llovering
For-Next loop
Fri Jul 18, 2014 9:35 pm
I'm new to Python and have a PiFace attached to my Pi. I want to do these things:
1. Enter a number, either 40, 80 or 140
2. Until X = number
3. Do Pi stuff
4. Next X
5. Goto 1 ; (line 1, enter a number).
I can do the loop but can't figure out how to go back to the number question.
Thank you,
Larry
David Melara
Re: For-Next loop
Fri Jul 18, 2014 9:54 pm
The goto does not existe anymore, so in the nowdays programming languages, you use loops,
while (1): //means is going to loop forever
Do your code
Son when your code finish, it will go back to the start, otherwise, you can use functions, like
def say_hi:
Print "Hi"
While (1):
Ask a number
If number == 1
say_hi
it will do what the functions is programmed to do, in this case, it will print Hi when you call it.
good luck!
If you love doing something, be sure that something will be done right
llovering
Re: For-Next loop
Fri Jul 18, 2014 10:24 pm
So, can I nest a for-next loop into this, like this:
While(1):
Ask for the number
For x=1 to x
Do Pi stuff
Next x
ame
Re: For-Next loop
Fri Jul 18, 2014 10:36 pm
llovering wrote:So, can I nest a for-next loop into this, like this:
While(1):
Ask for the number
For x=1 to x
Do Pi stuff
Next x
Yes.
PeterO
Re: For-Next loop
Sat Jul 19, 2014 6:28 am
If you are talking about python programming, you ought to be taking the effort to atleast lay out your code in a Python style.....
Use the "Code" button above the text entry box to preserve the layout of the text you type.... like this
I typed this text
   Then highlighted it with the mouse
   Then pressed the "Code" button
       And as you can see the indentation has been preserved.
PeterO
PeterO
Re: For-Next loop
Sat Jul 19, 2014 6:43 am
While(1):
Ask for the number
For x=1 to x
Do Pi stuff
Next x
Yes.
No, not like that. Since we are talking about Python, then the examples you give should be as close to valid Python code as possible. And when you use something that isn't Python code it should be
clear that it isn't so that less experienced programmers don't think it is !
What you want is
while True:
    Some code goes here  to ask for a number and assign it to n
    for x in range(n):
        Some code goes here to do stuff goes
llovering
Re: For-Next loop
Sat Jul 19, 2014 10:48 am
Ok, here's my code but I haven't found a "sleep" function in Python; is there a substitute?
Import pifacedigitalio as pfio
Pfio.init()
while True:
   a = int(raw_input("Enter the number of slides [40,80,160: "))
    for x in range(a):
          pfio.digital_write(0,1) # Drop slide
	  pfio.digital_write(0,0)
	  sleep 2 # wait for focus to settle
	  pfio.digital_write(1,1) # Take picture
          pfio.digital_write(1,0)
        sleep 2 # wait for picture to write
    Next x
joan
Re: For-Next loop
Sat Jul 19, 2014 10:50 am
Google Python sleep.
MattHawkinsUK
Re: For-Next loop
Sat Jul 19, 2014 10:55 am
import time
time.sleep(1)
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
llovering
Re: For-Next loop
Sat Jul 19, 2014 10:58 am
Think I got it...
import time
Pfio.init()
while True:
   a = int(input("Enter the number of slides [40,80,160: "))
    for x in range(a):
	time.sleep(2) # wait for focus to settle
        time.sleep(2) # wait for picture to write
    if x == a
         break
llovering
Re: For-Next loop
Sat Aug 02, 2014 4:52 pm
As for the code in the previous example, Python says I have the spacing or indentation wrong. I also had to define true as 1.
Re: For-Next loop
Sat Aug 02, 2014 5:09 pm
Well, you have the spacing and indentation wrong then. From the little I know of Python that appears to be the case.
Your lines are wandering in and out for no reason that I can see. Make sure all lines under a test/loop/selector of any sort are indented to the same level.
while True:
    for x in range(a):
not
while True:
    for x in range(a):
Ending the indent will end the "for" loop.
Then after a few lines you have suddenly put an indent again. Python is wondering why as it can't see any test or loop on the previous line.
Also, on a small bit of test code I ran I didn't have to define "True" as 1, but I would have had to define "true" as 1 (case sensitive).
AndrewS
Re: For-Next loop
Sat Aug 02, 2014 5:14 pm
When using Python, you need to get the indentation exactly right, as it uses that to work out where blocks of code (loops, if statements, etc.) stop and start.
I think you want
import pifacedigitalio as pfio
import time
pfio.init()
while True:
    for x in range(a):
davef21370
Re: For-Next loop
Sat Aug 02, 2014 5:21 pm
Get rid of the lines...
if x == a
    break
Not only will it not work without a colon after 'a' but it's completely unnessecary.
Dave.
Apple say... Monkey do !!
davef21370
Re: For-Next loop
Sat Aug 02, 2014 5:33 pm
Thankyou Master Yoda ;)
Return to “Python”
