nklr
Unable to start dbus-daemon on Raspbian Lite
Thu Apr 12, 2018 9:40 am
I get the following error when I try to start a dbus program.
 Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
I think this is because Raspbian Lite does not have a GUI display.
Can you please suggest a way to get around this issue?
Thanks.
n67
Re: Unable to start dbus-daemon on Raspbian Lite
Thu Apr 12, 2018 10:27 am
What program are you trying to launch?
"L'enfer, c'est les autres"
Epmu Sn!
topguy
Thu Apr 12, 2018 4:13 pm
DBus is mainly used to send messages between GUI programs, programs that need the X-server.
You can set the environment variable DISPLAY with "export DISPLAY=:0.0" which will point to a non running X-server on localhost.
But I guess that will only give you a different error message.
You also have the option to install and start an X-server. Using https://en.wikipedia.org/wiki/Xvfb for example.
nklr
Mon Apr 16, 2018 2:15 pm
Can you please suggest a technique for inter process communication for non-GUI application?
SteveSpencer
Fri Apr 27, 2018 8:42 am
Named pipes, shared memory, sockets are the ones that immediately spring to mind, or MQTT, even.
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
Return to “C/C++”
