Vanfanel
Cross compiling a simple program that uses an installed lib
Tue Oct 13, 2015 12:53 pm
Hi there,
I'm having seemingly unsolvable problems while trying to cross compile a simple Rpi program on my X86 box. It was working before but I've since rebuilt my system and now I can't make it work anymore.
I am using a cross-compiler I built using crosstool-ng. It lives on ~/x-tools/arm-rpi-linux-gnueabi, I have added the executables to the PATH and it has it's own sysroot on ~/x-tools/arm-rpi-linux-gnueabi/arm-rpi-linux-gnueabi/sysroot. It works in general for generating simple binaries that work on the Pi.
I also have copied over /usr /lib and /opt from the Raspberry Pi's Raspbian SD card to /opt/rpi_root, so I have another sysroot living there in /opt/rpi_root, which has the libraries installed in Raspbian.
Crosscompiling a simple program with no libs or references to the Raspbian sysroot works well:
arm-rpi-linux-gnueabi-gcc hello.c
and the resulting binary works on the Pi.
The problems start when I try to link against libs installed in Raspbian:
manuel@vader:~/src/picross$ arm-rpi-linux-gnueabi-gcc hello.c -lSDL
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: cannot find -lSDL
collect2: error: ld returned 1 exit status
Obviously it's looking for a library that is installed in Raspbian, so I do:
manuel@vader:~/src/picross$ find /opt/rpi_root -name 'libSDL.so'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so
Ok, found it. So I try:
manuel@vader:~/src/picross$ arm-rpi-linux-gnueabi-gcc hello.c -lSDL -L/opt/rpi_root/usr/lib/arm-linux-gnueabihf
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: cannot find /lib/arm-linux-gnueabihf/libc.so.6
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: cannot find /usr/lib/arm-linux-gnueabihf/libc_nonshared.a
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: cannot find /lib/arm-linux-gnueabihf/ld-linux-armhf.so.3
Ok, so the problem is that libc.so in the crosscompiler sysroot has wrong paths for libc.so.6, libc_nonshared.a and ld-linux-armhf.so.3 because it's using absolute paths. Let's see what we have in /home/manuel/x-tools/arm-rpi-linux-gnueabi/arm-rpi-linux-gnueabi/sysroot/usr/lib/libc.so:
/* GNU ld script
   Use the shared library, but some functions are only in
   the static library, so try that secondarily.  */
OUTPUT_FORMAT(elf32-littlearm)
GROUP ( /lib/libc.so.6 /usr/lib/libc_nonshared.a  AS_NEEDED ( /lib/ld-linux.so.3 ) )
Bingo! So what are the alternatives? I could start editing the crosscompiler's sysroot ld scripts for every library, which is just crazy, or I could change my strategy and try passing the compiler a new sysroot so it ONLY takes ld scripts and libs from the Raspbian sysroot living in /opt/rpi_root:
manuel@vader:~/src/picross$ arm-rpi-linux-gnueabi-gcc hello.c --sysroot=/opt/rpi_root -lSDL
In file included from /opt/rpi_root/usr/include/stdio.h:28:0,
                 from hello.c:2:
/opt/rpi_root/usr/include/features.h:323:26: fatal error: bits/predefs.h: No such file or directory
compilation terminated.
Oh, we also need to tell the compiler where it has to look for certain includes:
manuel@vader:~/src/picross$ arm-rpi-linux-gnueabi-gcc hello.c --sysroot=/opt/rpi_root -lSDL -I/opt/rpi_root/usr/include/arm-linux-gnueabihf
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: cannot find crt1.o: No such file or directory
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: cannot find crti.o: No such file or directory
Well, around here I get confused and desperated. Cannot find -lSDL on the Raspbian sysroot living on /opt/rpi_root? Ok... it shouldn't happen, but ok:
manuel@vader:~/src/picross$ find /opt/rpi_root -name 'libSDL.so'/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so
manuel@vader:~/src/picross$ arm-rpi-linux-gnueabi-gcc hello.c --sysroot=/opt/rpi_root -lSDL -I/opt/rpi_root/usr/include/arm-linux-gnueabihf -L/opt/rpi_root/usr/lib/arm-linux-gnueabihf
Ok, ok, don't panic, let's try adding the -B parameter to pass the binary objects location it's looking for. It makes no sense and means --sysroot=/opt/rpi_root isn't working as intended.
