drifterf
Script to download a file from internet at time intervals
Wed Aug 14, 2019 4:39 pm
hI, is there a simple python script that when i run it, it downloads a file from a location on the web to a folder on the pi ? or one that could auto do this every hour or so ? thanks
Andyroo
Re: Script to download a file from internet at time intervals
Wed Aug 14, 2019 4:42 pm
Use cron to schedule a simple script the uses wget
wget https://example.com/files/mydiwnload.dat
drifterf
Wed Aug 14, 2019 5:41 pm
hi, thank you for this, this seems to work great.
the only problem is if the file doesent exist or the pi dosent have internet it dosent retain the existing data as a failover ?
im using this wget to get the data
wget http://www.furniss.uk/Databases/database.csv -O /home/pi/furniss/database/database.csv
rpdom
Wed Aug 14, 2019 6:26 pm
Try this version of the command in the crontab
wget http://www.furniss.uk/Databases/database.csv -O /home/pi/furniss/database/database.tmp && mv /home/pi/furniss/database/database.tmp /home/pi/furniss/database/database.csv
That will download to a temporary file, and then overwrite the real file only if the wget didn't have any errors.
drifterf
Wed Aug 14, 2019 6:38 pm
Thank you, this seems to do the trick !!! much appreciated !!!
Return to “Python”
