JizzaDaMan
Turn screen on and off at will
Sun Mar 23, 2014 7:56 pm
I want to use my pi to play videos when they are sent a signal over a network (The signal sending part is sorted).
So my first question is how can I play full screen videos using python?
I also need the screen to be blank when it's not playing a video, how can I achieve this?
JizzaDaMan
Re: Turn screen on and off at will
Tue Mar 25, 2014 5:59 pm
Any suggestions?
redhawk
Tue Mar 25, 2014 6:01 pm
HDMI or composite??
Richard S.
davef21370
Tue Mar 25, 2014 6:09 pm
Does the screen need to be powered down or can it just be black?
Dave.
Apple say... Monkey do !!
iinnovations
Tue Mar 25, 2014 6:18 pm
This script works for me:
https://github.com/iinnovations/iicontr ... /screen.sh
Pass one of the three arguments.
Colin
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
davef21370
Tue Mar 25, 2014 6:37 pm
iinnovations wrote:This script works for me:
Colin
How would you implement that in Python?
Dave.
iinnovations
Tue Mar 25, 2014 8:14 pm
Probably something like this:
https://github.com/iinnovations/iicontr ... /screen.py
Although I just tested this, I did so on a remote headless box, so YMMV.
Colin
cupidcontrols.com
JizzaDaMan
Tue Mar 25, 2014 9:03 pm
Thanks for the responses. I'm talking about HDMI here.
With regard to it going black rather than off, I in fact need it to go black, rather than off, because otherwise I'll get the 'NO SIGNAL' message, which is something I'm trying to avoid.
I have tried a command something like tvservice -p or something, and that did what I wanted it to, except I had no idea how to turn it back on again :P
---EDIT---
Having had a look at the scripts, I'll try them out tomorrow. Thank you :)
simonmcc
Wed Mar 26, 2014 12:39 pm
if you just want the screen to go blank, not HDMI off then xscreensaver is your friend.
Install the xscreensaver package, and then use
xscreensaver-command -activate
and
xscreensaver-command -deactivate
they will blank and unblank the screen. You should run xscreensaver-demo to set the defaults (just set it to off and then you're in control)
simonmcc.blogspot.com/search/label/pi
toxibunny
Thu Mar 27, 2014 4:40 pm
Or just display a black .bmp or .jpg fullscreen...
note: I may or may not know what I'm talking about...
Return to “Python”