manuel@vader:~/src/picross$ find /opt/rpi_root -name 'crt1.o'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/crt1.o
manuel@vader:~/src/picross$ arm-rpi-linux-gnueabi-gcc hello.c --sysroot=/opt/rpi_root -lSDL -I/opt/rpi_root/usr/include/arm-linux-gnueabihf -L/opt/rpi_root/usr/lib/arm-linux-gnueabihf -B /opt/rpi_root/usr/lib/arm-linux-gnueabihf
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libasound.so.2, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libm.so.6, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libdl.so.2, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libpulse-simple.so.0, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libpulse.so.0, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libX11.so.6, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libXext.so.6, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libbcm_host.so, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libvcos.so, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libvchiq_arm.so, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libdirectfb-1.2.so.9, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libfusion-1.2.so.9, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libdirect-1.2.so.9, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libcaca.so.0, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libts-0.0.so.0, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/ld: warning: libpthread.so.0, needed by /opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so, not found (try using -rpath or -rpath-link)
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XAllocClassHint'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSendEvent'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XReparentWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XFlush'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pthread_mutexattr_init@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_stream_drain@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFreeModifiermap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetTransientForHint'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pow@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_stream_connect_playback@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_sizeof@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XESetEventToWire'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetIOErrorHandler'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XClearWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_display_get_info'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_resource_delete'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `__caca0_free_bitmap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_copy@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFreeColormap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XAllocColor'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_nonblock@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_set_access@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XResizeWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `log@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XLookupString'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetExtensionErrorHandler'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_rect_set'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_simple_new@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGetICValues'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XResetScreenSaver'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XESetWireToEvent'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XChangePointerControl'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_context_connect@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_sw_params_set_start_threshold@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_context_disconnect@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XEventsQueued'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XOpenIM'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XReply'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XPending'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_set_periods_near@ALSA_0.9.0rc4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `__caca0_create_bitmap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `ts_fd'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XListPixmapFormats'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_stream_new@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XIconifyWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XextFindDisplay'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_recover@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_set_period_size_near@ALSA_0.9.0rc4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_element_add'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreatePixmapFromBitmapData'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `DirectFBErrorString'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFreeColors'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `DirectFBCreate'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `ts_config'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFree'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XSend'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XextRemoveDisplay'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XMoveWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `caca_refresh_display'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XDeleteProperty'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XMoveResizeWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `caca_get_canvas_height'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pthread_create@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_any@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFreePixmap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XShmQueryExtension'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `__caca0_end'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `sem_getvalue@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetWMHints'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XPeekEvent'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGetVisualInfo'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XChangeWindowAttributes'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetWMNormalHints'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGrabPointer'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_set_format@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XDestroyIC'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_sw_params@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreatePixmapCursor'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XWarpPointer'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XextDestroyExtension'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_resource_create'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_sw_params_set_avail_min@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_set_channels@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_operation_cancel@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `dlsym@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `Xutf8TextListToTextProperty'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_close@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_get_periods@ALSA_0.9.0rc4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_get_channels@ALSA_0.9.0rc4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `__caca0_get_event'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XDestroyWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_element_change_source'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_stream_write@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGetErrorDatabaseText'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XShmPutImage'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `__caca0_dp'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_context_unref@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreateIC'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XVisualIDFromVisual'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `caca_dither_bitmap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_set_rate_near@ALSA_0.9.0rc4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XOpenDisplay'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pthread_cancel@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_operation_unref@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