uzair khan
line follower using raspberry pi
Tue Aug 27, 2019 3:09 pm
hello guys i m making line following robot using raspberry pi .i connected whole things like motor driver circuit ,ir sensors raspberry pi 3 b+ on chassis as shown in this site( https://circuitdigest.com/microcontroll ... ower-robot) .Then connected robot to monitor with hdmi and write whole coding in thonny's python ide from ( https://circuitdigest.com/microcontroll ... ower-robot) found some errors in below ,after correction it shows >>>>>> in lower block (shell).then i clicked on debug and compile it shows compilation successfully .plz some one tell me what to next ??? to run robot
MrYsLab
Re: line follower using raspberry pi
Tue Aug 27, 2019 11:10 pm
Please post the errors that you are getting. Without that information, it will be impossible to help. If you are simply asking how to run a program within thonny, click on the green RUN button.
Return to “Python”
