vajra11
Blinking led on raspberry pi in c
Sun Jul 08, 2018 2:56 pm
I am trying to blink led on raspberry pi. I have raspberry Pi3 . I am following this link http://wiringpi.com/examples/blink/
I followed all step but My led is not blinking. What could be wrong
This is output of terminal
Re: Blinking led on raspberry pi in c
Sun Jul 08, 2018 3:25 pm
What is wrong is that it does not work.
I suspect that nobody can help unless you show the code you are actually using and explain exactly how you have wired up your LED.
Might help to mention exact Raspi model and operating system version as well.
My suspicion is that if you had followed the instructions you have linked to correctly then it would work.
Is your LED the right way around for example?
vajra11
Sun Jul 08, 2018 4:22 pm
Raspberry Pi 3 Model B Rev 1.2
Raspbian GNU/Linux 9 (stretch)
code
#include <wiringPi.h>
int main (void)
  wiringPiSetup () ;
  pinMode (0, OUTPUT) ;
  for (;;)
    digitalWrite (0, HIGH) ; delay (500) ;
    digitalWrite (0,  LOW) ; delay (500) ;
  return 0 ;
LED connection
1dot0
Sun Jul 08, 2018 4:47 pm
hi,
Does wiringPi work correctly? What happens if you type in the console
gpio -v
gpio readall
Did you check if you really had connected to GPIO 0 and not to a different neighbor pin?
Is the LED connected correctly? does the LED turn on if you disconnect the wire to GPIO 0 and then connect to +3.3V?
rpiMike
Sun Jul 08, 2018 4:54 pm
Works fine for me - have you tried turning the LED around. Post an actual photo of your wiring.
vajra11
Sun Jul 08, 2018 6:54 pm
Take look at wiring
Sun Jul 08, 2018 7:44 pm
You have the red wire on pin 6 which is ground.
Which is very confusing.
Are you sure that LED is the right way around?
vajra11
Mon Jul 09, 2018 2:50 am
Thanks to all of you. I had connected led in wrong direction. now its flashing
Return to “C/C++”
