rasp87
tedious boost problem with standard deviation
Wed Oct 01, 2014 8:16 am
According to http://stackoverflow.com/questions/7616 ... using-boos, I'm trying to get standard deviation for values of a vector with this code inside a function:
// includes
#include "boost/accumulators/accumulators.hpp"
#include "boost/accumulators/statistics/stats.hpp"
#include "boost/accumulators/statistics/mean.hpp"
#include "boost/accumulators/statistics/moment.hpp"
#include "boost/bind.hpp"
vector<float> vcPenVals;
// initilizing vcPenVals is done here and then
using namespace boost::accumulators;
accumulator_set< float, stats<tag::variance> > acc;
for_each( vcPenVals.begin(), vcPenVals.end(), boost::bind<void>(boost::ref(acc), _1) );
float flStdDev = sqrt( tag::variance(acc) );
cout << "Standard Deviation = " <<  flStdDev << endl;
return flStdDev;
I get these errors though:
/usr/include/boost/accumulators/framework/depends_on.hpp:334: error: invalid use of incomplete type 'struct boost::accumulators::tag::variance'
/usr/include/boost/accumulators/statistics_fwd.hpp:139: error: forward declaration of 'struct boost::accumulators::tag::variance'
rasp87
Re: tedious boost problem with standard deviation
Sat Oct 04, 2014 6:22 am
Are there any ideas to solve this friends? Please say.
PeterO
Sat Oct 04, 2014 7:24 am
rasp87 wrote:Are there any ideas to solve this friends? Please say.
I can't help other than to say that C++ doesn't seem to be very popular on the Pi and that you would probably do better off asking your question on somewhere like stack overflow.
PeterO
Ravenous
Mon Oct 06, 2014 8:16 am
rasp87 wrote:error: forward declaration of 'struct boost::accumulators::tag::variance'
Just a guess as I'm not a C++ person, but would using a header file ".h" (or whatever C++ uses) fix the forward reference? Not sure, just guessing.
jeanleflambeur
Mon Oct 06, 2014 11:37 am
What version of boost and what compiler are you using?
rasp87
Mon Oct 06, 2014 1:05 pm
jeanleflambeur wrote:What version of boost and what compiler are you using?
I'm developing in qt creator 2.5.0 and boost version is 105000. (I got the vesion using below code:)
cout << "boost version is " << BOOST_VERSION
rasp87
Mon Oct 06, 2014 1:07 pm
It doesn't fix all of them. I have mentioned the includes above. I think that is all there is.
Redrobes
Mon Oct 06, 2014 2:08 pm
I cant specifically help, not having boost etc loaded up right now but the issue is that one of the boost headers has forward declared the tag::variance type but has failed to fully define it. I would expect that there is another header that you would need.
My guess is that accumulators/accumulators.hpp either directly or indirectly includes accumulators/statistics_fwd.hpp and that is what is forward declaring the variance type (at line 139) probably along with a load of other stuff given the header files name. So I would imagine that somewhere in the accumulators.hpp is a list of includes to pull in and one of them below the statistics_fwd header has some compile time define switch tests and that you need something to turn one of them on.
Forward declarations are a huge pain and something I try to avoid as much as I possibly can.
If it were me at this point I would grep through all of boosts headers looking for any reference to the variance tag string and see who (i.e. which header) is actually defining that structure / class. Then go a look for a #include of that header - or possibly just include that header in your list of them.
rasp87
Tue Oct 07, 2014 12:42 pm
Now I found it! When you copy code snippet from somewhere things can get a little boring! I was missing variance.hpp. However in the above mentioned thread the required includes weren't mentioned at all. So I write this code here in that someone might need it:
// includes
#include "boost/accumulators/statistics/variance.hpp"
float flStdDev = sqrt( variance(acc) );
Return to “C/C++”
