ALSA errors with PyAudio and SpeechRecognization
Posted: Fri Dec 13, 2019 6:14 pm
by sheikhsadab
Hi, I'm trying to get voice input from microphone using Raspberry Pi 2 and Python. I'm using SpeechRecognition and PyAudio for it.
Things I'm using:
Python: 2.7.16
Raspberry Pi 2
Microphone: using 3.5mm to USB
Mic is being detected, I can record audio (using arecord) and listen to the recorded files just fine.
My code is not faulty, it works perfect on my Windows systems.
I'm using the following code:
import speech_recognition as sr
#function to execute voice command
r = sr.Recognizer()
while True:
	with sr.Microphone() as source:
		print 'Say something: '
		#r.adjust_for_ambient_noise(source)
		try:
			audio = r.listen(source,timeout=3) #listening for 3 seconds
		except:
			print "Timeout Exception"
		try:
			text = r.recognize_google(audio)
			print "You said: " , text
			exec_command(text)
		except:
			print "Could not understand"
However, when trying on the Raspberry Pi, i get the following errors:
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.front.0:CARD=0'
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:5036:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM bluealsa
Say something:
Say something:
Say something:
Say something:
^Z
[1]+  Stopped                 python srt.py
Please let me know how it can be fixed.
If there's any alternative way (without using PyAudio and SpeechRecognization) to convert speech to text using Python on RaspberryPi, then that will also do.
If I need to provide any additional info or anything please let me know.
Thanks.
PS: My Project submission date is near (only few days remaining), so urgent help will be really appreciated.
PS: Sorry if this is the wrong section or if the same question has been answered previously.
Thanks.
Re: ALSA errors with PyAudio and SpeechRecognization
Posted: Fri Dec 13, 2019 7:35 pm
by hippy
This seems to be a long-standing issue others have run into as a forum search should reveal. I am not sure if there is any 'official fix' as such but some members have indicated they had success with rolling back to an older kernel -
https://www.raspberrypi.org/forums/view ... 4#p1478460
Posted: Fri Dec 13, 2019 9:34 pm
by Zilla707
Are you on the wifi? Google's sr won't work without wifi.