_operation_get_state@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XStringListToTextProperty'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGetModifierMapping'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_stream_writable_size@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `bcm_host_init'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XMissingExtension'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_mainloop_free@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetWMProtocols'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `sem_timedwait@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XQueryPointer'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XKeysymToKeycode'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XShmDetach'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XUngrabPointer'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `ts_read'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_mainloop_iterate@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCloseIM'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_set_buffer_size_near@ALSA_0.9.0rc4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XAllocSizeHints'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `sem_init@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetErrorHandler'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_element_remove'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XQueryExtension'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XGetRequest'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XAllocWMHints'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_stream_unref@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XQueryColors'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `sem_wait@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pthread_sigmask@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XNextEvent'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_stream_disconnect@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XMapRaised'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XInternAtom'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XQueryKeymap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_stream_get_state@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XChangeProperty'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XDisplayName'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetLocaleModifiers'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `__caca0_init'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_display_open'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreateWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XRefreshKeyboardMapping'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSync'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSelectInput'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetClassHint'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_context_get_state@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XRead'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_sw_params_current@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_update_start'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XDefineCursor'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_writei@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `ts_open'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreateGC'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XUnmapWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XUnsetICFocus'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreateSimpleWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_resource_set_palette'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XSetLastRequestRead'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_context_set_name@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XKeycodeToKeysym'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_get_buffer_size@ALSA_0.9.0rc4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_hw_params_get_period_size@ALSA_0.9.0rc4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `__caca0_cv'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFlush'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XextCreateExtension'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreateColormap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGetPointerControl'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGetWindowAttributes'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pthread_join@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetICFocus'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_simple_free@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `caca_get_canvas_width'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XPutImage'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XReadPad'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_mainloop_get_api@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XMatchVisualInfo'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetWindowColormap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetWindowBackgroundPixmap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCheckTypedEvent'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XEatData'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFreeCursor'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_sw_params_sizeof@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XMapWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_channel_map_init_auto@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `sem_destroy@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `Xutf8LookupString'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetWindowBackground'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_open@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XSetTextProperty'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFreeGC'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pthread_mutexattr_settype@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `_XFlushGCCache'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `DirectFBError'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XShmAttach'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `dlerror@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGetWMHints'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XextAddDisplay'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_strerror@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XShmCreateImage'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XUngrabKeyboard'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XFilterEvent'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `dlopen@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `ts_close'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_mainloop_new@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `sem_trywait@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XInstallColormap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XStoreColors'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XRaiseWindow'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCloseDisplay'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreateImage'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XCreatePixmap'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `snd_pcm_drain@ALSA_0.9'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_display_close'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `pa_context_new@PULSE_0'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `dlclose@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `DirectFBInit'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XDisplayOfIM'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XMaskEvent'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_update_submit_sync'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `vc_dispmanx_resource_write_data'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `sem_post@GLIBC_2.4'
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libSDL.so: undefined reference to `XGrabKeyboard'
After this I close my eyes, breathe deeply not to throw my laptop away across the closed window, and come here for help.
What am I doing wrong?? Passing --sysroot should DO it, the compiler and linker should find and use the ld scripts and libs and headers from /opt/sysroot, but according to
manuel@vader:~/src/picross$ arm-rpi-linux-gnueabi-gcc hello.c --sysroot=/opt/rpi_root -lSDL -I/opt/rpi_root/usr/include/arm-linux-gnueabihf -v
Using built-in specs.
