drifterf
reading a online database but have a fall over on the pi ?
Mon Aug 12, 2019 6:45 pm
hi, i have a system that reads a csv file on the pi itself at the moment and does its job as needed. i can update this csv file wih new data as i need.
ithe system is an access control system so when the proximity reader reads the correct number it triggers a gpio pin.
what i want to so is have my script read a csv file remotly (maybe a web address, http://mywebsite.co.uk/data.csv) but if the pi is not onlone or cannot see the file it falls over onto a database that is stored on the pi itself. the current start of my script which reads the data file is as follows:
import pigpio, csv, os
os.system("pigpiod")
FILE_TO_READ = '/home/pi/furniss/database/database.csv'
CSV_ID_KEY = 'Number :'
CSV_NAME_KEY = 'Name :'
CSV_TEL_KEY = 'Tel No :'
class decoder:
could i add this under the file to read /database.csv ?
FILE_TO_READ = /'http://mywebsite.co.uk/data.csv'
thanks
ghp
Re: reading a online database but have a fall over on the pi ?
Mon Aug 12, 2019 7:59 pm
https://stackoverflow.com/questions/139 ... d-the-cont
Surround this with a try:...except Exception: and read the file in the exception branch.
Douglas6
Tue Aug 13, 2019 12:28 am
And you might want to use the term 'failover' (https://en.m.wikipedia.org/wiki/Failover), instead of 'fall over' (https://www.dictionary.com/browse/fall-over).
drifterf
Tue Aug 13, 2019 4:17 pm
thank you for the comments and thats great. also thanks for the fallover-failover thing :)
isit possible you could help me add it to the code, im new and learning and if could see the differnce between my original code and one with the option of what i asked above this would really help me so i could continue to modify this script with this. appreciated in advance.
my current script is as follows
#!/usr/bin/env python
class decoder:
   A class to read Wiegand codes of an arbitrary length.
   The code length and value are returned.
   EXAMPLE
   import time
   import pigpio
   import wiegand
   def callback(bits, code):
      print("bits={} code={}".format(bits, code))
   pi = pigpio.pi()
   w = wiegand.decoder(pi, 14, 15, callback)
   while True:
      time.sleep(60)
   w.cancel()
   pi.stop()
   def __init__(self, pi, gpio_0, gpio_1, callback, bit_timeout=5):
      Instantiate with the pi, gpio for 0 (green wire), the gpio for 1
      (white wire), the callback function, and the bit timeout in
      milliseconds which indicates the end of a code.
      The callback is passed the code length in bits and the value.
      self.pi = pi
      self.gpio_0 = gpio_0
      self.gpio_1 = gpio_1
      self.callback = callback
      self.bit_timeout = bit_timeout
      self.in_code = False
      self.pi.set_mode(gpio_0, pigpio.INPUT)
      self.pi.set_mode(gpio_1, pigpio.INPUT)
      self.pi.set_pull_up_down(gpio_0, pigpio.PUD_UP)
      self.pi.set_pull_up_down(gpio_1, pigpio.PUD_UP)
      self.cb_0 = self.pi.callback(gpio_0, pigpio.FALLING_EDGE, self._cb)
      self.cb_1 = self.pi.callback(gpio_1, pigpio.FALLING_EDGE, self._cb)
   def _cb(self, gpio, level, tick):
      Accumulate bits until both gpios 0 and 1 timeout.
      if level < pigpio.TIMEOUT:
         if self.in_code == False:
            self.bits = 1
            self.num = 0
            self.in_code = True
            self.code_timeout = 0
            self.pi.set_watchdog(self.gpio_0, self.bit_timeout)
            self.pi.set_watchdog(self.gpio_1, self.bit_timeout)
         else:
            self.bits += 1
            self.num = self.num << 1
         if gpio == self.gpio_0:
            self.code_timeout = self.code_timeout & 2 # clear gpio 0 timeout
         else:
            self.code_timeout = self.code_timeout & 1 # clear gpio 1 timeout
            self.num = self.num | 1
      else:
         if self.in_code:
               self.code_timeout = self.code_timeout | 1 # timeout gpio 0
            else:
               self.code_timeout = self.code_timeout | 2 # timeout gpio 1
            if self.code_timeout == 3: # both gpios timed out
               self.pi.set_watchdog(self.gpio_0, 0)
               self.pi.set_watchdog(self.gpio_1, 0)
               self.callback(self.bits, self.num)
   def cancel(self):
      Cancel the Wiegand decoder.
      self.cb_0.cancel()
      self.cb_1.cancel()
def readFile(filename):
   data = []
   with open(filename, 'r') as file:
      reader = csv.DictReader(file)
      data = [row for row in reader]
   return data
def authenticateFromFile(id):
   for row in readFile(FILE_TO_READ):
      if CSV_ID_KEY in row and row[CSV_ID_KEY] == id:
         return row
   return False
if __name__ == "__main__":
   print (" ")
   print ("Furniss.UK ACS - Version 1.1 - TLF")
   print (" ")
   import time
   import datetime
   import RPi.GPIO as GPIO
   import pigpio
   import wiegand
   GPIO.setmode(GPIO.BCM)
   GPIO.setwarnings(False)
   def callback(bits, value):
      user = authenticateFromFile('{}'.format(value))
      if user:
         now = datetime.datetime.now()
         print (now.strftime("%Y-%m-%d %H:%M:%S"))
         print("User='{}' Tel='{}' Wiegand bits={} Card Number={}".format(user[CSV_NAME_KEY], user[CSV_TEL_KEY], bits, value))
         print (" ")
         file = open("/home/pi/furniss/html/events.txt", "w")
         file.write("Last Access: Wiegand bits={}\n".format(bits))
         file.write("\nCard value={}".format(value))
         GPIO.setup(18,GPIO.OUT)
         print("door released")
         GPIO.output(18,GPIO.LOW)
         time.sleep(5)
         print (" ")
         print("door secure")
         GPIO.output(18, GPIO.HIGH)
         print (" ")
         print (" --------------------------------------------")
      else:
         print (" ")
         print("Access Denied = Wiegand bits={} Card Number={}".format(bits, value))
         file.write("Access Denied = Wiegand bits={} Card Number={}".format(bits, value))
         print (" ")
         print (" ")
   pi = pigpio.pi()
   while True:
      time.sleep(60)
   w.cancel()
   pi.stop()
Andyroo
Tue Aug 13, 2019 4:59 pm
I would use something like wget to download the file and if that fails then use the local copy rather than trying to read from a CSV on the net. This is not as up to date as reading the file directly but less prone to errors. Remember, EVERY command with the remote file will need error trapping.
It can be done (example here from 2013.
The other option is to move away from flat files and use MySQL and replication.
drifterf
Tue Aug 13, 2019 5:24 pm
this is exactly as i want tbh !! could you help me put this in the code i posted above please ? as mentioned if i could see the differnce i could continue this project greatly on my own and learn. appreciated
drifterf
Wed Aug 14, 2019 4:19 pm
anyone please ?
hippy
Wed Aug 14, 2019 8:43 pm
Have a search for "urllib" and "urllib.urlopen" which allows a 'wget' to be done from within Python.
And you will probably want to add that to your "readFile" routine, though I would suggest starting with separate a proof of concept aside program to get urllib and fail-over detect working, and safely updating your disk-based database file. The last thing you want to do is to lose or corrupt your database file and lock everyone out.
And on that - How business critical, or otherwise critical, is this project, your code ?
Return to “Python”
