syedatta94
serial communication raspberry pi in C
Sun Jul 03, 2016 11:31 am
need help!!! I want to send data from arduino to raspberry pi, i want a c code which recieves the data from arduino and save it in an integer variable, please anybody can provide me with the code?? i have tried 2 or three codes from the internet but that doesn't work.
edo1
Re: serial communication raspberry pi in C
Sun Jul 03, 2016 10:03 pm
there is nothing raspberry-specific (except serial port name)
joan
Sun Jul 03, 2016 10:10 pm
Explain how you have connected the Arduino to the Pi.
Show us your Arduino code.
Show us your Pi code.
Tell us what doesn't work.
AndyNC
Sat Jul 09, 2016 8:00 am
From first principles and not giving complete code, one way to progress is:
list the serial devices
ls /dev/tty*
You should get something like
ls /dev/tty*
/dev/tty    /dev/tty16  /dev/tty24  /dev/tty32  /dev/tty40  /dev/tty49  /dev/tty57  /dev/tty8
/dev/tty0   /dev/tty17  /dev/tty25  /dev/tty33  /dev/tty41  /dev/tty5   /dev/tty58  /dev/tty9
/dev/tty1   /dev/tty18  /dev/tty26  /dev/tty34  /dev/tty42  /dev/tty50  /dev/tty59  /dev/ttyprintk
/dev/tty10  /dev/tty19  /dev/tty27  /dev/tty35  /dev/tty43  /dev/tty51  /dev/tty6   /dev/ttyUSB0
/dev/tty11  /dev/tty2   /dev/tty28  /dev/tty36  /dev/tty44  /dev/tty52  /dev/tty60
/dev/tty12  /dev/tty20  /dev/tty29  /dev/tty37  /dev/tty45  /dev/tty53  /dev/tty61
/dev/tty13  /dev/tty21  /dev/tty3   /dev/tty38  /dev/tty46  /dev/tty54  /dev/tty62
/dev/tty14  /dev/tty22  /dev/tty30  /dev/tty39  /dev/tty47  /dev/tty55  /dev/tty63
/dev/tty15  /dev/tty23  /dev/tty31  /dev/tty4   /dev/tty48  /dev/tty56  /dev/tty7
Choose the device you want.eg /dev/ttyUSB0
if its a USB serial converter. This is the name of MODEMDEVICE device in the following code:
#include <termios.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/types.h>
#include <stdint.h>
#include <fcntl.h>
#include <sys/signal.h>
#include <time.h>
#include <stdbool.h>
#include <stropts.h>
#include <poll.h>
#include <errno.h>
#define BAUDRATE B19200
#define MODEMDEVICE "/dev/ttyAMA0"
int set_interface_attribs (int fd, int speed, int parity)
        struct termios tty;
        memset (&tty, 0, sizeof tty);
        if (tcgetattr (fd, &tty) != 0)
                printf ("error %d from tcgetattr", errno);
                return -1;
        cfsetospeed (&tty, speed);
        cfsetispeed (&tty, speed);
        tty.c_cflag = (tty.c_cflag & ~CSIZE) | CS8;     // 8-bit chars
        // disable IGNBRK for mismatched speed tests; otherwise receive break
        // as \000 chars
        tty.c_iflag &= ~IGNBRK;         // disable break processing
        tty.c_lflag = 0;                // no signaling chars, no echo,
                                        // no canonical processing
        tty.c_oflag = 0;                // no remapping, no delays
        tty.c_cc[VMIN]  = 0;            // read doesn't block
        tty.c_cc[VTIME] = 5;            // 0.5 seconds read timeout
        tty.c_iflag &= ~(IXON | IXOFF | IXANY); // shut off xon/xoff ctrl
        tty.c_cflag |= (CLOCAL | CREAD);// ignore modem controls,
                                        // enable reading
        tty.c_cflag &= ~(PARENB | PARODD);      // shut off parity
        tty.c_cflag |= parity;
        tty.c_cflag &= ~CSTOPB;
        tty.c_cflag &= ~CRTSCTS;
        if (tcsetattr (fd, TCSANOW, &tty) != 0)
                return -1;
        return 0;
void set_blocking (int fd, int should_block)
        struct termios tty;
                printf("error %d from tggetattr", errno);
                return;
        tty.c_cc[VMIN]  = should_block ? 1 : 0;
                printf("error %d setting term attributes", errno);
int main(void)
	int fd;
    char buf[255];
	int variable;
	struct pollfd fds[1];
	int ret, res;
	/* open the device */
	fd = open(MODEMDEVICE, O_RDWR | O_NOCTTY | O_NONBLOCK);
	if (fd == 0)
		perror(MODEMDEVICE);
		printf("Failed to open MODEMDEVICE \"/dev/ttyAMA0\"\n");
		exit(-1);
	set_interface_attribs (fd, BAUDRATE, 0);  // set speed to 19200 bps, 8n1 (no parity)
	set_blocking (fd, 0);                // set no blocking
	/* Open STREAMS device. */
	fds[0].fd = fd;
	fds[0].events = POLLRDNORM;
	for (;;)		// forever
		ret = poll(fds, 1, 1000);		//wait for response
		if (ret > 0)
			/* An event on one of the fds has occurred. */
			if (fds[0].revents & POLLHUP)
				printf("Hangup\n");
			if (fds[0].revents & POLLRDNORM)
					res = read(fd,buf,255);
					buf[res]=0;		// terminate buffer
					sscanf(buf,"%d\n",&variable);
					printf("Received %d\n",variable);
Compile with
cc -c serialiopoll.c
cc  -o serialiopoll  serialiopoll.o
All the above I gleaned from the web and I'm thank full for their contribution.