COLLECT_GCC=arm-rpi-linux-gnueabi-gcc
COLLECT_LTO_WRAPPER=/home/manuel/x-tools/arm-rpi-linux-gnueabi/libexec/gcc/arm-rpi-linux-gnueabi/4.7.4/lto-wrapper
Target: arm-rpi-linux-gnueabi
Configured with: /home/manuel/cross-rasp/.build/src/gcc-linaro-4.7-2014.01/configure --build=x86_64-build_unknown-linux-gnu --host=x86_64-build_unknown-linux-gnu --target=arm-rpi-linux-gnueabi --prefix=/home/manuel/x-tools/arm-rpi-linux-gnueabi --with-sysroot=/home/manuel/x-tools/arm-rpi-linux-gnueabi/arm-rpi-linux-gnueabi/sysroot --enable-languages=c,c++ --with-arch=armv6zk --with-cpu=arm1176jzf-s --with-tune=arm1176jzf-s --with-fpu=vfp --with-float=hard --with-pkgversion='crosstool-NG 1.20.0' --enable-__cxa_atexit --disable-libmudflap --disable-libgomp --disable-libssp --disable-libquadmath --disable-libquadmath-support --with-gmp=/home/manuel/cross-rasp/.build/arm-rpi-linux-gnueabi/buildtools --with-mpfr=/home/manuel/cross-rasp/.build/arm-rpi-linux-gnueabi/buildtools --with-mpc=/home/manuel/cross-rasp/.build/arm-rpi-linux-gnueabi/buildtools --with-ppl=/home/manuel/cross-rasp/.build/arm-rpi-linux-gnueabi/buildtools --with-cloog=/home/manuel/cross-rasp/.build/arm-rpi-linux-gnueabi/buildtools --with-libelf=/home/manuel/cross-rasp/.build/arm-rpi-linux-gnueabi/buildtools --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm -L/home/manuel/cross-rasp/.build/arm-rpi-linux-gnueabi/buildtools/lib -lpwl' --enable-threads=posix --enable-target-optspace --disable-nls --disable-multilib --with-local-prefix=/home/manuel/x-tools/arm-rpi-linux-gnueabi/arm-rpi-linux-gnueabi/sysroot --enable-c99 --enable-long-long --with-float=hard
Thread model: posix
gcc version 4.7.4 20140107 (prerelease) (crosstool-NG 1.20.0)
COLLECT_GCC_OPTIONS='-I' '/opt/rpi_root/usr/include/arm-linux-gnueabihf' '-v' '-march=armv6zk' '-mtune=arm1176jzf-s' '-mfloat-abi=hard' '-mfpu=vfp' '-mtls-dialect=gnu'
 /home/manuel/x-tools/arm-rpi-linux-gnueabi/libexec/gcc/arm-rpi-linux-gnueabi/4.7.4/cc1 -quiet -v -I /opt/rpi_root/usr/include/arm-linux-gnueabihf -isysroot /opt/rpi_root hello.c -quiet -dumpbase hello.c -march=armv6zk -mtune=arm1176jzf-s -mfloat-abi=hard -mfpu=vfp -mtls-dialect=gnu -auxbase hello -version -o /tmp/ccBXrCwp.s
GNU C (crosstool-NG 1.20.0) version 4.7.4 20140107 (prerelease) (arm-rpi-linux-gnueabi)
	compiled by GNU C version 4.9.2, GMP version 5.1.3, MPFR version 3.1.2, MPC version 1.0.2
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring nonexistent directory "/opt/rpi_root/home/manuel/x-tools/arm-rpi-linux-gnueabi/arm-rpi-linux-gnueabi/sysroot/include"
#include "..." search starts here:
#include <...> search starts here:
 /home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/include
 /home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/include-fixed
 /home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/include
End of search list.
