Rapberry pi 4 IO memory base address
Posted: Sat Jun 29, 2019 3:26 am
by chipace
Anyone know the RPi 4 base IO address (and the offset for GPIO)?
This is what I used for RPi 3:
#define BCM2708_PERI_BASE 0x3F000000
#define GPIO_BASE (BCM2708_PERI_BASE + 0x200000)
Thanks.
Re: Rapberry pi 4 IO memory base address
Posted: Sat Jun 29, 2019 12:37 pm
by DavidS
This has been mentioned over in the baremetal sub-forum here:
Raspberry Pi 4
See the post:
Raspberry Pi 4: CPU and peripherals base addresses: by gothicknight
Posted: Sat Jun 29, 2019 1:50 pm
by joan
Peripheral base is 0xFE000000.
Peripheral offsets are unchanged (as far as I can tell).
Posted: Sat Jun 29, 2019 8:37 pm
by chipace
Thanks joan! My gpio is working great now.
I used a simple C program to toggle one pin as fast as possible and I am measuring 12.5MHz (80ns period with 25% duty cycle).
Posted: Sat Jun 29, 2019 9:24 pm
by joan
What code are you using for the toggle? I thought it might be a bit faster as I think the GPIO are connected differently (I may well have misremembered or misinterpreted something I read).
Posted: Sun Jun 30, 2019 12:35 am
by dl324
I get 17MHz from Pi 0; 29MHz with compiler optimization.
Posted: Mon Jul 01, 2019 5:32 am
by chipace
Here's the code. I found it on-line. I am not very familiar with C.
If you have a more simple code example, I would very much like to use it.
//  How to access GPIO registers from C-code on the Raspberry-Pi
//  Example program
//  15-January-2012
//  Dom and Gert
//  Revised: 15-Feb-2013
// Access from ARM Running Linux
#define BCM2711_PERI_BASE        0xFE000000
#define GPIO_BASE                (BCM2711_PERI_BASE + 0x200000) /* GPIO controller */
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <sys/mman.h>
#include <unistd.h>
#define PAGE_SIZE (4*1024)
#define BLOCK_SIZE (4*1024)
int  mem_fd;
void *gpio_map;
// I/O access
volatile unsigned *gpio;
// GPIO setup macros. Always use INP_GPIO(x) before using OUT_GPIO(x) or SET_GPIO_ALT(x,y)
#define INP_GPIO(g) *(gpio+((g)/10)) &= ~(7<<(((g)%10)*3))
#define OUT_GPIO(g) *(gpio+((g)/10)) |=  (1<<(((g)%10)*3))
#define SET_GPIO_ALT(g,a) *(gpio+(((g)/10))) |= (((a)<=3?(a)+4:(a)==4?3:2)<<(((g)%10)*3))
#define GPIO_SET *(gpio+7)  // sets   bits which are 1 ignores bits which are 0
#define GPIO_CLR *(gpio+10) // clears bits which are 1 ignores bits which are 0
#define GET_GPIO(g) (*(gpio+13)&(1<<g)) // 0 if LOW, (1<<g) if HIGH
#define GPIO_PULL *(gpio+37) // Pull up/pull down
#define GPIO_PULLCLK0 *(gpio+38) // Pull up/pull down clock
void setup_io();
void printButton(int g)
  if (GET_GPIO(g)) // !=0 <-> bit is 1 <- port is HIGH=3.3V
    printf("Button pressed!\n");
  else // port is LOW=0V
    printf("Button released!\n");
int main(int argc, char **argv)
  int g,rep;
  // Set up gpi pointer for direct register access
  setup_io();
  // Switch GPIO 7..11 to output mode
  * You are about to change the GPIO settings of your computer.          *
  * Mess this up and it will stop working!                               *
  * It might be a good idea to 'sync' before running this program        *
  * so at least you still have your code changes written to the SD-card! *
  // Set GPIO pin 21 to output
  INP_GPIO(21); // must use INP_GPIO before we can use OUT_GPIO
  OUT_GPIO(21);
  for (rep=0; rep<10000; rep++)
     GPIO_SET = 1<<21;
     GPIO_SET = 1<<21;
     GPIO_CLR = 1<<21;
     GPIO_CLR = 1<<21;
  return 0;
} // main
// Set up a memory regions to access GPIO
void setup_io()
   /* open /dev/mem */
   if ((mem_fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0) {
      printf("can't open /dev/mem \n");
      exit(-1);
   /* mmap GPIO */
   gpio_map = mmap(
      NULL,             //Any adddress in our space will do
      BLOCK_SIZE,       //Map length
      PROT_READ|PROT_WRITE,// Enable reading & writting to mapped memory
      MAP_SHARED,       //Shared with other processes
      mem_fd,           //File to map
      GPIO_BASE         //Offset to GPIO peripheral
   close(mem_fd); //No need to keep mem_fd open after mmap
   if (gpio_map == MAP_FAILED) {
      printf("mmap error %d\n", (int)gpio_map);//errno also set!
