RomoBoom
i am trying to make a small window appear, with nothing in it, but it just isn't working.
Sun May 05, 2019 1:58 pm
The code is from a book called
AN INTRODUCTION TO
---------C & GUI-------------
----PROGRAMMING-----
By: Simon Long
Code:
#include <gkt/gkt.h>
int main (int argc,char *argv[])
  gkt_init (&argc, &argv);
  GtkWidget *win = gkt_window_new (GKT_WINDOW_TOPLEVEL);
  gkt_widget_show (win);
  gkt_main ();
  return 0;
(in geany)
and this happens
(i ran it through the terminal)
picture of error
if you see what is wrong, please tell me, so that i can fix it :D :D :)
buja
Re: Is this wrong?
Sun May 05, 2019 2:01 pm
Just a guess: wrong spelling: gkt => should be gtk, try:
#include <gtk/gtk.h>
Edit: now that I try it myself I see that you made the same typo everywhere :lol:
Edit 2: it might be a good idea to download the PDF of the book and copy & paste the example programs instead of typing them, saves a few errors.
B.Goode
Re: Is this wrong?
Sun May 05, 2019 3:37 pm
This is a cut'n paste of the PDF download -
int main (int argc, char *argv[])
 gtk_init (&argc, &argv);
 GtkWidget *win = gtk_window_new (GTK_WINDOW_TOPLEVEL);
 gtk_widget_show (win);
 gtk_main ();
 return 0;
So unless something went badly wrong when the paper book was printed, it seems your code is not what is in the book.
cmrincon
Re: Is this wrong?
Mon May 06, 2019 10:27 am
From that same guide:
First we need to make sure that the relevant GTK libraries are installed. To do this, type
sudo apt-get install libgtk2.0-dev into a terminal window and answer yes to any
prompts – this installs the developer libraries for GTK 2.
B.Goode
Re: Is this wrong?
Mon May 06, 2019 10:38 am
Obviously correct in itself.
But as already stated, it won't help with compilation of code that contains:
RomoBoom
Re: Is this wrong?
Sun May 12, 2019 5:22 pm
its from a book, so no copy paste
RomoBoom
Re: i am trying to make a small window appear, with nothing in it, but it just isn't working.
Sun May 12, 2019 5:30 pm
i did everything that you guys said, and this happened :x
same error,
different code.
RomoBoom
Sun May 12, 2019 5:38 pm
ugh
i found it
if you see it, you have good eyes
(Hint: gkt)
RomoBoom
Sun May 12, 2019 5:42 pm
YASSSSSSS!!!! it worked!!! :D :D :D :D :D :D :D :D :lol: :lol: :lol: :) :D
THANK YOU EVERYONE!!!
RomoBoom
Sun May 12, 2019 5:48 pm
:D
just saying, this is a base for something bigger, i just had to get this right! :D
Return to “C/C++”
