mad-hatter
C++/Qt4 - Compiling error after update/upgrade [Solved]
Sun Aug 31, 2014 2:24 pm
This maybe coincidence or me, being stupid.
I ran a full update today:-
apt-get update && apt-get upgrade && apt-get dist-upgrade && apt-get install raspberrypi* && rpi-update
First thing I noticed was the cursor had changed, shows 'waiting/clock' on long operations, never noticed it doing so before.
My problem is that a program that previously compiled OK now does not.
Shown below is the code that refers to time.
Any body got any suggestions?
Regards
compile output:-
:-1: error: common.o: undefined reference to symbol 'clock_gettime@@GLIBC_2.4'
:-1: error: error adding symbols: DSO missing from command line
/lib/arm-linux-gnueabihf/librt.so.1
class cr
public:
    static void delay(quint32, bool);
    static void nanoDelay(quint32);
#include <QTime>
void cr::delay(quint32 delay, bool type) {
    if (type) usleep(delay); //microseconds
    else {                   //milliseconds
        QTime stopTime = QTime::currentTime().addMSecs(delay);
        while(QTime::currentTime() < stopTime) {
            QCoreApplication::processEvents(QEventLoop::AllEvents);
void cr::nanoDelay(quint32 delay) { // nanoseconds
    quint32 endNsecs;
    struct timespec time_now;
    clock_gettime(CLOCK_REALTIME, &time_now);
    endNsecs = (quint32)time_now.tv_nsec + delay;
     while (endNsecs > (quint32)time_now.tv_nsec) {
dmesg on a fresh reboot:-
[   37.106086] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   38.438441] bcm2835-cpufreq: switching to governor ondemand
[   38.438475] bcm2835-cpufreq: switching to governor ondemand
[   44.559150] bcm2708_fb_blank blank_mode=1
[   44.571565] bcm2708_fb_blank returns=1 p[1]=0x80000000
[   46.245174] bcm2708_fb_blank blank_mode=0
[   46.254526] bcm2708_fb_blank returns=0 p[1]=0x80000000
[   67.134334] bcm2835_audio_set_ctls:558  Controls set for stream 0
[   69.166222] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Re: C++/Qt4 - Compiling error after update/upgrade 31-8-2014
Sun Aug 31, 2014 2:51 pm
mad-hatter
Sun Aug 31, 2014 5:16 pm
Hello Heater,
Thanks for your reply.
What I don't understand is that 2 days ago it compiled OK, I didn't have to add any compile flags.
Since then I've done my update/upgrade etc., I also removed gambas3 and
did an apt-get autoremove, I wonder if the autoremove took those files out.
I did a system search on libudev.*, I know it exits and this is OK.
I did a system search on librt.* and its not in the expected directory.
Can I just copy the files from /lib/arm-linux-gnueabihf/ to /usr/lib/ and run 'ldd' or should I reinstall gambas 3.
Regards
root@mypi:/# find -name libudev.*
./usr/lib/libudev.a
./usr/lib/libudev.so
root@mypi:/# find -name librt.*
./lib/arm-linux-gnueabihf/librt.so.1
./usr/lib/arm-linux-gnueabihf/librt.so
./usr/lib/arm-linux-gnueabihf/librt.a
pro file
QT       += core gui
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
TARGET = myProg
TEMPLATE = app
SOURCES += \
    myProg.cpp
HEADERS  += \
    myProg.h
LIBS += \
    -L/usr/lib/ -ludev
mad-hatter
Sun Aug 31, 2014 7:40 pm
Hello Heater,
OK, I've resolved the problem.
I copied librt.a and librt.so from a backup I had.
Ran 'ldconfig'.
Added to the .pro file.
I don't understand why it compiled before, without the change to the .pro file.
Regards
pro file
QT       += core gui
TARGET = myProg
TEMPLATE = app
SOURCES += \
    myProg.cpp
HEADERS  += \
    myProg.h
LIBS += \
    -L/usr/lib/ -ludev \
    -L/usr/lib/ -lrt
Return to “C/C++”
