racpi
how to get a serial event to update a tkinter screen
Tue Jul 22, 2014 8:10 am
I'm trying to make a gui interface that can monitor,log and interact with some wireless arduino devices (a solar panel tracker and a pid controlled wood heater) . I ultimately want to run it on the pi but I offer this example code that I'm running on a pc for ease of experimention.
what I would like to achieve is to sample an incoming serial stream for a certain value and if found update the gui. I can achieve this by pressing the button on the gui but I would like the serial input update the screen too.
#!/usr/bin/env python
import Queue
import serial
import datetime
import os
import string
import sys
import threading
import time
from Tkinter import *
count=0
ser=serial.Serial("com27",115200)
class App:
    def __init__(self, master):
        frame = Frame(master)
        frame.pack()
        self.desc=['none ','outmax ','kp','ki','kd','mkp','mki','mkd','no reg']
        self.reg   = StringVar()
        self.val   = StringVar()
        self.act   = StringVar()
        self.des   = StringVar()
        self.reg.set(0)
        self.val.set(0)
        self.act.set(0)
        self.des.set('blank')
        Label(frame, text='Reg').grid(row=0, column=0,sticky=W)
        Entry(frame, textvariable=self.reg).grid(row=0, column=1)
        Label(frame, text='Value').grid(row=1, column=0,sticky=W)
        Entry(frame, textvariable=self.val).grid(row=1, column=1)
        Label(frame, text='Action').grid(row=2, column=0,sticky=W)
        Entry(frame, textvariable=self.act).grid(row=2, column=1)
        Label(frame, text='desc').grid(row=3, column=0,sticky=W)
        Label(frame, textvariable=self.des).grid(row=3, column=1,sticky=W)
        button1 = Button(frame, text='xmit', command=self.up_load)
        button1.grid(row=4, column=1)
    def up_load(self):
        j = int(self.reg.get())
        t = chk_dig(j,2)
        t += chk_dig(int(self.val.get()),4)
        t += chk_dig(int(self.act.get()),1)
        t+="\r\n"
        #print t
        ser.write(t)
        tries=3
        time.sleep(.1)
        while tries:
            if ck.qsize()>0:
                nx=ck.get()
                if nx[0]=='R':
                    pk.put( nx)
                    self.reg.set(int(nx[1:3],16))
                    self.val.set(int(nx[3:7],16))
                    d=int(self.reg.get())
                    self.des.set(self.desc[d])
                    tries=1
                else :
                    self.val.set(0)
                    self.des.set('nill response')
            time.sleep(1)
            tries -= 1
        self.act.set(0)
class cxthread (threading.Thread):
    def __init__(self,name):
        threading.Thread.__init__(self)
    def run(self):
        process_c(self.name)
class mythread (threading.Thread):
    def __init__(self,name,q,c):
        self.q=q
        self.c=c
    def run(self):
        process_d(self.name,self.q,self.c)
class pxthread (threading.Thread):
    def __init__(self,name,p):
        self.q=p
    def run(self):
        process_p(self.name,self.q)
def process_d(tname,q,c):
    while exitflg==0:
        nx=ser.readline()
        #queueLock.acquire()
        if nx[0]=='R':
            while c.qsize()>0:
                tmp=c.get()
            c.put(nx)
        else:
            q.put(nx)
        time.sleep(.1)
        #queueLock.release()
def process_p(tname,p):
    while exitflg==0:
         #print 'count ',count
         while p.qsize()>0:
                nx=p.get()
                pk.put('nx '+nx)
         time.sleep(.1)
def process_c(tname):
        global exitflg
        root = Tk()
        root.wm_title('device para')
        app = App(root)
        root.mainloop()
        exitflg=1
def chk_dig(x,n):
    j=hex(x).lstrip("0x")
    while len(j)<n:
         j="0"+j
         #print j
    return j
#queueLock=threading.Lock()
wk=Queue.Queue(100)
ck=Queue.Queue(5)
pk=Queue.Queue(100)
exitflg=0
thread=mythread("rxd",wk,ck)
thread.start()
thread2=pxthread("pxd",wk)
thread2.start()
thread3=cxthread("cxd",)
thread3.start()
try:
    while exitflg ==0:
        if  pk.qsize()>0:
            nx=pk.get()
            print nx
        time.sleep(.1)
except  KeyboardInterrupt:
    exitflg=1
    print 'closing'
    thread.join()
    thread2.join()
    ser.close()
    sys.exit()
TrevorAppleton
Re: how to get a serial event to update a tkinter screen
Tue Jul 22, 2014 2:56 pm
I have written something which does something similar in the past
You will need to have
import threading
at the top.
You can then create a thread as such
threading.Thread(target = nameOfFunction.start()
Then create a function which checks the incoming serial stream called nameOfFunction to suit.
Hope this helps you out.
Check out my blog post for Raspberry Pi and Python tutorials.
http://trevorappleton.blogspot.co.uk/
MadCow42
Thu Jul 24, 2014 6:01 pm
The threading solution posted above is the "right" way to do it, and will work fine. The challenge in doing this with a simple loop in Python is that once you call the Tkinter.mainloop() function, it basically is an endless loop on its own until you exit the widget. So - no code after your mainloop will execute until you kill the GUI.
Conversely, if you do the serial checking in a loop prior to your Tkinter.mainloop(), then the GUI will never execute.
However, there's another option - using the Tkinter.after() command. "After" allows you to have the GUI itself execute a function after a certain timeout. You can do that in a self-sustaining loop.
Pseudocode... (sorry, just from memory):
def checkSerial():
    # check the serial for data and do something with it
    MainWindow.after(1, checkSerial) # to cause the loop.  You can pass in a reference to your Tk widget if you need to
# and then somewhere in your GUI code before the .mainloop, you need to call the checkSerial once to get it started.
gkreidl
Thu Jul 24, 2014 6:08 pm
And you can also use threads inside your Tkinter application, which in turn can send events to the main app.
Minimal Kiosk Browser (kweb)
racpi
Fri Jul 25, 2014 10:58 am
thanks everyone for your replies.
I still don't understand the tk loop yet , when I try and insert a looping function in the tk loop it all goes wrong
if I insert this into my app class I get syntax errors (self has no function after I think)
def checkSerial(self):
   self.after(1, checkSerial) # to cause the loop.  You can pass in a reference to your Tk widget if you need [code]
[/code]
I think running tkinter in a thread is not really the right way to go about this
I'm going to try running the other threads in the tk loop
scotty101
Fri Jul 25, 2014 12:49 pm
racpi wrote:if I insert this into my app class I get syntax errors (self has no function after I think)
Your class should inherit from one of the Tkinter classes which do have the .after method.
I created a traffic light example for someone several months back which shows how to use .after. Have a look at http://www.raspberrypi.org/forums/viewt ... 22#p453722
MadCow42
Fri Jul 25, 2014 6:40 pm
Correct - any of the high-level Tkinter widgets have that method... as long as that's what you're passing in as the argument to "self" you should be fine.
See: http://effbot.org/tkinterbook/widget.htm
And look for the "after" method described there.
Return to “Python”
