mad-hatter
Qt4/C++ - QTextEdit subclass - can't show cursor
Sun Apr 05, 2015 12:04 pm
I'm subclassing a QTextEdit and I can't get the cursor to show.
Flow:-
From the button slot, I call a QDialog (propForm).
From the dialog, I call a subclassed QTextEdit (data/dataEdit).
No matter what I try, I can't get the cursor to show (visible).
The program compiles and runs OK, up to the point of a noshow cursor.
Could someone tell me what I haven't done.
Regards
void menu::textButton() // slot
    prop = new propForm(this);
    prop->setObjectName("prop" + QString::number(cm::formCount));
    prop->setFocus();
#ifndef PROPFORM_H
#define PROPFORM_H
#include <QDialog>
#include <QLabel>
#include "dataEdit.h"
class propForm : public QDialog
    Q_OBJECT
public:
    propForm(QWidget *parent = 0);
    dataEdit *data;
    QLabel *fileData;
protected slots:
    void focusInEvent(QFocusEvent *);
    void closeEvent(QCloseEvent *);
    void focusOutEvent(QFocusEvent *);
    bool eventFilter(QObject *, QEvent *);
#endif // PROPFORM_H
propForm::propForm(QWidget *parent) : QDialog(parent)
    this->resize(400, 300);
    this->setWindowTitle(cm::subItem);
    this->setStyleSheet(sty::style1);
    QString filePath = (cm::mainItem + "/" + cm::subItem);
    fileData = new QLabel(filePath, this);
    fileData->setGeometry(0, 0, this->width(), 25);
    fileData->setFrameStyle(QFrame::Panel | QFrame::Sunken);
    fileData->setAlignment(Qt::AlignHCenter | Qt::AlignBottom);
    data = new dataEdit(this);
    data->setObjectName("data" + QString::number(cm::formCount));
    data->setGeometry(0, fileData->height(), this->width(), this->height() - fileData->height());
    QFile file(filePath);
    if ( ! (file.open(QIODevice::ReadOnly))) {
        cr::message("Can't open file\nfor read.", "Error", 2);
        return;
    QTextStream in(&file);
    while ( ! in.atEnd()) data->append(in.readLine());
    file.close();
    this->show();
#ifndef DATAEDIT_H
#define DATAEDIT_H
#include <QTextEdit>
class dataEdit : public QTextEdit
    Q_OBJECT
public:
    dataEdit(QWidget *parent = 0);
    ~dataEdit();
protected slots:
    void showEvent(QShowEvent *);
    void resizeEvent(QResizeEvent *e);
private slots:
    void onTextChanged();
private:
    //QTextCursor *textCursor;
#endif // DATAEDIT_H
dataEdit::dataEdit(QWidget *parent) : QTextEdit(parent)
    qDebug() << "start1";
    this->activateWindow();
    this->setFocus();
    connect(this, SIGNAL(textChanged()), this, SLOT(onTextChanged()));
    qDebug() << "start2";
    this->setReadOnly(false);
    this->setEnabled(true);
    this->setLineWrapMode(NoWrap);
    QTextCursor textCursor(this->textCursor());
    textCursor.movePosition(QTextCursor::Start, QTextCursor::MoveAnchor, 1);
    textCursor.movePosition(QTextCursor::EndOfLine, QTextCursor::MoveAnchor, 1); //end of first line
    this->ensureCursorVisible();
    qDebug() << "end";
void dataEdit::showEvent(QShowEvent *e)
    qDebug() << "show1";
void dataEdit::focusInEvent(QFocusEvent *)
    qDebug() << "focusInEvent - " << this->objectName();
void dataEdit::onTextChanged()
    qDebug() << "text changed";
OUTPUT:
start1
start2
end
text changed [text changed
text changed (from
text changed (the data
text changed (loaded
text changed (at startup
show1
focusInEvent -  "data1"
Return to “C/C++”
