How to use c/c++ to run my rpi 0
Posted: Tue Jun 25, 2019 10:27 pm
by dharanivel
Please tell me how to use c/c++ to run my rpi0.
Re: How to use c/c++ to run my rpi 0
Posted: Tue Jun 25, 2019 10:41 pm
by jahboater
Can you explain what your question means?
Raspbian includes a C/C++ compiler as standard.
Its called gcc.
Posted: Tue Jun 25, 2019 11:52 pm
by dl324
If you know how to program in C or C++ on Unix/Linux, you already know how to do it on RPi.
Posted: Wed Jun 26, 2019 12:23 am
by Andyroo
https://www.raspberrypi.org/magpi/issue ... ogramming/
Hardback versions are available if you do not like PDFs :)
Posted: Wed Jun 26, 2019 5:19 am
by dharanivel
I need to run standalone c c++ in rpi0
Posted: Wed Jun 26, 2019 5:34 am
by rpdom
Are you talking Bare Metal (no OS)?
That is possible, but a lot of work and you will have to write some hardware drivers yourself.
If that is the case, report this post and ask for it to be moved to the "Bare Metal" section of the forums and people will be able to give you better advice there.
Posted: Wed Jun 26, 2019 9:31 am
by dharanivel
Actually Iam trying to build a standalone OS. Can you able to help me
Posted: Wed Jun 26, 2019 9:35 am
by rpdom
That's the sort of thing that is discussed in Bare Metal.
Posted: Wed Jun 26, 2019 11:03 am
by jamesh
If that is your aim, but you are having to ask the questions above, then I suspect you need to do a little more reading up before you start anything. Wiring an OS is a very very non-trivial task, and if you don't yet know how to use C/C++ on the Pi then you have a VERY steep mountain to climb.
