mad-hatter
QT4/C++ - Problem with QFileInfo
Thu Mar 05, 2015 11:49 am
I'm trying to understand QFileInfo.
The problem I've got is that an entry 'alsamixergui' that shows as a directory when I think it should be a .desktop file.
Its quite probable that I don't understand the 'linux' file system or I'm making a mistake.
Perhaps some one could take a look at the code and tell me where I've gone wrong.
Regards
private:
    QListWidget *subMenu;
    QStringList *fileList[19], *base;
    QDir         baseDir[19];
    QStringList base1;
    base1 << "/usr/local/share/applications"              // 0
          << "/usr/share/applications"                    // 1
          << "/home/pi/.local/share/applications";        // 2
    base = new QStringList();
    base->append(base1);
    baseDir[1].setFilter(QDir::AllDirs | QDir::Files | QDir::NoDotAndDotDot); //| QDir::NoSymLinks);
    baseDir[2].setFilter(QDir::AllDirs | QDir::Files | QDir::NoDotAndDotDot);
    baseDir[1] = base[1];
    baseDir[2] = base[2];
    fileList[1] = new QStringList();
    fileList[2] = new QStringList();
    fileList[1]->append(baseDir[1].entryList());
    fileList[2]->append(baseDir[2].entryList());
    //qDebug() << *fileList[1] << "\n";
    //qDebug() << *fileList[2] << "\n\n";
    QString file1;
    for (int i = 0; i < fileList[1]->count(); i++) {
        file1 = baseDir[1].path() + "/" + fileList[1]->at(i);
        QFileInfo checkFile(file1);
        fileType(checkFile, i);
    for (int i = 0; i < fileList[2]->count(); i++) {
        file1 = baseDir[2].path() + "/" + fileList[2]->at(i);
    subMenu->addItems(*fileList[1]);
    subMenu->addItems(*fileList[2]);
    subMenu->sortItems();
    fileTypeColour();
void menu::fileType(QFileInfo checkFile, int i)
    if (checkFile.isSymLink()) fileList[1]->replaceInStrings(fileList[1]->at(i), "Symlink - " +
                                                             fileList[1]->at(i) +
                                                             " - Target =  " +
                                                             checkFile.symLinkTarget());
    else if (checkFile.isDir()) fileList[1]->replaceInStrings(fileList[1]->at(i), "Directory - " +
                                                             fileList[1]->at(i));
void menu::fileTypeColour()
    for (int i = 0; i < subMenu->count(); i++) {
        if (subMenu->item(i)->text().startsWith("Symlink")) subMenu->item(i)->setForeground(*(new QBrush(Qt::darkCyan)));
        else if (subMenu->item(i)->text().startsWith("Directory")) subMenu->item(i)->setForeground(*(new QBrush(Qt::magenta)));
topguy
Re: QT4/C++ - Problem with QFileInfo
Thu Mar 05, 2015 5:17 pm
Some other relevant information would also be the result from "ls -al" in that directory.
mad-hatter
Thu Mar 05, 2015 9:24 pm
topguy wrote:Some other relevant information would also be the result from "ls -al" in that directory.
pi@mypi /usr/share/applications $ ls -al
total 576
drwxr-xr-x   3 root root  4096 Mar  1 10:08 .
drwxr-xr-x 289 root root 12288 Feb 28 16:19 ..
-rw-r--r--   1 root root   199 May  8  2012 alsamixergui.desktop
Thanks for the reply.
I'm afraid this doesn't mean to much to me, if I understand correctly its r/w by root and read only by anyone else.
Perhaps you can interpret the results.
Regards
topguy
Fri Mar 06, 2015 11:41 am
I thought it might be more files in that directory, but I saw later that you fetch files from more than one directory.
My only theory ( without fine-reading your code ) is that you also pick up "." and ".." when listing files and those will check out as directories.
mad-hatter
Fri Mar 06, 2015 12:06 pm
topguy wrote:I thought it might be more files in that directory
There are more files listed, I just showed the file of interest.
It shows directories, see the entry in the attachment for 'list.jpeg' for kde4.
The problem is that it is showing 'alsemixergui.desktop' as a directory when I think it should be a file.
Regards
mad-hatter
Sat Mar 07, 2015 8:34 pm
I've just tested the same source code on Debian Wheezy on my PC.
Works as it is supposed to.
Anybody have any ideas.
Regards
topguy
Tue Mar 10, 2015 11:41 am
I would have added some debug printout to "menu::fileType()" long time ago, thats where the error most likely will appear.
And if you look closer you will see that you always manipulate fileList[1] inside that function, but you are also using that function from the loop where you loop through the files in fileList[2], which is a completely different list of files.
mad-hatter
Tue Mar 10, 2015 1:41 pm
Hello topguy,
Thanks for your reply.
I realised there was something basically wrong with my method and got it working with some help from another forum.
http://www.qtcentre.org/threads/61821-Q ... -QFileInfo
Regards
    QStringList base1;
    fileList[1]->append(getList(QDir(base1.at(1))));
    fileList[1]->append(getList(QDir(base1.at(2))));
    fileList[1]->sort();
QStringList menu::getList(QDir dir)
    QStringList fileList;
    QFileInfoList fList = dir.entryInfoList(QDir::AllDirs | QDir::Files | QDir::NoDotAndDotDot);
    for (int i = 0; i < fList.size(); i++) {
        if (fList.at(i).isSymLink() || fList.at(i).isDir()) {
            if (fList.at(i).isDir()) fileList.append(fList.at(i).fileName() + " - Directory");
            else fileList.append(fList.at(i).fileName() + " - Symlink - Target = "
                                 + fList.at(i).symLinkTarget());
        } else fileList.append(fList.at(i).fileName());
    return (fileList);
Return to “C/C++”