      exit(-1);
   // Always use volatile pointer!
   gpio = (volatile unsigned *)gpio_map;
} // setup_io
Posted: Mon Jul 01, 2019 5:44 am
by Heater
chipace,
I did an experiment like yours a year or so ago. Using Dom and Gerts example code. I added a simple loop to toggle an I/O pin as fast as possible.
On a Pi 3 I achieved a 50MHz toggle rate. https://www.raspberrypi.org/forums/view ... 3&start=25
Be aware that when doing that under Raspbian there will be all kinds of stutters and delays that upset the goggle timing as the Linux kernel reschedules tasks, handles interrupts etc.
To achieve an almost continuous toggle at a constant rate I had to take the precaution of running the code on it's own isolated core that Linux was prevented from scheduling anything on. Methods for doing that are described in the the thread linked above.
Posted: Tue Jul 02, 2019 10:15 pm
by DavidS
Just out of curiosity (not yet having a RPi 4B):
Has anyone figured how much of the peripheral address space is the same layout, relative to the base address, for the Raspberry Pi 4B as for earlier Raspberry Pi's?
Also is there any difference in the mailbox channels for communicating with the GPU firmware?
Just
Posted: Tue Jul 02, 2019 10:58 pm
by joan
Peripheral offsets appear to be the same. Tested GPIO, SYST, SPI, DMA, PWM.
I only use the mailbox to allocate/free memory. That works as before.
Posted: Tue Jul 02, 2019 11:56 pm
by DavidS
Thank you for that. That tells me that a lot of my code for the RPi 1 B, 2B, and 3B/3B+ should work with just a change of periphial base on the RPi 4B (so for many things no need to reinvent the wheel, as it were). Still going to be interesting to learn about USB, PCIe, and Ethernet on the RPi 4B though.
Thank you for the information.
Posted: Wed Jul 03, 2019 6:21 am
by Paul Webster
Is there an official way to get the base address at runtime (i.e. not using defines).
With older Raspbian builds it could be found via /proc/iomem
with different keywords depending whether or not device tree was being used.
https://www.raspberrypi.org/forums/view ... p?t=100066
Edit: changed /dev to /proc as had misremembered
Posted: Wed Jul 03, 2019 7:12 am
by joan
Not official but something like:
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
int main(int argc, char *argv[])
   FILE *fp;
   uint32_t base;
   unsigned char buf[12];
   if (fp = fopen("/proc/device-tree/soc/ranges" , "rb"))
      if (fread(buf, 1, sizeof(buf), fp) >= 8)
         base = buf[4]<<24 | buf[5]<<16 | buf[6]<<8 | buf[7];
         if (!base)
            base = buf[8]<<24 | buf[9]<<16 | buf[10]<<8 | buf[11];
         printf("peri base is %x\n", base);
      fclose(fp);
Posted: Wed Jul 03, 2019 8:59 am
by jamesh
With older Raspbian builds it could be found via /dev/iomem
There is a standard function, but its not yet been updated to have the correct value for Pi4. It's in our issues list.
https://www.raspberrypi.org/documentati ... dresses.md
Posted: Wed Jul 03, 2019 9:40 am
by Paul Webster
I have created an issue on LCDProc github with link to this.
