Page 1 of 2
reading 2x MCP23017: how long for reading 32 bits?
Posted: Mon Feb 29, 2016 4:01 pm
by davenull
hey,
how long will 2x MCP23017 readings last (min, max) to read or write all 2x16 =32 bits (2x2=4 bytes) via i2c repeatedly (endless loop, given only these 2 devices on that i2c bus) ?
Re: reading 2x MCP23017: how long for reading 32 bits?
Posted: Mon Feb 29, 2016 6:38 pm
by gordon@drogon.net
davenull wrote:hey,
It depends on how you write them... wiringPi writes one bit at a time, but if you directly access the registers, then it's 3 bytes over the I2C bus per 8-bit write - or 30 bits. So 30 bits at 100Kbits/sec is 0.3mS - so to write to 16-bits is 0.6mS, so 1.2mS for double that (2 devices) - given ideal conditions.
This: https://www.youtube.com/watch?v=g5cSvVGCX_A uses 2 x mcp23017's to drive 128 LEDs multiplexed, one LED at a time using wiringPi's digitalWrite() function. Not the most efficient, but usable.
-Gordon
Posted: Mon Feb 29, 2016 6:51 pm
by davenull
thank you Gordon!
can you please give me a hint for (edit) reading and writing bytes to registers?
In Arduino Wiring Sketch it's
  Wire.beginTransmission(addr);
  Wire.write(databyte);
  Wire.endTransmission();
(not knowing by heart now how to address the write register for devices).
How would it look like for Raspi to do something like
i2cwrite(int devaddr, int regaddr, int ndatabytes, char *data)
i2cread(int devaddr, int regaddr, int ndatabytes, char *data)
? (edited)
and 2nd question:
would it be possible to drive the bus at 400kb/s for the MCPs?
Posted: Mon Feb 29, 2016 6:58 pm
davenull wrote:thank you Gordon!
can you please give me a hint for writing bytes to registers?
You read my source code for mcp23017.c in wiringPi ...
The code there is:
    wiringPiI2CWriteReg8 (node->fd, MCP23x17_GPIOA, old) ;
where node->fd is the fd returned from wiringPiI2CSetup() and 'old' here is the value you're writing. Get the register definitions from the header file mcp23x0817.h.
I plan on expanding the digitalWriteByte & digitalReadByte calls soon, but that'll break binary compatibility, so not sure what to do about that one. (just need re-linking)
-Gordon
Posted: Mon Feb 29, 2016 7:08 pm
by davenull
yes, I read your code... (http://wiringpi.com/extensions/i2c-mcp23008-mcp23017/) :
 * q2w.c:
 *      Using the Quick 2 wire board for its mcp23017
 * Copyright (c) 2012-2013 Gordon Henderson. <projects@drogon.net>
#include <stdio.h>
#include <wiringPi.h>
#include <mcp23017.h>
int main (void)
  int i, bit ;
  wiringPiSetup () ;
  mcp23017Setup (100, 0x20) ;
  printf ("Raspberry Pi - MCP23017 Test\n") ;
  for (i = 0 ; i < 10 ; ++i)
    pinMode (100 + i, OUTPUT) ;
  pinMode         (100 + 15, INPUT) ;
  pullUpDnControl (100 + 15, PUD_UP) ;
  for (;;)
    for (i = 0 ; i < 1024 ; ++i)
      for (bit = 0 ; bit < 10 ; ++bit)
        digitalWrite (100 + bit, i & (1 << bit)) ;
      delay (5) ;
      while (digitalRead (100 + 15) == 0)
        delay (1) ;
  return 0 ;
but I must admit: I don't understand how to read/write a byte at a certain MCP23017 dev addr and reg address containing a bit pattern... :oops:
moreover, there is a different initialization:
   wiringPiSetup () ;
and no node->fd which is the fd returned from wiringPiI2CSetup()
I know how to set or read single bits in a byte, I just want to know how to address the reg to read or write to it...
