chun9321md
How to using a value from spinbox
Wed Aug 07, 2019 11:53 am
How to use a value from spinbox? Even though i set the spinbox value (>1), the "print('turning on'+spinsee1)" command is printing "turning on0" (the default value spinbox value=0). So, how to use the exact value, for example: when i set the value as 30, the print is showing turning on30?
from tkinter import *
import tkinter as tk
import time
root = Tk()
class App(Frame):
    def __init__(self,master=None):
        Frame.__init__(self, master)
        self.master = master
        self.label = Label(text="", fg="Red", font=("Helvetica", 10))
        self.label.grid(row=6, column=1)
        self.update_clock()
    def update_clock(self):
        now = time.strftime("%H:%M:%S")
        self.label.configure(text=now)
        self.after(1000, self.update_clock)
app=App(root)
root.wm_title("Jotnar controller_version 1.0 beta")
Label(root, text='Current time:').grid(row=6, column=0)
root.geometry("300x250")
root.after(1000, app.update_clock)
Label(root, text='Percentage(%)').place(x=140, y=0)
Label(root, text='1').place(x=10, y=30)
Label(root, text='2').place(x=10, y=60)
Label(root, text='3').place(x=10, y=90)
Label(root, text='4').place(x=10, y=120)
Label(root, text='5').place(x=10, y=150)
Label(root, text='6').place(x=10, y=180)
spin1 = Spinbox(root, from_=0, to=100, width=5)
global spinsee1
spin1.place(x=150, y=30)
spinsee1=spin1.get()
spin2 = Spinbox(root, from_=0, to=100, width=5)
global spinsee2
spin2.place(x=150, y=60)
spinsee2=spin2.get()
spin3 = Spinbox(root, from_=0, to=100, width=5)
spin3.place(x=150, y=90)
global spinsee3
spinsee3=spin3.get()
spin4 = Spinbox(root, from_=0, to=100, width=5)
spin4.place(x=150, y=120)
global spinsee4
spinsee4=spin4.get()
spin5 = Spinbox(root, from_=0, to=100, width=5)
spin5.place(x=150, y=150)
global spinsee5
spinsee5=spin5.get()
spin6 = Spinbox(root, from_=0, to=100, width=5)
spin6.place(x=150, y=180)
global spinsee6
spinsee6=spin6.get()
def toggle1():
    if var1.get() == "ON":
    else:
        print("turning off...")
var1 = tk.StringVar()
toggle = tk.Checkbutton(root, onvalue="ON", offvalue="OFF", width=4,
                        indicatoron=False,
                        variable=var1, textvariable=var1,
                        selectcolor="green", background="red",
                        command=toggle1)
var1.set("OFF")
toggle.place(x=220, y=30)
def toggle2():
    if var2.get() == "ON":
        print('turning on'+spinsee2)
    else:
var2 = tk.StringVar()
                        indicatoron=False,
                        variable=var2, textvariable=var2,
                        command=toggle2)
var2.set("OFF")
toggle.place(x=220, y=60)
def toggle3():
    if var3.get() == "ON":
        print('turning on'+spinsee3)
    else:
var3 = tk.StringVar()
                        indicatoron=False,
                        variable=var3, textvariable=var3,
                        command=toggle3)
var3.set("OFF")
toggle.place(x=220, y=90)
def toggle4():
    if var4.get() == "ON":
        print('turning on'+spinsee4)
    else:
var4 = tk.StringVar()
                        indicatoron=False,
                        variable=var4, textvariable=var4,
                        command=toggle4)
var4.set("OFF")
toggle.place(x=220, y=120)
def toggle5():
    if var5.get() == "ON":
        print('turning on'+spinsee5)
    else:
var5 = tk.StringVar()
                        indicatoron=False,
                        variable=var5, textvariable=var5,
                        command=toggle5)
var5.set("OFF")
toggle.place(x=220, y=150)
def toggle6():
    if var6.get() == "ON":
        print('turning on'+spinsee6)
    else:
var6 = tk.StringVar()
                        indicatoron=False,
                        variable=var6, textvariable=var6,
                        command=toggle6)
var6.set("OFF")
toggle.place(x=220, y=180)
mainloop()
topguy
Re: How to using a value from spinbox
Wed Aug 07, 2019 12:34 pm
Please put Python questions to the python sub-forum.. the General Discussion forum is overcluttered as it is.
Also google..
https://stackoverflow.com/questions/438 ... om-spinbox
scotty101
Wed Aug 07, 2019 1:06 pm
You need to "get" the value directly before you use it. At the moment you only get the value once when the program starts
See below example
def toggle1():
        spinsee = spin1.get()
    else:
mahjongg
Wed Aug 07, 2019 2:55 pm
moved to python
MrYsLab
Wed Aug 07, 2019 4:20 pm
In general, one of the main reasons to use a class is that allows one to avoid using globals and organizes the code so that it is easier to read and debug.