I submitted a change to LCDProc for older RPi when base changed for the first time - but this time around it is probably best to fix it in a more generic way.
What timescale for the updated official way and how backwards compatible will it be (i.e. will it work on old RPi that are not running Buster) if developers include the required files?
Posted: Thu Jul 04, 2019 6:10 am
by Paul Webster
Update from LCDProc ... they now consider having specific RPi module for GPIO-based devices as obsolete and instead they want to control via libgpiod.
So ... quick question ... does libgpiod know about the RPi4 base address or whatever it needs to access them?
Edit:
Someone with access to RPi4 (mine is nowhere near me) and something on GPIO could use
gpioinfo pinctrl-bcm2835
assuming that is still the correct name.
Posted: Thu Jul 04, 2019 9:39 am
by rudiratlos
cat /proc/iomem | grep gpio@
produces the following output on different plattforms:
rpi4: fe200000-fe2000b3 : gpio@7e200000
rpi2-3x: 3f200000-3f2000b3 : gpio@7e200000
zerow: 20200000-202000b3 : gpio@7e200000
e.g. just subtract the GPIO-BaseAddr 0x00200000 from fe200000 or 3f200000 or 20200000 and you will get the PeripheralBaseAddr (PBase) for each pi
iomem is better than using:
xxd -ps -c250 /proc/device-tree/soc/ranges
this creates strange output (I do not understand for rpi4):
ZeroW: 7e0000002000000002000000...
3B+: 7e0000003f00000001000000400000004000000000001000
4B: 7e00000000000000fe000000018000007c00000000000000fc000000020000004000000000000000ff80000000800000
Posted: Thu Jul 04, 2019 12:11 pm
by Paul Webster
The change that I submitted to LCDProc in 2015 did something similar.
However, those particular fields have disappeared ... so someone using the above code would also need something like my stuff below if it is required to run on older Raspbian systems
extract from the diff ...
+       if ((fp = fopen("/proc/iomem", "r")) != NULL) {
+               /* Would expect this to be present but perhaps not on all supported OS so not fatal */
+               /* Check to see if setting shows the GPIO base value */
+               while (!feof(fp)) {
+                       fgets(buf, sizeof(buf), fp);
+                       /* from Device Tree-enabled B+ - 20200000-202000b3 : /soc/gpio */
+                       if (strstr(buf, "/soc/gpio") != NULL) {
+                               sscanf(buf, "%x-%x : /soc/gpio", &gpio_base, &gpio_top);
+                       /* without Device Tree - 20200000-20200fff : bcm2708_gpio */
+                       if (strstr(buf, "bcm2708_gpio") != NULL) {
+                               sscanf(buf, "%x-%x : bcm2708_gpio", &gpio_base, &gpio_top);
Posted: Thu Jul 04, 2019 2:43 pm
by 6by9
Look at the source DT rather than the compiled version.
https://github.com/raspberrypi/linux/bl ... 5.dtsi#L20
https://github.com/raspberrypi/linux/bl ... 36.dtsi#L8
https://github.com/raspberrypi/linux/bl ... 8.dtsi#L16
BCM2838 has LPAE enabled , therefore all DMA addresses are 64bit.
Posted: Sun Nov 17, 2019 11:01 pm
by JGPIO
Perhaps I've missed something, but is there any particular reason no one is using the bcm_host_get_peripheral_address() function?
Posted: Mon Nov 18, 2019 8:39 am
by joan
History. A lot of code was written and tested and debugged before that interface became available.
Utility. It didn't help with the Pi4B. As far as I am aware it was not updated for some time after the release of the Pi4B.
Portability. Does it work on all Linux distributions, does it work on 64-bit systems. If it does I might change my code to use it.
