NPDedyukhin
i2c_lcd and python. Display of variable value.
Wed Oct 09, 2019 1:49 pm
Good afternoon!
There is a module "i2c_lcd" and python.
At the beginning of the script, I assign the variable "a" to 1 (am I doing the assignment correctly?)
Next, I try to display the value of the variable on the display.
I wrote a script like this:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
a = 1
import lcddriver
lcd = lcddriver.lcd()
lcd.lcd_clear()
lcd.lcd_display_string(a, 1)
Apparently, I'm doing something wrong, because after running this script, nothing is displayed.
Writes an error: TypeError: 'int' object is not iterable
Please help me figure out what the problem is.
Respectfully,
Nikita Dedyukhin
B.Goode
Re: i2c_lcd and python. Display of variable value.
Wed Oct 09, 2019 1:58 pm
a = 1
That assigns the numeric value '1' to the variable named a.
It seems reasonable to guess that lcd_display_string() will output a string on the display. (Reading the documentation for the module you are using is recommended.)
But as discussed above your variable a contains a number, not a string.
NPDedyukhin
Wed Oct 09, 2019 1:59 pm
Good afternoon!
a = 1
import lcddriver
lcd.lcd_clear()
I rewrote the code and it worked:
a = 1
a = str(a)
import lcddriver
lcd.lcd_clear()
It was necessary to set the variable type "str"
Respectfully,
Nikita Dedyukhin
Andyroo
Wed Oct 09, 2019 3:29 pm
a = 1
a = str(a)
import lcddriver
lcd.lcd_clear()
A simpler method would be to set the value as a string first:
a = "1"
import lcddriver
lcd.lcd_clear()
You can also use the single quote ( ' ) to denote a string. If you are using some editors (or iPads etc) you have to be careful as the will try to correct the quotes to match correct English so "test" becomes “test” and the program fails...
Have a look at https://www.tutorialspoint.com/python/p ... _types.htm for some basic information on types of variables.
Return to “Python”