OTOH, that would be very easy to use instead:
i2cwrite(char * i2cport, int devaddr, int regaddr, int ndatabytes, char *data)
i2cread(char * i2cport, int devaddr, int regaddr, int ndatabytes, char *data)
Posted: Mon Feb 29, 2016 8:14 pm
davenull wrote:yes, I read your code... (http://wiringpi.com/extensions/i2c-mcp23008-mcp23017/) :
Not that code.
~/wiringPi/wiringPi/mcp23017.c
You can use my code to get the basic setup done, then get the fd with:
struct wiringPiNodeStruct *node ;
node = wiringPiFindNode (100) ;
fd = node->fd ;
Then you can write to GPIO portA on that device (with a pin base of 100 inside wiringPi) with
  wiringPiI2CWriteReg8 (fd, MCP23x17_GPIOA, data) ;
You need to do the same for the 2nd mcp23017 you have.
-Gordon
Posted: Mon Feb 29, 2016 8:17 pm
by davenull
sorry, I don't find the ressource link, and I am obviously too dump fo this extremely sophisticated i2c protocol
I really can't understand and handle that :oops:
(Arduino wiring Sketch programming level ist the upper most level for my programming skills :oops: )
Posted: Mon Feb 29, 2016 8:30 pm
davenull wrote:sorry, I don't find the ressource link, and I am obviously too dump fo this extremely sophisticated i2c protocol
You need to get the wiringPi source:
cd ; git clone git://git.drogon.net/wiringPi
-Gordon
Posted: Mon Feb 29, 2016 8:41 pm
by davenull
I have that already!
for a cmps11 I am already using this:
int cmps11 = wiringPiI2CSetupInterface("/dev/i2c-1", 0x60);
     unsigned char  angle8;
     signed char    pitch, roll;
     angle8    = wiringPiI2CReadReg8 (cmps11, 1 ) ;
     pitch     = wiringPiI2CReadReg8 (cmps11, 4 ) ;
     roll      = wiringPiI2CReadReg8 (cmps11, 5 ) ;
I assumed I could do it that way for a mcp23017:
int mcp23017_0= wiringPiI2CSetupInterface("/dev/i2c-1", 0x20);
     uint8_t readbyte0, writebyte0, readbyte1, writebyte1;
     readbyte0  = wiringPiI2CReadReg8 (mcp23017_0, 0x12) ;   // bank A
edit: how to write a byte to a register?
wiringPiI2CWriteReg8 (mcp23017_0, 0x12, databyte) ; // bank A
Posted: Mon Feb 29, 2016 10:36 pm
by davenull
ps,
just found an Arduino Wiring Sketch ressource for
i2cwrite(byte devaddr, int regaddr, byte ndatabytes, char *data)
bool i2cwrite(byte devaddr, int regaddr, byte ndatabytes, char *data){
   Wire.beginTransmission(devaddr);
   Wire.write(HIGH(regaddr)); // this assumes the device expects MSB,LSB
   Wire.write(LOW(regaddr));
   if(ndatabytes>29) ndatabytes=29; // Wire's internal transmit buffer is 32 bytes
   for(byte i=0;i<ndatabytes;i++){
       Wire.write(data[i]);
   return (Wire.endTransmission(true)==0);
and for the MCP23017 especially
 // ref.: Nick Gammon,  http://www.gammon.com.au/forum/?id=10940
// address dev and reg and set bank and mode, and read or write
Wire.beginTransmission (0x20);  // expander has I2C address 0x20
Wire.send (0x00);   // register 0 is the I/O direction register for Port A ("B" == 0x01)
Wire.send (0x00);   //  0x00 for all pins to output mode, 0xFF for all pins to input mode
Wire.endTransmission ();
// (write)
Wire.send (0x12);   // register 0x12 is the I/O port "A" ("B" == 0x13)
Wire.send (0x56);   //  what to put on that port
// (read)
Wire.requestFrom (0x20, (byte) 1);
byte data = Wire.receive ();
Posted: Tue Mar 01, 2016 10:23 pm
by davenull
now from Nick Gammon's Arduino MCP23017 code the basic logic is a little bit more clear to me:
get device handle:
read 1 byte from register 0x12:
unsigned char data  = wiringPiI2CReadReg8 (mcp23017_0, 0x12) ;   // read bank A data register (0x12)
unsigned char data  = wiringPiI2CReadReg8 (mcp23017_0, 0x13) ;   // read bank B data register (0x13)
but which command is the right one to write to a register?
