NicoVanDerDussen
gspread module problem
Mon Apr 28, 2014 10:13 am
I'm trying to connect with gspread using http://www.danielhansen.net/2013/03/ras ... .html#more
my code
import os, glob, time, gspread, sys, datetime
#Google account details
email = 'xxxx@gmail.com'
password = 'yyyy'
spreadsheet = 'tester' #the name of the spreadsheet already created
#attempt to log in to your google account
try:
    gc = gspread.login(email,password)
except:
    print('fail')
    sys.exit()
results in
File "./danielhansen.py", line 5, in <module>
File "/home/pi/tempmonitor/gspread.py", line 4, in <module>
gc = gspread.login('xxxx@gmail.com', 'yyyy')
AttributeError: 'module' object has no attribute 'login'
I followed the code at https://github.com/burnash/gspread/blob ... /README.md and get the same error.
What have i missed? :)
thanks
Nico
Setting up your Raspberry Pi to work with a 3G dongle http://nvdd.info/11gKrsZ
elParaguayo
Re: gspread module problem
Mon Apr 28, 2014 11:34 am
Are there any files called gspread in your current folder?
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
davef21370
Mon Apr 28, 2014 11:50 am
elParaguayo wrote:Are there any files called gspread in your current folder?
That'll be it... File "/home/pi/tempmonitor/gspread.py", line 4, in <module> the source file is called gspread, rename that and it should be fine.
Dave.
Apple say... Monkey do !!
afedriansyah
Mon Feb 26, 2018 6:36 am
Hi I've been trying to install gpsread oauth2client module on raspberry pi 3 but this message appears. I'm using raspbian stretch.
"could not find version that satisfies the requirement oauth2client ( from version: ) no matching distribution found for oauth2client"
I really neeed help with this thank you
afedriansyah
Tue Feb 27, 2018 3:05 am
Hi i've been trying to do this command "pip install oauth2client"
but this message appears "Could not find a version that satisfies the requirement oauth2client (from version ) No matching distribution found for oauth2client.
Another question is : is it truly important to install oauth2client into my raspberry pi to enable gspread database or are there more alternatives to use gpsread in raspberry pi
Detail answers would be appreciated
Thank you very much
Return to “Python”