Therefore, I have reformatted your script as follows. It should now function properly.
import time
class App(Frame):
    def __init__(self):
        self.root = tk.Tk()
        self.frame = Frame.__init__(self, self.root)
        Label(self.frame, text='Current time:').grid(row=6, column=0)
        self.root.geometry("300x250")
        self.root.wm_title("Jotnar controller_version 1.0 beta")
        Label(self.root, text='Percentage(%)').place(x=140, y=0)
        Label(self.root, text='1').place(x=10, y=30)
        Label(self.root, text='2').place(x=10, y=60)
        Label(self.root, text='3').place(x=10, y=90)
        Label(self.root, text='4').place(x=10, y=120)
        Label(self.root, text='5').place(x=10, y=150)
        Label(self.root, text='6').place(x=10, y=180)
        self.spin1 = Spinbox(self.root, from_=0, to=100, width=5)
        self.spin1.place(x=150, y=30)
        self.spin2 = Spinbox(self.root, from_=0, to=100, width=5)
        self.spin2.place(x=150, y=60)
        self.spin3 = Spinbox(self.root, from_=0, to=100, width=5)
        self.spin3.place(x=150, y=90)
        self.spin4 = Spinbox(self.root, from_=0, to=100, width=5)
        self.spin4.place(x=150, y=120)
        self.spin5 = Spinbox(self.root, from_=0, to=100, width=5)
        self.spin5.place(x=150, y=150)
        self.spin6 = Spinbox(self.root, from_=0, to=100, width=5)
        self.spin6.place(x=150, y=180)
        self.var1 = tk.StringVar()
        self.toggle = tk.Checkbutton(self.root, onvalue="ON", offvalue="OFF", width=4,
                                     indicatoron=False,
                                     variable=self.var1, textvariable=self.var1,
                                     command=self.toggle1)
        self.var1.set("OFF")
        self.toggle.place(x=220, y=30)
        self.var2 = tk.StringVar()
        self.toggle2 = tk.Checkbutton(self.root, onvalue="ON", offvalue="OFF", width=4,
                                      indicatoron=False,
                                      variable=self.var2, textvariable=self.var2,
                                      command=self.toggle2)
        self.var2.set("OFF")
        self.toggle2.place(x=220, y=60)
        self.var3 = tk.StringVar()
        self.toggle3 = tk.Checkbutton(self.root, onvalue="ON", offvalue="OFF", width=4,
                                      indicatoron=False,
                                      variable=self.var3, textvariable=self.var3,
                                      command=self.toggle3)
        self.var3.set("OFF")
        self.toggle3.place(x=220, y=90)
        self.var4 = tk.StringVar()
        self.toggle4 = tk.Checkbutton(self.root, onvalue="ON", offvalue="OFF", width=4,
                                      indicatoron=False,
                                      variable=self.var4, textvariable=self.var4,
                                      command=self.toggle4)
        self.var4.set("OFF")
        self.toggle4.place(x=220, y=120)
        self.var5 = tk.StringVar()
        self.toggle5 = tk.Checkbutton(self.root, onvalue="ON", offvalue="OFF", width=4,
                                      indicatoron=False,
                                      variable=self.var5, textvariable=self.var5,
                                      command=self.toggle5)
        self.var5.set("OFF")
        self.toggle5.place(x=220, y=150)
        self.var6 = tk.StringVar()
        self.toggle6 = tk.Checkbutton(self.root, onvalue="ON", offvalue="OFF", width=4,
                                      indicatoron=False,
                                      variable=self.var6, textvariable=self.var6,
                                      command=self.toggle6)
        self.var6.set("OFF")
        self.toggle6.place(x=220, y=180)
        self.update_clock()
        mainloop()
    def toggle1(self):
        if self.var1.get() == "ON":
            print('turning on: ' + self.spin1.get())
        else:
    def toggle2(self):
        if self.var2.get() == "ON":
            print('turning on: ' + self.spin2.get())
        else:
    def toggle3(self):
        if self.var3.get() == "ON":
            print('turning on: ' + self.spin3.get())
        else:
    def toggle4(self):
        if self.var4.get() == "ON":
            print('turning on: ' + self.spin4.get())
        else:
    def toggle5(self):
        if self.var5.get() == "ON":
            print('turning on: ' + self.spin5.get())
        else:
    def toggle6(self):
        if self.var6.get() == "ON":
            print('turning on: ' + self.spin6.get())
        else:
app = App()
Return to “Python”