1st, to set bank A or B to input or output: write 0x00 or 0xff to register 0x00 (A) or register 0x01 (B) ?
wiringPiI2CWriteReg8 (mcp23017_0, 0x00, 0x00) ;  bank A:= output?
wiringPiI2CWriteReg8 (mcp23017_0, 0x00, 0xff) ;  bank A:= input?
wiringPiI2CWriteReg8 (mcp23017_0, 0x01, 0x00) ;  bank B:= output?
wiringPiI2CWriteReg8 (mcp23017_0, 0x01, 0xff) ;  bank B:= input?
2nd, to write a certain data byte to register 0x12 (A) or 0x13 (B) ?
wiringPiI2CWriteReg8 (mcp23017_0, data, 0x12 ; write data to bank A?
wiringPiI2CWriteReg8 (mcp23017_0, data, 0x13 ; write data to bank B?
I'm still not sure about that... :-/
Posted: Wed Mar 02, 2016 7:00 am
The code is all written for you - I typed some in in my last post and the sources to wiringPi are all online with many examples of using mcp23017's.
I suggest you read the data sheets too. I also suggest you use my header file (or someone elses) that has all the register definitions in it to save guessing register numbers.
All you need will be in ~/wiringPi/wiringPi/mcp23017.c if you get the wiringPi source.
-Gordon
Posted: Wed Mar 02, 2016 7:46 am
by davenull
yes, thank you for your advice!
I already found your MCP23017 ressource, and I also saw what you wrote above -
my issue is: to understand, how writing and reading from / to device registers work with your wiringPi API in general to be capable to use either i2c device in future.
about what you wrote above
I don't understand at all because I have no clue what node->fd means ( looks weird....: a pointer? or a class?),
and instead of wiringPiI2CSetup() I want to use
because of the additional "/dev/i2c-0" option, but this also will return a i2c device handle, won't it?
Of course I will use then later
#define MCP23017_0_addr 0x20
for the first MCP device if the code will work.
Data sheets are an abomination to me (they are obviously written by technicians for technicians, not for hobby programming noobs),
but if I understood the logic of the device and the logic of your wiringPi API functions correctly, the following code should work (please CMIIW):
set bank A to output (read),
set bank B to input (write),
then read 1 byte from A ,
then write 1 byte to B:
uint8_t data;
int mcp23017_0= wiringPiI2CSetupInterface("/dev/i2c-1", MCP23017_0_addr);
wiringPiI2CWriteReg8 (mcp23017_0, 0x00, 0x00) ;  // bank A:= output (read)
wiringPiI2CWriteReg8 (mcp23017_0, 0x01, 0xff) ;  // bank B:= input (write)
wiringPiI2CWriteReg8 (mcp23017_0, data, 0x13);   // write data to bank B (0x13)
Am I right or wrong?
(hell, how confusing! - but I MUST understand that!)
Posted: Wed Mar 02, 2016 10:55 am
davenull wrote: Am I right or wrong?
I think you might want to stop and learn some more C before you do much more ... (sorry. but it has to be done!)
-Gordon
Posted: Wed Mar 02, 2016 11:03 am
by davenull
I'm learning by doing.