Compiler executable checksum: ef439bbfaf97ced736f40e5e67b965df
 /home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/as -v -I /opt/rpi_root/usr/include/arm-linux-gnueabihf -march=armv6zk -mfloat-abi=hard -mfpu=vfp -meabi=5 -o /tmp/cckIn07q.o /tmp/ccBXrCwp.s
GNU assembler version 2.24 (arm-rpi-linux-gnueabi) using BFD version (crosstool-NG 1.20.0) 2.24
COMPILER_PATH=/home/manuel/x-tools/arm-rpi-linux-gnueabi/libexec/gcc/arm-rpi-linux-gnueabi/4.7.4/:/home/manuel/x-tools/arm-rpi-linux-gnueabi/libexec/gcc/arm-rpi-linux-gnueabi/4.7.4/:/home/manuel/x-tools/arm-rpi-linux-gnueabi/libexec/gcc/arm-rpi-linux-gnueabi/:/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/:/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/:/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/bin/
LIBRARY_PATH=/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/:/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/lib/:/opt/rpi_root/lib/:/opt/rpi_root/usr/lib/
 /home/manuel/x-tools/arm-rpi-linux-gnueabi/libexec/gcc/arm-rpi-linux-gnueabi/4.7.4/collect2 --sysroot=/opt/rpi_root --eh-frame-hdr -dynamic-linker /lib/ld-linux-armhf.so.3 -X -m armelf_linux_eabi crt1.o crti.o /home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/crtbegin.o -L/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4 -L/home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/../../../../arm-rpi-linux-gnueabi/lib -L/opt/rpi_root/lib -L/opt/rpi_root/usr/lib /tmp/cckIn07q.o -lSDL -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /home/manuel/x-tools/arm-rpi-linux-gnueabi/lib/gcc/arm-rpi-linux-gnueabi/4.7.4/crtend.o crtn.o
it's using a mixture of both /opt/rpi_root sysroot and the ~/x-tools/arm-rpi-linux-gnueabi/arm-rpi-linux-gnueabi/sysroot sysroot.
Please help me here :oops:
Vanfanel
Re: Cross compiling a simple program that uses an installed
Tue Oct 13, 2015 5:43 pm
I managed to cross-compile by editing
/opt/rpi_root/usr/lib/arm-linux-gnueabihf/libc.so
and setting the paths to relative ones, leaving it like this:
/* GNU ld script
GROUP ( ../../../lib/arm-linux-gnueabihf/libc.so.6 ../../../usr/lib/arm-linux-gnueabihf/libc_nonshared.a  AS_NEEDED ( ../../../lib/arm-linux-gnueabihf/ld-linux-armhf.so.3 ) )
then I did:
manuel@vader:~/src/picross$ arm-rpi-linux-gnueabi-gcc hello.c -lSDL -L /opt/rpi_root/usr/lib/arm-linux-gnueabihf -I/opt/rpi_root/usr/include/arm-linux-gnueabihf -Xlinker -rpath-link=/opt/rpi_root/usr/lib/arm-linux-gnueabihf -Xlinker -rpath-link=/opt/rpi_root/lib/arm-linux-gnueabihf -Xlinker -rpath-link=/opt/rpi_root/opt/vc/lib -Xlinker -rpath-link=/opt/rpi_root/usr/lib/arm-linux-gnueabihf/pulseaudio
But this seems overkilling to me.
Isn't it possible to simply pass --sysroot instead to the linker and NOT havng to fiddle with .so editing on the Raspbian sysroot nor rpath-link parameters??
Vanfanel
Fri Oct 16, 2015 10:46 am
The sysroot parameter works right. That's not the problem of all this mess.
The root cause of all this is since Wheezy (on which Raspbian is/was based), Debian adds "multiarch". That means that LD scripts, headers and actual libs can be in the sysroot for different achitectures at the same time.
Old Raspbian (whatever I was using before) had all libs/includes/LD scripts under "standard" locations like /usr/lib, /lib, /usr/include... but now, some of them are under routes like /usr/lib/arm-linux-gnueabihf, /lib/arm-linux-gnueabihf, /usr/include/arm-linux-gnueabihf...
To make the crosscompiler look into the "arm-linux-gnueabihf" subdirs we should build it with the "--enable-multiarch --target=arm-linux-gnueabihf" options. That will also make linker look for the crt*.o files in <sysroot>/usr/lib/arm-linux-gnueabihf instead of <sysroot>/usr/lib.
