NPDedyukhin
Round trip cycle
Wed Oct 09, 2019 5:30 am
Good afternoon! :)
I have a variable: "a"
It can take two values: 1 or 2.
By default, the variable must be of type: 1
Further, using "pygame", we analyze events on the keyboard - if one of the arrows is pressed (left or right), the variable value changes from 1 to 2, and vice versa - each time you click on one of the arrows on the keyboard.
If you press Enter, then the following script is run.
Please tell me how to make a cycle of constant change from one value to another? :?:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import pygame
pygame.init()
screen = pygame.display.set_mode((400,400))
a = 1
done = False
while not done:
    for event in pygame.event.get():
        if event.type == pygame.QUIT:
            done = True
        elif event.type == pygame.KEYDOWN:
            if event.key == pygame.K_LEFT:
            	#how to change the value of "type_con" here?
            if event.key == pygame.K_RIGHT:
            if event.key == pygame.K_RETURN:
                import write_connection_01
Respectfully,
Nikita Dedyukhin
NPDedyukhin
Re: Round trip cycle
Wed Oct 09, 2019 2:17 pm
Good afternoon! :)
import pygame
pygame.init()
a = 1
done = False
while not done:
            done = True
In order to, when an event occurs, a variable changes between two values, it is necessary:
At the very beginning, create this variable (a) and two more (b and c).
Then, we set the variable “a” to 1
And for the remaining two variables (b and c) we assign the value 2.
We have:
A = 1
B = 2
C = 2
Further, when an event occurs, we need to do the following:
To the variable "c" we assign the value to the variable "a".
We assign the value of the variable b to the variable “a”.
To the variable "b" we assign the value to the variable "c".
And we get:
A = 2
B = 1
C = 1
(the value of A changed from 1 to 2 - what you need)
If the event occurs repeatedly, we get:
A = 1
B = 2
C = 2
(the value of A reversed from 2 to 1 - that's right)
Code:
a = 1
b = 2
c = 2
a = str(a)
b = str(b)
c = str(c)
import pygame
pygame.init()
done = False
while not done:
            done = True
            	c = a
                a = b
                b = c
            	c = a
                a = b
                b = c
Respectfully,
Nikita Dedyukhin
joelostinspace
Wed Oct 09, 2019 5:31 pm
I've seen this solved multiple ways- use a as a count and all even counts are true and Boolean.
I look at this as a Boolean problem and solution: if it's one way then change it, then vice versa.
I like to solve these problems with the interrupter so fallow along with your favorite:
>>> a= 1
>>> def check_boolean(var):
	    global a
	    if var == True:
		a = 0
		print('false')
	    else:
		a = 1
		print('Now True')
>>> check_boolean(a)
false
>>> check_boolean(a)
Now True
>>> check_boolean(a)
false
import pygame
pygame.init()
a = 1
    global a
    if var == True:
        a = 0
	print('false')
    else:
    a = 1
    print('Now True')
done = False
while not done:
            done = True
            	check_boolean(a)
            	check_boolean(a)
then you need a if statement example:
if a == True:
    do something...
else:
    something else.....
edit: code indent may be off...
I would rather live in a world where my life is surrounded by mystery than a world so small that my mind could comprehend it.
--- Harry Emerson Fosdick
Return to “Python”
