan 21, 2015 5:57 pm
I wrote a driver you can use if you dont want to go via python or the memory device.
See:
http://www.raspberrypi.org/forums/viewt ... 33&t=32152
Return to “C/C++”
