datanaut
Threading. Run two tasks independently
Sat Jan 26, 2013 2:21 am
I'm very new to python and pi.
I can use this bash script to run two tasks simultaneously independent of each other
#!/bin/bash
/home/pi/gpio/led_Startup.py &
# Blink led 1 at random
/home/pi/gpio/blink_Led_1.py &
# Blink led 2 at random
/home/pi/relay/blink_Led_2.py &
There has to be a better way within a pythons script but what do I look for and where?
Is it threading, multitasking, parallel processing?
souperPi
Re: Threading. Run two tasks independently
Sat Jan 26, 2013 4:48 am
Datanaut,
Check out the "threading" package in Python, that should do what you're looking for. Your example doesn't need it, but the queue package is very straightforward for communicating between threads.
The "multiprocessing" package could be used too, but for your example I think that would be overkill.
datanaut
Sun Jan 27, 2013 3:13 am
souperPi wrote:Datanaut,
Thanks. I found this now I know what to look for and hacked it to run 5 'while loops' simultaneously
import time
from threading import Thread
def myfunc(i):
    print "sleeping 5 sec from thread %d" % i
    time.sleep(5)
    print "finished sleeping from thread %d" % i
for i in range(10):
    t = Thread(target=myfunc, args=(i,))
    t.start()
Anyone know how to set a thread to SOLVED?
Return to “Python”
