fdiba
pi camera openCV and Python
Mon Apr 14, 2014 9:19 pm
Hello I try to edit the code below to use a pi camera with openCV (to be able to detect faces at the end)
I just want to put the image taken by the pi camera on my Display (myDisplay). Can you help me ?
from SimpleCV import Camera, Display
from time import sleep
myCamera = Camera(prop_set={'width': 320, 'height': 240})
myDisplay = Display(resolution=(320, 240))
while not myDisplay.isDone():
      myCamera.getImage().save(myDisplay)
      sleep(.1)
TrevorAppleton
Re: pi camera openCV and Python
Tue Apr 15, 2014 10:21 am
I have written a blog post in the past which helps getting started with Image detection in OpenCV. I think this may be a good starting point.
http://trevorappleton.blogspot.co.uk/20 ... pencv.html
If I was re-writing this now I would probably implement the python libraries for the camera, which were not available at the time I wrote the post. There are some details here.
http://www.raspberrypi.org/a-pure-pytho ... -picamera/
Hope this helps,
Trevor
Check out my blog post for Raspberry Pi and Python tutorials.
fdiba
Tue Apr 15, 2014 4:27 pm
Thank you but it doesn't really help : I don't want to use camera.start_preview() to show the video.
I'd like to find the something like .getImage() if it exists to use with myDisplay and use the library PiCamera.
I'm going to try this : http://thinkrpi.wordpress.com/2013/05/2 ... board-csi/ if I get any other solution.
Return to “Python”
