Can't get Python to run with Pygame
Posted: Sun Jul 01, 2012 11:04 am
by oobtim
:evil: Been very frustrating over the last week.
I have experience with C++ so I have been fiddling with Python to try learning a new language but keeping hitting a wall. I've been trying to run Python (both on command line and through JPE on the Debian OS) to run the example 'bat and ball' program in the Magpi issue 2 magazine but it refuses to run.
When checking using JPE it produces an error message:
error importing pygame: name 'color' is not defined
On the command line I get errors with ALSA to do with card 0 e.g.:
ALSA lib confmisc.c:768:(parse_card) cannot find card '0'
A simple"Hello World" runs fine but this one kicks up a fuss. Any ideas what's going wrong?
Re: Can't get Python to run with Pygame
Posted: Mon Jul 02, 2012 6:34 am
by texy
Which version of python are you running? Isn't Pygame only compatable with python 2, but not 3 ?
T.
Posted: Mon Jul 02, 2012 6:58 am
by KenT
Well worth updating to Wheezy Beta. That has pygame installed for python 2.7, maybe for 3 as well, also has a set of pygame based games with source and a pygame tutorial accessible from the desktop. Analogue and hdmi sound works with pygame in wheezy.
Posted: Mon Jul 02, 2012 6:50 pm
by tcstyle
I couldn't find any "bat and ball" example in the 2nd MagPi issue to check back, but the problem with errors like that
seems to be missing sound drivers in squeeze.
Look at this to install the sound module: http://www.chrisnewland.com/solved-no-s ... indows-244
Solved those issues for me.
Posted: Mon Jul 02, 2012 7:26 pm
by oobtim
Sorry my mistake, issue 1 :S
I'm running Python 2.6.6 if that helps. I aim to try out wheezy, puppy etc. once my order of sd cards comes in the post. I was going to try them all out then choose which is best for me.
I'll give the sound driver update a go and see if I can start listening to music.
BTW certainly recommend using Dillo as a web browser. Very basic but it works good enough for me to type this out on the Pi :)
Posted: Fri Jul 06, 2012 8:55 am
by oobtim
Sorted it out. Tried Debian Wheezy worked straight away :D
Posted: Tue Jul 10, 2012 5:53 am
by antiloquax
Sorry, I've only just seen this!
Glad to hear you got the bat and ball program working on your Pi.
Just for the record, I use Python 3.1.4 with Pygame. Everything works, but I did have to compile it myself (I'm on Arch).
There should be a more interesting Python / Pygame game in issue 4 (if I can make it short enough to fit on two pages!)
antiloquax