This is a stripped down version of some code I use to receive asynchronous data from an RF receiver. I assume this is the way you will receive it from the Arduino.
It does compile and probably work but I've not tested it. There are a lot of header files, These are left over from the original program and I can't remember exactly which ones are required.
The points you need to pay attention to are
1) in linux the serial device is a file
2) the poll() function waits for data on the serial line and returns with fds[0].revents -> POLLRDNORM
3) res = read(fd,buf,255); reads up to 255 chars from the serial buffer
4) sscanf(buf,"%d\n",&variable); scans the string buf and converts the data to integer and places it in variable.
5) The functions set_blocking() and set_interface_attribs() were gleaned from the web.
As joan has explained you haven't given us much to go on so this post may not fit your application but is is one way forward and give one way of handling serial IO.
HIH
Andy
Romonga
Mon Jul 11, 2016 4:42 pm
The easiest class I have found to use is part of the wiringPi library. https://github.com/WiringPi/WiringPi/bl ... ngSerial.h
It takes care of the low level details. I use this lib to talk to any serial device.
You can run, but you will only die tired.
gordon@drogon.net
Fri Jul 15, 2016 6:27 am
Romonga wrote:The easiest class I have found to use is part of the wiringPi library. https://github.com/WiringPi/WiringPi/bl ... ngSerial.h
Just FYI: wiringPi is maintained at http://wiringpi.com/
The github site is not mine and may not be up to date.
-Gordon
Gordons projects: https://projects.drogon.net/
John Public
Sat Aug 20, 2016 12:53 pm
I have an addition question to OP.
I tested the code shown in this forum post with an USB input device connected to an RPi3. Works fine when I use open("/dev/ttyACM0"..) etc..
I'd like to send and receive data from an old Nokia Symbian mobile phone I have connected to another USB port.
The Linux command:
ls /dev/tty*
It shows many USB devices. How do I find out which is connected to my mobile phone? Do I open all in sequence and try sending AT command and see if I get a response? Or what?
topguy
Sat Aug 20, 2016 9:00 pm
Is your phone the only usb device connected ?
A good way to figure out which devices are creater for a specific device is to plug it in after boot and look at the last lines of the output of the "dmesg" command after that.
Some GSM modems ( which are mobiles phones in a way ) create multiple serialports and the simplest is to test with a terminal program like minicom or similar.
I always try "at" and "ate1v1" commands first. ( "ate1v1" turns on "echo" and "answers" )
John Public
Sun Aug 21, 2016 8:51 am
My Rpi has multiple USB devices (keyboard, camera etc.).
I am designing a program (C) that should know when the phene is connected and what is the handle I can use to send sms messages.
gordon@drogon.net
Mon Aug 22, 2016 9:10 pm
John Public wrote:I have an addition question to OP.
The Linux command:
ls /dev/tty*
ls /dev/serial
after you plug something in.
-Gordon
DavidS
Tue Aug 23, 2016 9:54 pm
syedatta94 wrote:need help!!! I want to send data from arduino to raspberry pi, i want a c code which recieves the data from arduino and save it in an integer variable, please anybody can provide me with the code?? i have tried 2 or three codes from the internet but that doesn't work.
You did not say on what OS?
I would assume Bare Metal (no OS at all), based on your description of what you wish to do.
In case of RISC OS
I can not help you in C, though in assembly I could.
In the case of a n*x (Linux, BSD, etc), read form and write to the serial device.
3lev3n
Fri Oct 12, 2018 8:08 am
If I wan't to send a string from COM 3 on PC to USB0 on raspbian ? How to ?
AndyNC
Fri Oct 12, 2018 11:35 am
There is a load of info on the web.
A quick Google brings
https://www.cmrr.umn.edu/~strupp/serial.html
Have a read. There are many snippets there and probably many other places.
Cheers
Andy
Return to “C/C++”
