spi
Posted: Tue Oct 16, 2012 4:58 pm
by Baeseke
Dear,
I'm trying to get an DS1390 SPI RTC (http://datasheets.maximintegrated.com/e ... DS1394.pdf) working on a raspberry pi.
I'm using debian wheezy with the http://www.open.com.au/mikem/bcm2835/index.html lib, currently i'm using this code:
 int main(int argc, char **argv) {
    // If you call this, it will not actually access the GPIO
// Use for testing
//        bcm2835_set_debug(1);
      if (!bcm2835_init())
        return 1;
    bcm2835_spi_begin();
    bcm2835_spi_setBitOrder(BCM2835_SPI_BIT_ORDER_LSBFIRST);      // The default
    bcm2835_spi_setDataMode(BCM2835_SPI_MODE0);                   // The default
    bcm2835_spi_setClockDivider(BCM2835_SPI_CLOCK_DIVIDER_512); // The default
    bcm2835_spi_chipSelect(BCM2835_SPI_CS0);                      // The default
    bcm2835_spi_setChipSelectPolarity(BCM2835_SPI_CS0, HIGH);   // the default
	//sleep(5);
		unsigned char msec=0, sec=0x12, min=0x23, hr=0x05, dow=0x07, date=0x25, mon=0x08, yr=0x12;
    // Send a byte to the slave and simultaneously read a byte back from the slave
    // If you tie MISO to MOSI, you should read back what was sent
			uint8_t data = bcm2835_spi_transfer(0x8d);
	   		printf("Dummy: %02X\n", data);
			data = bcm2835_spi_transfer(0x18);
			data = bcm2835_spi_transfer(0x80);
			data = bcm2835_spi_transfer(msec);
			data = bcm2835_spi_transfer(sec);
			data = bcm2835_spi_transfer(min);
			data = bcm2835_spi_transfer(hr);
			data = bcm2835_spi_transfer(dow);
			data = bcm2835_spi_transfer(date);
			data = bcm2835_spi_transfer(mon);
			data = bcm2835_spi_transfer(yr);
		data = bcm2835_spi_transfer(0);
			printf("msec: %02X\n", data);
			printf("sec: %02X\n", data);
			printf("min: %02X\n", data);
			printf("hr: %02X\n", data);
			printf("dow: %02X\n", data);
			printf("date: %02X\n", data);
			printf("mon: %02X\n", data);
			printf("yr: %02X\n", data);
    bcm2835_spi_end();
    return 0;
Normally i would use a buffer and other stuff to shorten the code but for the moment the data I receive is always incorrect and i even looks like it's rotating with 4 byte.
Am I doing something wrong here?
Thanks in advance
Baeseke
Re: spi
Posted: Wed Oct 17, 2012 12:07 pm
by gordon@drogon.net
Baeseke wrote: Am I doing something wrong here?
Thanks in advance
Baeseke
May I ask why you're not using the Kernel SPI driver? It's trivially easy to do stuff like this with it.
I can't think of any reason whatsoever to not use it these days. It's been stable for months now.
-Gordon
Re: spi
Posted: Wed Oct 17, 2012 10:41 pm
by Baeseke
Dear,
I've been testing with all the possible drivers i could find.
After changing some settings it's almost working.
The only problem I have right now is that the RTC doesn't count, the data is always the same, even when the status registers have the correct bits
Re: spi DS1390 / DS1394
Posted: Tue Oct 03, 2017 10:27 am
by xranby
Can you share the devicetree .dts configuration you made?
Trickle charge support was added first in 2015 for the linux kernel driver thus you may need a fairly recent 4.4 linux kernel if you require such support.
https://github.com/torvalds/linux/commi ... c-ds1390.c
Re: spi
Posted: Tue Oct 03, 2017 10:51 am
by PeterO
Did we even have device tree support five years ago (that's how old this thread is!).
PeterO
Posted: Tue Oct 03, 2017 2:56 pm
by xranby
I advice you to look at using the kernel module and a device tree overlay to add the ds1390 to your system as a system realtime clock.
I could not find any examples online how to configure a device tree for the ds1390 thus I have created something here that you can look at and use as a reference. I have composed a devicetree overlay that can detect a ds1394 on the spi bus (same driver as the ds1390), you need to change the trickle resistor and use of internal diode to match your setup.
ds1390-rpi.dts
/dts-v1/;
/plugin/;
    compatible = "brcm,bcm2835";
    fragment@0 {
        target = <&spi0>;
        __overlay__ {
            /* disable spi-dev for spi0.0 */
            spidev@1 {
                status = "disabled";
            spidev@0 {
            /* enable ds1394 RTC clock */
            ds1390: rtc@0 {
                compatible = "rtc-ds1390";
                reg = <0>;
                trickle-diode-disable = <0>;
                trickle-resistor-ohms = <250>;
                spi-max-frequency = <4000000>;
                status = "okay";
to ease compilation you create a
Makefile
DTC=dtc
all: ds1390-rpi.dtb
ds1390-rpi.dtb: ds1390-rpi.dts
        $(DTC) -@ -I dts -O dtb -o ds1390-rpi.dtbo ds1390-rpi.dts
install-ds1390-rpi.dtbo: ds1390-rpi.dtbo
        cp ds1390-rpi.dtbo /boot/overlays/
install: install-ds1390-rpi.dtbo
clean:
        rm *.dtbo
to install you run
 make
sudo make install
You also need to add the following line to /boot/config.txt
dtoverlay=ds1390-rpi
when you boot up you can check the "dmesg" command and notice that the ds1390 or ds1394 has been registered as a system rtc clock. you can use sudo hwclock -r to read the time stored in the chip sudo hwclock -s to set the system time from the clock chip and sudo hwclock -w to write system time to the clock chip
