Lookslikerain75
GUIZERO Button waits for process called to finish
Mon Nov 11, 2019 8:46 pm
I am calling a subprocess.run from a pushbutton, the issue I have is the button remains pressed down whilst the entire subprocess runs (10-15 seconds. I need the button to run the process but still let other processes run and not lock the entire window, so that the contents of a log file can update the value of a textbox. This all works but only after the subprocess called by the button completes.
Is this standard behaviour?
rpiMike
Re: GUIZERO Button waits for process called to finish
Tue Nov 12, 2019 10:29 am
You need to post your code for us to be able to help.
scotty101
Tue Nov 12, 2019 10:55 am
Are you using subprocess.run or subprocess.Popen?
Run will always wait, Popen can be configured to not wait.
See https://stackoverflow.com/questions/351 ... -dont-wait
Lookslikerain75
Wed Nov 13, 2019 10:36 am
subproccess.Popen solved the problem, much appreciated
Return to “Python”
