Page 1 of 2
Error: ‘for’ loop initial declarations are only allowed in C99 or C11 mode
Posted: Thu Sep 28, 2017 9:12 am
by tchichua25
Hey everyone,
I'm trying to compile really simple code on my RPi3 using Geany. The code was originally written using code::blocks on windows and it was working without any problem. The errors I'm getting are:
untitled.c:33:5: error: ‘for’ loop initial declarations are only allowed in C99 or C11 mode
and
untitled.c:33:5: note: use option -std=c99, -std=gnu99, -std=c11 or -std=gnu11 to compile your code
As I understand the code is not the problem but the way I'm compiling it. Can you give me any advice?
Re: Error: ‘for’ loop initial declarations are only allowed in C99 or C11 mode
Posted: Thu Sep 28, 2017 9:22 am
by PeterO
You need to add one of the suggested options to the compile command configured in geany,
In the menu.. Build -> Set Build Commands add "-std=c99" after "gcc" in Compile and Build boxes.
(I'm looking on a MINT PC but I expect the version on PI is the same).
PeterO
Posted: Thu Sep 28, 2017 9:28 am
by tchichua25
PeterO
Compilation finished successfully.
Yeeyy! Thank you so much, works like a charm!
Posted: Thu Sep 28, 2017 10:17 am
by jahboater
By the way, in Stretch (the recent version of Raspbian) it now defaults to C11 which is the latest C standard.
Posted: Thu Sep 28, 2017 11:00 am
by Stiller
tbh I never heard about a for-loop which just compiles (and complies) with C99 or C11, so I'm really curious about the current source code and the actual Geany compile/build-settings
Posted: Thu Sep 28, 2017 11:02 am
by jamesh
/* Works for any C */
int i
for (i=0;i<10;i++)
// Requries C99 (although some older compilers do support it)
for (int i=0;i<10;i++)
Posted: Thu Sep 28, 2017 11:09 am
by Stiller
for (i=0;i<10;i++)
so far I've been using both versions with the standard Geany settings in gcc 5.x and 7.x (Jessie admittedly), regardless of explicitely std=-C99/11 in the Geany settings or not.
Posted: Thu Sep 28, 2017 11:28 am
by jamesh
for (i=0;i<10;i++)
I think those versions of the compiler default to at least C99 so will work with both version out of the box.
Posted: Thu Sep 28, 2017 11:50 am
by Stiller
exactly! So that's why I can't explain that the OP's Geany or compiler didn't comply with these defaults!
... so I'm really curious about the current source code and the actual Geany compile/build-settings
Posted: Thu Sep 28, 2017 12:04 pm
by Martin Frezman
It depends on which version of gcc you are using. They changed the default standard somewhere along the way (I think [but don't quote me] that up through 5.x, the default was gnu89, as of 6.0, they changed it to gnu99).
This in turn depends on which OS (we tend to assume Raspbian, but it needn't be true) and which version of that OS any one particular poster is running.
Posted: Fri Sep 29, 2017 6:27 am
by jahboater
Yes thats right. In fact they changed it all the way to gnu11 and gnu++14).
The compiler that comes with stretch is 6.3 and is C11 by default and C++14.
Posted: Fri Sep 29, 2017 7:37 am
by Stiller
so if the OP had Stretch or Jessie he probably wouldn't have run into this issue: both apply to C99 or even C11 from the start.
Thats why I'm still curious about the current source code and the actual Geany compile/build-settings - or which OS he is using instead.
Posted: Fri Sep 29, 2017 11:47 am
by Paeryn
Gcc in Jessie defaults to gnu90 IIRC.
Posted: Fri Sep 29, 2017 12:52 pm
by Stiller
how could then both work with jessie, gcc, and Geany, without std=-C99 / -C11 setting?
for (i=0;i<10;i++)
Posted: Fri Sep 29, 2017 2:06 pm
by jamesh
for (i=0;i<10;i++)
it doesn't, judging by the original post.
Posted: Fri Sep 29, 2017 3:49 pm
by Stiller
no, it does:
for (i=0;i<10;i++)
Stiller wrote:so if the OP had Stretch or Jessie he probably wouldn't have run into this issue: both apply to C99 or even C11 from the start.
Posted: Fri Sep 29, 2017 4:02 pm
by Martin Frezman
no, it does:
Yes, it doesn't. Are we having fun yet?
FWIW, I just tested on an up-to-date Jessie system, running GCC 4.9.2, and it rejects shown below:
$ printf "#include <stdio.h>\nint main(void) { for (int i=1; i<5; i++); }\n" | gcc -xc -
<stdin>: In function 'main':
<stdin>:2:18: error: 'for' loop initial declarations are only allowed in C99 or C11 mode
<stdin>:2:18: note: use option -std=c99, -std=gnu99, -std=c11 or -std=gnu11 to compile your code
Note, of course, that version of OS really isn't the variable; the variable is version of GCC.
Anyway, it turns out to be rather difficult to answer the simple question: What is the default standard for my version of GCC? That is, there's no good "system" way to do it; you have to check the documentation.
The following comes close (so solving our over-arching problem):
$ gcc -dM -E - < /dev/null | grep STDC
#define __STDC_HOSTED__ 1
#define __STDC_IEC_559__ 1
#define __STDC_ISO_10646__ 201103L
#define __STDC_NO_THREADS__ 1
#define _STDC_PREDEF_H 1
#define __STDC_IEC_559_COMPLEX__ 1
#define __STDC__ 1
The variable that should be there, but isn't, is __STDC_VERSION__, as shown in the next example:
$ gcc -std=gnu99 -dM -E - < /dev/null | grep STDC
#define __STDC_UTF_16__ 1
#define __GNUC_STDC_INLINE__ 1
#define __STDC_VERSION__ 199901L
#define __STDC_UTF_32__ 1
#define __STDC__ 1
Posted: Fri Sep 29, 2017 4:10 pm
by Stiller
that is really funny - except apt-get update and upgrade I never made changes to my Jessie, nor did I upgrade gcc (except once for a try on a sepaerate SD, but reformatted then everything) - nonetheless both for-loops work without setting a std=-Cxx flag.
gcc is 4.9 .
But I agree, it's a mysterium.
Posted: Fri Sep 29, 2017 4:12 pm
by jahboater
and in the documentation:
gnu11
gnu1x
   GNU dialect of ISO C11.  This is the default for C code.  The name gnu1x is
   deprecated.
Posted: Fri Sep 29, 2017 4:13 pm
by jahboater
that is really funny - except apt-get update and upgrade I never made changes to my Jessie, nonetheless both for-loops work without setting a std=-Cxx flag.
gcc is 4.9 .
Unless there is some kind of default setting in your IDE?
Posted: Fri Sep 29, 2017 4:15 pm
by Martin Frezman
*WHICH* documentation? Which OS/version-of-gcc did you get that from?
Posted: Fri Sep 29, 2017 4:16 pm
by jahboater
Sorry, "man gcc"
Raspbian stretch / the default compiler (gcc 6.3)
Posted: Fri Sep 29, 2017 4:18 pm
by Stiller
I am compiling with g++ , not gcc
can perhaps that be the reason why?
Posted: Fri Sep 29, 2017 4:19 pm
by Martin Frezman
Well, yes. As in "NOW you tell us???"
This feature has been in C++ since forever. It was gradually back-fitted into C.
Posted: Fri Sep 29, 2017 4:22 pm
by Stiller
well, ok, I'm a beginner to C, I didn't know there is a difference between gcc and g++ compiler calls in this respect :mrgreen:
