scottie2212
Python Gtk and PiFace listener - help needed.
Mon Sep 16, 2013 6:46 pm
Hi, I need some help with my first python project.
The project -
Target: to use a R-Pi to control a camera atop a 100 foot mast.
Current state: head control finished, camera control (gphoto2) in progress.
Current task: read output of anemometer and convert it to windspeed.
I found the following on piface.github
>>> import pifacedigitalio
>>> pifacedigitalio.init()
>>> pfd = pifacedigitalio.PiFaceDigital()
>>> def toggle_led0(event):
...     pfd.leds[0].toggle()
>>> listener = pifacedigitalio.InputEventListener()
>>> listener.register(0, pifacedigitalio.IODIR_ON, toggle_led0)
>>> listener.activate()
and decided this would do for counting output pulses.
I found it worked perfectly through Python shell but when I tried to incorporate it into a python script everything went pear shaped. I must point out that this is the first time I have tried to write a python script so any suggestions you can make should take this into consideration.
#!/usr/bin/python
from gi.repository import Gtk
icount = 1
class MyWindow(Gtk.Window):
  def toggle_led0(self, event):
    global icount
    icount += 1
  def start_listen(self, widget):
    listener.register(0, pifacedigitalio.IODIR_ON, self.toggle_led0)
    listener.activate()
    print "listener activated"
  def stop_listen(self, widget):
    listener.deactivate()
    print "listener deactivated"
  def __init__(self): # this is the class constructor where we build widgets, etc
    Gtk.Window.__init__(self, title="Wind Speed Indicator")
    self.box = Gtk.Box(spacing=6)
    self.add(self.box)
    self.button1 = Gtk.Button(label="Start Listener")
    self.button1.connect("clicked", self.start_listen)
    self.box.pack_start(self.button1, True, True, 0)
    self.label = Gtk.Label(label="Hello World", halign=Gtk.Align.CENTER)
    self.box.pack_start(self.label, True, True, 2)
    self.button2 = Gtk.Button(label="Stop Listener")
    self.button2.connect("clicked", self.stop_listen)
    self.box.pack_start(self.button2, False, False, 5)
    self.button3 = Gtk.Button(label="Show icount")
    self.button3.connect("clicked", self.on_button3_clicked)
    self.box.pack_start(self.button3, True, True, 0)
  def on_button1_clicked(self, widget):
    self.label.set_text("Starting Listener")
  def on_button2_clicked(self, widget):
    self.label.set_text("Stopping Listener")
  def on_button3_clicked(self, widget):
    icntprt = "Count is " + str(icount)
    self.label.set_text(icntprt)
win = MyWindow()
win.connect("delete-event", Gtk.main_quit)
win.show_all()
Gtk.main()
What happens -
The window, I click 'Start Listener', the shell window shows 'listener activated'. I press the input button a few times and then click 'Show icount'.
'Count is 1' appears in the window. This is the default value. I expected it to have increased by the number of button pushes.
I click 'Stop Listener' and then click 'Show icount'. Now the number has been incremented.
I think I must have the counter and/or listener functions in the wrong place but I have tried various things which usually produced errors. This script does not raise any errors but doesn't work as I want.
I'd be very grateful for any help you can give me.
Scottie
Return to “Python”
