david_1234
Get pi CPU temp and load
Sun Aug 04, 2019 9:52 am
Hello ,
I'm trying to get the cpu information
I couldn't find the cpu load
the cpu temp I'm getting using :
f = open("/sys/class/thermal/thermal_zone0/temp", "r")
    t = f.readline ()
    CPU_Temp_Int = int(t)
    CPU_Temp = (CPU_Temp_Int / 1000)
but where is the cpu load?
Thanks ,
Re: Get pi CPU temp and load
Sun Aug 04, 2019 10:01 am
    t = float(f.readline ())
    t = t / 1000
This is a doctor free zone.
gordon77
Sun Aug 04, 2019 10:03 am
#!/usr/bin/python3
import sys
import Adafruit_DHT
import io
while True:
    humidity, temperature = Adafruit_DHT.read_retry(11, 4)
    t = int(f.readline ())/1000
    print 'Outside Temp: {0:0.1f} C  Humidity: {1:0.1f} '.format(temperature, humidity)
    print ('CPU Temp is - ' + str(t))
david_1234
Sun Aug 04, 2019 10:04 am
Thanks,
and about the cpu load?
rpdom
Sun Aug 04, 2019 10:06 am
The CPU/GPU temp of "47236" means 47.236°C
(I see you edited your post while I was typing this)
CPU load is a bit harder to work out. The "top" command will show you an overview. You can toggle between overall usage and per-cpu usage by pressing "1". Press "q" to quit".
The load average figures are possibly more interesting. If the figure goes above 1 x CPU cores (so 1 for Pi 1 or Pi 0, 4 for any other Pi) the Pi is a bit overloaded. This figure can be found in /proc/loadavg.
Just for reference, I've managed servers where the load average has gone over 30 - they struggled a lot with that load! On some of them it was just that the server was not up to handling the load. On others it was bad software. I had to identify which of the two it was and make recommendations or kill things to get stuff up and running again.
david_1234
Sun Aug 04, 2019 10:12 am
this is what I wanr\need to do
run my code and see how the PI handle with it...
for now just for report(save the data into a file ).
Thanks ,
gordon77
Sun Aug 04, 2019 10:21 am
You could just run uptime from python and store the resultant line, or the load average figures
david_1234
Sun Aug 04, 2019 10:27 am
but it will just give me the usage of the python , no?
I want to see of the all system
or I didn't understand you?
Thanks .
david_1234
Sun Aug 04, 2019 10:34 am
I found this command
# Return % of CPU used by user as a character string
def getCPUuse():
    return(str(os.popen("top -n1 | awk '/Cpu\(s\):/ {print $2}'").readline().strip()))
but the resualt is in the range of 2.8 - 3.5
when I look at hte icon of the cpu from the gui I can see it changing from 30-60%
how do I get this ?
maybe something from this part?
cat /proc/stat
cpu  59661 19 10181 1693018 2582 0 658 0 0 0
cpu0 16032 4 2754 417182 709 0 589 0 0 0
cpu1 14537 2 2708 424932 592 0 33 0 0 0
cpu2 15427 7 2479 424454 589 0 12 0 0 0
cpu3 13665 6 2240 426448 690 0 24 0 0 0
intr 1372397 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2888 115 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 281 0 0 0 341 13316 0 0 0 0 0 0 0 0 0 0 518533 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3786 6983 0 0 0 0 3450 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 388040 0 0 0 1 0 3
ctxt 1745002
btime 1564911386
processes 1956
procs_running 2
procs_blocked 0
softirq 963864 103224 234155 5752 51293 0 0 176583 209456 243 183158
Thanks,
gordon77
Sun Aug 04, 2019 10:39 am
Thanks .
It will give you the same average figure as top AFAIK, which is overall.
Paul Hutch
Tue Aug 06, 2019 12:18 pm
I've had good luck using the psutil library for getting CPU load.
https://pypi.org/project/psutil/
david_1234
Tue Aug 13, 2019 12:07 pm
I will take a look at this
PeterO
Tue Aug 13, 2019 12:18 pm
glibtop provides an easy API to get cpu loads etc. calling glibtop_get_cpu (glibtop_cpu *buf) gets you one of these :
struct glibtop_cpu {
	guint64 flags;
	guint64 total;				/* GLIBTOP_CPU_TOTAL		*/
	guint64 user;				/* GLIBTOP_CPU_USER		*/
	guint64 nice;				/* GLIBTOP_CPU_NICE		*/
	guint64 sys;				/* GLIBTOP_CPU_SYS		*/
	guint64 idle;				/* GLIBTOP_CPU_IDLE		*/
	guint64 iowait;				/* GLIBTOP_CPU_IOWAIT		*/
	guint64 irq;				/* GLIBTOP_CPU_IRQ		*/
	guint64 softirq;			/* GLIBTOP_CPU_SOFTIRQ		*/
	guint64 frequency;			/* GLIBTOP_CPU_FREQUENCY */
	guint64 xcpu_total [GLIBTOP_NCPU]; /* GLIBTOP_XCPU_TOTAL		*/
	guint64 xcpu_user [GLIBTOP_NCPU]; /* GLIBTOP_XCPU_USER		*/
	guint64 xcpu_nice [GLIBTOP_NCPU]; /* GLIBTOP_XCPU_NICE		*/
	guint64 xcpu_sys  [GLIBTOP_NCPU]; /* GLIBTOP_XCPU_SYS		*/
	guint64 xcpu_idle [GLIBTOP_NCPU]; /* GLIBTOP_XCPU_IDLE		*/
	guint64 xcpu_iowait [GLIBTOP_NCPU]; /* GLIBTOP_XCPU_IOWAIT		*/
	guint64 xcpu_irq [GLIBTOP_NCPU]; /* GLIBTOP_XCPU_IRQ		*/
	guint64 xcpu_softirq  [GLIBTOP_NCPU]; /* GLIBTOP_XCPU_SOFTIRQ		*/
	guint64 xcpu_flags;	                /* GLIBTOP_XCPU_IDLE		*/
I use it to drive this "Load meter" :
I'm looking at how to use this in python... stay tuned....
Hmmmmmm ..... It doesn't seem to be supported by gintrospection so looks like it's not useable in python3 :cry:
PeterO
Return to “Python”
