profro
List files in directory
Tue Apr 11, 2017 7:18 pm
I am trying to list files in a directory and I keep getting "." and ".." in my list. What are these? I have tried to ignore then by doing a strcmp but they keep getting in my list.
#include <stdio.h>
#include <dirent.h>
int main(void)
        char bad_1[1] = ".";
        char bad_2[2] = "..";
        char list_array[20][255];
        int i = 0;
        int j;
        DIR     *d;
        struct dirent *dir;
        d = opendir("/home/pi/Documents/C\040Projects/arrays/Metrology_Data/");
        if (d)
                while ((dir = readdir(d)) != NULL)
                        if (strcmp(dir->d_name,bad_1) == 0)
                                //do nothing
                        if (strcmp(dir->d_name,bad_2) == 0)
                                //do nothing
                        else
                                strcpy(list_array[i], dir->d_name);
                                printf("%s\n", list_array[i]);
                        }       i++;
                closedir(d);
        else
                printf("Open error\n");
        printf("size of array %d\n", i);
        return(0);
Re: List files in directory
Tue Apr 11, 2017 7:23 pm
The first of those "." is the entry for the directory itself. That's why you often use "./something" in the shell to execute commands in the current directory.
The second ".." is a link to the parent directory. ("cd .." in the shell will take you up one directory level.)
Every directory has these entries except for / which only has . as it has no parent.
They won't normally show, as entries that begin with a "." are classed as hidden. For example, from the command line you would be able to see them with "ls -a"
pi@raspi9:~ $ ls
rpi_ws281x
pi@raspi9:~ $ ls -a
.  ..  .bash_history  .bash_logout  .bashrc  .profile  rpi_ws281x  .ssh
profro
Tue Apr 11, 2017 7:46 pm
How would I best ignore them while trying to get a list of the files in a directory?
jahboater
Tue Apr 11, 2017 8:27 pm
profro wrote:How would I best ignore them while trying to get a list of the files in a directory?
You probably want "else if" for the second test.
Or something quick and dirty like:
if( dir->d_name[0] == '.' )
   continue;
will ignore all "hidden" files.
profro
Wed Apr 12, 2017 12:39 pm
Brilliant! Worked perfectly.
If I may ask, why [0] on the d_name? and why '.' versus "."?
Paeryn
Wed Apr 12, 2017 12:43 pm
profro wrote:Brilliant! Worked perfectly.
Because it is just checking ​if the first character of the string is a fullstop.
profro
Wed Apr 12, 2017 1:49 pm
So it in effect will filter all names that a "." in the first index of the string? Which catches both "." and ".."
Nice. Thanks again.
Martin Frezman
Wed Apr 12, 2017 1:55 pm
profro wrote:So it in effect will filter all names that a "." in the first index of the string? Which catches both "." and ".."
Nice. Thanks again.
Note that it also "catches" every other filename that starts with a dot, e.g., .bashrc, .profile, etc
These are the so-called "hidden" files, and, in theory, you may want to be skipping (ignoring) them, but experience tends to show that these are, in fact, the files, you care the most about. I.e., TPTB hides them from you for just that reason.
If this post appears in the wrong forums category, my apologies.
PeterO
Wed Apr 12, 2017 4:45 pm
Martin Frezman wrote: These are the so-called "hidden" files, and, in theory, you may want to be skipping (ignoring) them, but experience tends to show that these are, in fact, the files, you care the most about. I.e., TPTB hides them from you for just that reason.
Kindly leave your silly conspiracy theories at the door. There is no place here for them.
PeterO
SteveSpencer
Thu Apr 13, 2017 1:31 pm
rpdom wrote: Every directory has these entries except for / which only has . as it has no parent.
At the risk of seeming picky,
ls -la /
does show both . and .. although I would hope that they are both links to the same thing :)
Also,
These are well named. The sizing element in the array should be left blank, so the compiler can work out how much space to allocate. Technically, the "string" should be terminated by a NUL character (a zero value), and a character array that isn't, would, most likely, not be handled correctly by the string(3) library routines.
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
Thu Apr 13, 2017 1:37 pm
Nice. Thanks again.
So thoroughly hidden that the only way you can see them is by using the utterly obscure command
ls -a
/sarcasm off
Return to “C/C++”
