sayhello
Wemos with a serial/USB chip based on CH304G - using for micropython
Wed Aug 07, 2019 3:56 pm
hello dear raspi-experts,
this tutorial here - ( regarding the rc car that runs with micropython ) notes the following
Step 4: MicroPython Installation
cf: https://www.instructables.com/id/MicroP ... SP-8266EX/
Step 4: MicroPython Installation First, Wemos has a serial/USB chip based on CH304G. This is the same chip found in cheap Arduino-clones and you must install a proper driver for Mac or PC. Follow the instructions on this site to install the driver.
Connect Wemos to your computer and confirm that your computer could detect Wemos. On Mac, run the following command and you will see a device called /dev/tty.wchusbserial640.
well - is the chip that is mentioned - Wemos has a serial/USB chip based on CH304G - is it on the WEMOS Board or should i add them on a
breakout-board!?
well i want to stick with Mycropython in the project - i want to go this way.
love to hear from you,
regards YOURS SAY
CF https://www.instructables.com/id/MicroP ... SP-8266EX/
PhatFil
Re: Wemos with a serial/USB chip based on CH304G - using for micropython
Wed Aug 07, 2019 4:13 pm
breakout-board!?
the wemos dev boards have usb ports onboard for power/connection so its already onboard so no need to add anything just plug in a usb lead and install drivers if needed.
mikronauts
Wed Aug 07, 2019 5:34 pm
Return to “Python”
