matherp
Not seeing ctrl-Z
Wed Nov 22, 2017 10:14 am
I've got a text based application that uses ncurses in raw mode (all keystrokes go to the application) to do some simple screen handling. The application traps ctrl-Z and does an orderly shutdown when it sees it.
This works perfectly when the application is run in putty over SSH to a Raspbian Lite Pi. It also works perfectly in a console window on a full Raspbian install. However ctrl-Z isn't seenwhen running on the local console on a Raspbian Lite Pi
Any ideas appreciated as to why this is the case and possible solutions.
JosAH
Re: Not seeing ctrl-Z
Wed Nov 22, 2017 10:42 am
I bet putty itself runs on a MS Windows box which interprets ctrl-Z as an end-of-stream event. On a local terminal (which happens to run on Linux), the same event can be generated by pressing ctrl-D.
kind regards,
Jos
jahboater
Wed Nov 22, 2017 11:01 am
No, ^Z is the suspend key in the console.
https://askubuntu.com/questions/510811/ ... -the-shell
I see that
showkey -a
lets it through.
You might be able to use the ncurses function define_key() to map something else onto ^Z.
^D is EOF
^C aborts the application: SIGINT
^Z suspends it: SIGTSTP
Return to “C/C++”
