kyled2012
Simultaneous python commands?
Wed Feb 06, 2013 11:53 am
Hello all.
I have written a python script that uses the GPIO to flash some LEDs and play a sound when a switch is opened (for a proof of concept burglar alarm).
The lights work and the sound plays, but unfortunately when the sound is played, no other commands are processed at the same time, leading to a delay until the sound is finished playing.
I would love to know, is it possible to have multiple commands executed simultaneously in python?
Or if not, is there a sound player available on the pi that can play a file without hanging terminal during playback?
Thanks in advance guys!
texy
Re: Simultaneous python commands?
Wed Feb 06, 2013 1:07 pm
Hi and welcome to the forum,
please post your complete script and remember to use the
 tab - then we can see how you are playing the tune.
Rgds,
Texy
bgreat
Wed Feb 06, 2013 1:45 pm
What you are wanting to accomplish can accomplished using Python threads -- parallel execution of tasks.
In its simplest form, you define a Python function to execute your task and use Thread to start it. Control returns back to your main application while the thread runs. You can monitor the running state of the thread using isAlive() or is_alive().
Simple example:
#!/usr/bin/env python
import time
from threading import Thread
def myfunc(count):
    print "myfunc entry"
    for i in range(count):
        time.sleep(2)
        print "loop:",(i+1)
def main():
    print "main"
    t = Thread(target=myfunc, args=(10,))
    print "Starting myfunc() thread"
    t.start()
    print "main still running"
    while True:
        time.sleep(1)
        print "tick"
        time.sleep(1)
        print "tock"
        if (not t.isAlive()):
            t.join()
            print "thread stopped"
            break;
    print "Done"
if __name__=='__main__':
    main()
This just shows how threads work. Read more in the Python documentation. For your requirement, you may want to start a "playback" thread that waits on a queue to receive the next sound to play (read about interprocess communication).
Enjoy!
Bill
-rst-
Wed Feb 06, 2013 2:52 pm
Threads would definitely do it, but it maybe just as simple as invoking the play command in the background (if using an external player)...
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
toxibunny
Wed Feb 06, 2013 7:51 pm
Threads are pretty easy to use, mind. When I first came across it, I thought 'oh no, this'll be complicated', but I had it up and running in no time. Probably come in handy later on, too.
note: I may or may not know what I'm talking about...
kyled2012
Wed Feb 06, 2013 10:27 pm
Thanks bgreat, I will check it out when I get home tonight, seems like a perfect solution to my problem
Return to “Python”
