lihakimpale
Graphical user interface development
Mon Aug 11, 2014 5:08 pm
I need to do graphical user interface for my C code but I am new to GUI development so I don't know how to start.
I have red that Qt might be the best solutions for GUI development. I am developing the C code with Eclipse from my laptop so some Eclipse plugin might be good way to go.
If I am correct there isn't anymore Qt plugin for Eclipse? Can I do the GUI with the normal Qt developer tool and then just add the C code there and run it on my Pi. Does it compile to one executable so that I can run it on my Raspberry Pi like I am doing now. Hope someone can help me to get started.
rfrazier
Re: Graphical user interface development
Mon Aug 11, 2014 8:29 pm
Hi Lihakimpale,
I can't answer your question. But, you might look in this thread
http://www.raspberrypi.org/forums/viewt ... 34&t=83554
at this post
http://www.raspberrypi.org/forums/viewt ... 40#p595140
for posts by Heater. He mentions QT GUI development for C++. You could also send him a private message if you like.
Sincerely,
Ron
(PS - If you email me and don't get a quick response, you might want to send again after a couple of weeks. I don't always see new email messages quickly.)
Ron's Tech Rant Blog: techstarship.com - Blog RSS: techstarship.com/feed/
Ron Frazier
mad-hatter
Tue Aug 12, 2014 10:09 am
There is a Qt4 GUI development system available for the Pi.
sudo apt-get install qtcreator.
You might want to look here, to set it up.
http://www.raspberrypi.org/forums/viewt ... 31&t=43545
I don't know if the 'Eclipse' plugin will run on the Pi.
QtCreator can bet set up, in such a way as to allow you to write code (C or C++ or a combination of the two),
compile, debug and run your code from within the Qt GUI running on the Pi.
There are a whole bunch of Qt4 modules available.
Qt5 is available for the Pi, I've never used it, so can't offer any advice.
Regards
lihakimpale
Tue Aug 12, 2014 12:40 pm
I decided to go with this tutorial http://qt-project.org/wiki/RaspberryPi_Beginners_guide but then I got confused about the mounting of the wheezy image. What is the point of that? Can I bypass that somehow and get it still working properly?
PeterO
Tue Aug 12, 2014 1:05 pm
As the title says ... "Beginner’s guide to cross-compile Qt5 on RaspberryPi". That means the development is done on a desktop linux PC rather than on the PI itself. It does produce programs that run on the PI, but the compilations are done on the PC.
PeterO
lihakimpale
Tue Aug 12, 2014 1:15 pm
PeterO wrote:As the title says ... "Beginner’s guide to cross-compile Qt5 on RaspberryPi". That means the development is done on a desktop linux PC rather than on the PI itself. It does produce programs that run on the PI, but the compilations are done on the PC.
PeterO
Yes I knew that. That's why I decided to go with that because I prefer to develop the code from my laptop.
PeterO
Tue Aug 12, 2014 1:20 pm
Ok, the need to cross compile was rather well hidden in your original post ! :roll:
It would seem to be much better to use NFS to mount a shared directory fromo the PC onto the PI. That would remove the need to keep moving the SD card between the PC and the PI.
PeterO
lihakimpale
Wed Aug 13, 2014 11:16 am
I am confused about what I need to transfer by nfs to Raspberry Pi
lihakimpale
Wed Aug 13, 2014 11:21 am
I can't even find the .exe file of the Qt Creator so that I could start the program :D
PeterO
Wed Aug 13, 2014 12:09 pm
lihakimpale wrote:I can't even find the .exe file of the Qt Creator so that I could start the program :D
Sorry, but I have no experience with any Windows tools.
PeterO
mad-hatter
Wed Aug 13, 2014 12:15 pm
If you know its name, use Windows menu/search, accepts wildcards.
Regards
lihakimpale
Wed Aug 13, 2014 12:19 pm
I'm running it on Ubuntu.
mad-hatter
Wed Aug 13, 2014 12:22 pm
sudo find -name namehere
Regards
Return to “C/C++”