(BTW, that's why I loved to have Wiring for Raspi like I have it for Arduino Sketch, suitable for beginners:
it took me 1 day to write my first C programs for Arduino, but meanwhile I struggling 6 months for writing C programs for Raspi!)
but what is faulty now in my code?
uint8_t data;
Posted: Wed Mar 02, 2016 11:27 am
davenull wrote:I'm learning by doing.
uint8_t data;
Assuming your register assignments are correct then it doesn't look too bad - what doesn't happen?
Always a good idea to check return codes from functions that return error codes though - make sure the fd (mcp23017_0 in your case) is >= 0.
-Gordon
Posted: Wed Mar 02, 2016 11:44 am
by davenull
I have no MCP23017 yet, but I will order 2 of 'em, and I will have to be sure that I'll be capable of using the right code to control it once I've finally got it.
Although my Arduino Due works.... but it's interface is too slow for 8x encoder motor control :-/
3 PCF8591 will be the next challenge then, at the 2nd i2c bus.
Posted: Wed Mar 02, 2016 11:53 am
davenull wrote:I have no MCP23017 yet, but I will order 2 of 'em, and I will have to be sure that I'll be capable of using the right code to control it once I've finally got it.
when you do get it, before writing a single line of code, you can test it -
gpio -xmcp23017:100:0x20 mode 100 out
gpio -xmcp23017:100:0x20 write 100 1
that will set the first bit of port A high - connect an LED to check or use a multimeter.
The gpio command can't use the "other" I2C bus (but programs can). Not sure why you want to, however I'm sure you have your reasons.
-Gordon
Posted: Wed Mar 02, 2016 1:23 pm
by davenull
yes, sure, thanks, I will do so!
what exactly do these 2 lines test? Just if it's defective or not?
and which wires do I have to plug to the mcp chip for this test?
just +5V(9), GND(10), SCL(12), SDA(13),
and pin21( line A) -> LED 470Ohm -> GND ?
Posted: Wed Mar 02, 2016 1:48 pm
by Massi
why don't you read the datasheet of the chip? (as suggested above)
in the datasheet it's clearly stated what you need to connect to have the chip working reliably
Sometimes (not always, in your case would be enough SOME TIME) you can try to do some homework instead of waiting for prepared bread from others.
Obviously wrong connections to mcp23017 chips have been discussed a lot of times on the forum.
Posted: Wed Mar 02, 2016 2:02 pm
davenull wrote:yes, sure, thanks, I will do so!
They don't test anything really - more confidence to make sure its wired up correctly. I see too many people diving into code after connecting hardware without even doing basic tests that I get fed-up replying to their email... Just saving you some bother.
You need to read the fine manual, however I'd start off with using the 3.3v power from the Pi rather than the 5v supply.
Read the manual/datasheet to find out what to do with the A0, A1 and A2 pins. Also the reset pin. The picture here:
http://wiringpi.com/examples/testing-wiringpi-v2/
might give you some hints too if you study it closely. (although its not that high resolution, but still might be handy)
-Gordon
Posted: Wed Mar 02, 2016 4:07 pm
by davenull
I see too many people diving into code after connecting hardware without even doing basic tests that I get fed-up replying to their email... Just saving you some bother....however I'd start off with using the 3.3v power from the Pi rather than the 5v supply.
yap ! 8-)
Posted: Tue Mar 08, 2016 6:25 am
by Sonny_Jim
Just curious, why the recommendation to run the mcp23017 at 3.3v rather than 5v? I run mine at 5V with seemingly no problems.
Posted: Tue Mar 08, 2016 7:04 am
Sonny_Jim wrote:Just curious, why the recommendation to run the mcp23017 at 3.3v rather than 5v? I run mine at 5V with seemingly no problems.
Less chance of doing something silly and blowing up a Pi...
-Gordon
Posted: Tue Mar 08, 2016 8:50 am
by joan
A lot of people do. Strictly speaking it is not guaranteed to work. The spec says SCL/SDA need to be at least 0.8 VDD (4V) to be seen as logic high The Pi's I2C bus operates at 3V3. The same applies applies to the SPI version.