BUT since there's no support for multiarch in crosstool-ng that I can see, there's no way to use it to build a crosscompiler for a modern Raspbian system that has multiarch.
The only option I am left with is manuallt putting whatever is needed from the arm-linux-gnueabihf subdirs to "standard" non-multiarch locations, fixing paths in .so LD scripts, etc... what a mess.
yasriady
Mon Oct 19, 2015 3:29 am
Dear there,
I use buildroot build system to generate my own toolchain. Shall you want to try, please use the way I'm followed: http://yasriady.blogspot.co.id/2015/10/ ... ry-pi.html. Buildroot is very nice because it can automate to build dependency library such X11, GTK, and other related. So, please make a try and good luck.
MyRaspberryPi : Cross Compile, wxWidgets/C++ and Linux Journal at http://yasriady.blogspot.com
vagrant4ever
Thu Apr 21, 2016 10:21 pm
I believe I am running into the same multiarch problem. I am porting an application that uses several libraries (bluetooth, log4cxx, etc) to the Rpi3 (Jessie, gcc 4.9.3). My host system is Ubuntu 14.04 (gcc 4.9.3)
I "rsync"ed /usr and /lib from my RPi3 to:
~/raspberrypi/rootfs
I am using this as my sysroot.
I downloaded the pre-built toolchains from:
git clone https://github.com/raspberrypi/tools
I first attempted to use this tool chain:
~/raspberrypi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin
This one supported multiarch:
./arm-linux-gnueabihf-gcc --print-multiarch
arm-linux-gnueabihf
However the compiler version is 4.8.3, and I received link errors:
/home/steve/raspberrypi/rootfs/usr/lib/arm-linux-gnueabihf/liblog4cxx.so: undefined reference to `std::__throw_out_of_range_fmt(char const*, ...)@GLIBCXX_3.4.20'
make: *** [MasterPi] Error 1
A google search turned up that libs may be compiled with different compiler versions.
I then tried this toolchain:
~/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin
This one does not support multiarch:
steve@steve-HP-EliteBook-8570w:~/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin$ ./arm-linux-gnueabihf-gcc --print-multiarch
And I receive the following link errors:
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find crt1.o: No such file or directory
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find crti.o: No such file or directory
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find -llog4cxx
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lpthread
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lbluetooth
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lglib-2.0
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lssl
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lcrypto
/home/steve/raspberrypi/tools/arm-bcm2708/arm-rpi-4.9.3-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.3/../../../../arm-linux-gnueabihf/bin/ld: cannot find -lm
I even tried to build a toolchain with crosstool-ng and still ran into linking issues. More research and it looks like crosstool-ng does not support multiarch....
Any help would be greatly appreciated! Surely there is a toolchain out there some where :oops:
davenull
Fri Apr 22, 2016 9:20 am
is there a special reason why you want to cross-compile and not just compile on the Pi itself, plugging a keyboard, a mouse, and a HDMI-Monitor (or a DVI Monitor plus a HDMI Adapter) ?
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
jahboater
Fri Apr 22, 2016 11:27 am
davenull wrote:is there a special reason why you want to cross-compile and not just compile on the Pi itself, plugging a keyboard, a mouse, and a HDMI-Monitor (or a DVI Monitor plus a HDMI Adapter) ?
Yes!
Have you tried a Pi3? Its pretty fast, and capable of building almost anything (such as the Linux kernel or GCC itself).
You can of course ssh into the Pi to build things.
"We are in the beginning of a mass extinction, and all you can talk
about is money and fairy tales of eternal economic growth."
- Greta Thunberg
vagrant4ever
Mon Apr 25, 2016 4:59 pm
Yes, that is an option. However I cross compile this code for multiple boards (intel Edison, etc) and I was hoping to find a toolchain that would allow me to do so for the Pi 3.
Return to “C/C++”
