drifterf
Running Python Scripts From A Html
Fri Aug 02, 2019 4:13 pm
Hi everyone, suppose its a simple enough question, i hope the answer is just as simple lol.
so i have a few python scripts on the pi which do differnt things.
i want to create a webpage local on the pi (with apache i suppose) that when a simple link is clicked it launchs and runs the script as if you had typed it in terminal.
any help with this ?
thanks
ghp
Re: Running Python Scripts From A Html
Fri Aug 02, 2019 5:18 pm
Look for a python based 'web server' like tornado (my favorite), flask, django. Then your web requests are directly handled inside a python environment.
If you want the html page to be public, then security issues might need a more complicated architecture.
gkreidl
Fri Aug 02, 2019 5:56 pm
Kweb (Minimal Kiosk Browser) can do this without any supporting server (only from local HTML files)
But a Buster version is not available, yet.
Minimal Kiosk Browser (kweb)
drifterf
Fri Aug 02, 2019 6:09 pm
so with the above i can create a html with a link to the .py and it will launch it ?
ghp
Fri Aug 02, 2019 6:24 pm
Tornado basic example is here. a form, a link. Run the code, use browser and localhost:8888 should bring up the sample page.
import tornado.ioloop
import tornado.web
class MainHandler(tornado.web.RequestHandler):
    def get(self):
        self.write('<a href="%s">link to story 1</a>' %
                   self.reverse_url("story", "1"))
class MySampleHandler(tornado.web.RequestHandler):
    def get(self):
        self.set_header("Content-Type", "text/plain")
        self.write("You pressed sample link")
class MyFormHandler(tornado.web.RequestHandler):
    def get(self):
        self.write("""<html>
                           <body>
                              <form action="/myform" method="POST">
                                   <input type="text" name="message">
                                   <input type="submit" value="Submit">
                              </form>
                           </body>
                           <a href="/sample">a sample link</a>
                       </html>""")
    def post(self):
        self.write("You wrote " + self.get_body_argument("message"))
def make_app():
    return tornado.web.Application([
        ( r"/", MyFormHandler),
        ( r"/myform", MyFormHandler),
        ( r"/sample", MySampleHandler),
if __name__ == "__main__":
    app = make_app()
    app.listen(8888)
    tornado.ioloop.IOLoop.current().start()
neilgl
Fri Aug 02, 2019 6:58 pm
Yes you can use apache2 no problem.
gkreidl
Fri Aug 02, 2019 8:46 pm
Yes. A link, a button, an Image (icon) or a web form with selectable arguments.
My desktop is a local web page running in kweb which gives access to all my important applications.
Another example is a kweb interface to mumudvb to start and watch TV channels:
drifterf
Sat Aug 03, 2019 10:09 am
i get the following error, i have used pip install tornado
sudo python tornado1.py
File "tornado1.py", line 1, in <module>
File "/home/pi/tornado.py", line 1, in <module>
ImportError: No module named ioloop
ghp
Sat Aug 03, 2019 10:22 am
unfortunately there is the python2-python3 confusion.
For python3, install and run with
# recommended, as Tornado 6.0 requires Python 3.5.2
sudo pip3 install tornado
python3 tornado1.py
drifterf
Sat Aug 03, 2019 10:41 am
python3 tornado1.py
should of known that lol, much appreciated !!
how would i link the "a sample link" button to launch a .py script then ?
i would like seperate links for seperate py scripts
button 1 = /scripts/test.py
button 2 = /differntscripts/this.py
etc ?
thanks
ghp
Sat Aug 03, 2019 11:03 am
Hello, in the Handler for the link, add
import subprocess
Good if the python script executes fast.
subprocess.run("python3 test1.py", shell=True)
For long running scripts, you should spawn the process.
pid = subprocess.Popen(["python3", "test1.py"]).pid
print(pid) # pid allows to terminate the process later.
drifterf
Sat Aug 03, 2019 11:14 am
thank you for your help again, something like i done below ?
i changed this part
def post(self):
import subprocess
import tornado.web
    def get(self):
    def get(self):
    def get(self):
                           <body>
                              </form>
                           </body>
                       </html>""")
    def post(self):
        import subprocess
def make_app():
    app = make_app()
    app.listen(8888)
ghp
Sat Aug 03, 2019 4:03 pm
Hello, this handler MyFormHandler with its post method is dedicated to the form in the html.
Think you spotted the url mapping to the handlers in the code
The method names correspond to the GET, POST, ... request names in the html-requests.
drifterf
Sat Aug 03, 2019 4:13 pm
thank you once again for helping but im new to this and still confused. could you show me a modified code that would launch a .py on clicking the link. hopefully then i can see what to change and why, thank you again
ghp
Sat Aug 03, 2019 4:55 pm
The link in the html page <a href="/sample">a sample link</a> is using url "/sample".
The url resolution table in the code
links /sample to MySampleHandler.
You know about http-requests: a link is a using a GET-request.
So using the link in the page forwards the request into the get-method of the MySampleHandler.
Conclusion: put this code subprocess.run("python3 test1.py", shell=True) into the MySampleHandler, get-method.
drifterf
Sat Aug 03, 2019 5:19 pm
once again im sorry, i currently now get this when i click the web button with the code i have attached.
pi@raspberrypi:~ $ sudo python html.py
WARNING:tornado.access:404 GET /favicon.ico (::1) 1.80ms
ERROR:tornado.application:Uncaught exception GET /sample (::1)
HTTPServerRequest(protocol='http', host='localhost:8888', method='GET', uri='/sample', version='HTTP/1.1', remote_ip='::1')
File "/usr/local/lib/python2.7/dist-packages/tornado/web.py", line 1590, in _execute
result = method(*self.path_args, **self.path_kwargs)
File "html.py", line 13, in get
NameError: global name 'subprocess' is not defined
ERROR:tornado.access:500 GET /sample (::1) 13.06ms
this is my python script
import tornado.web
    def get(self):
    def get(self):
    def get(self):
                           <body>
                              </form>
                           </body>
                       </html>""")
    def post(self):
def make_app():
    app = make_app()
    app.listen(8888)
drifterf
Sat Aug 03, 2019 5:51 pm
ok so i forgot to add import subprocess lol
but now i get this
WARNING:tornado.access:404 GET /favicon.ico (::1) 2.13ms
  File "html.py", line 14, in get
    subprocess.run("python test1.py", shell=True)
AttributeError: 'module' object has no attribute 'run'
ERROR:tornado.access:500 GET /sample (::1) 25.87ms
drifterf
Sun Aug 04, 2019 6:24 am
ok,, i have been messing around and not can get a gpio to trigger from a web button so i will continue to mess around
i would like to thank everyone for the help !
drifterf
Sun Aug 04, 2019 7:53 am
Hi everyone, sorry to bring my head back up after all your help lol
i am getting into the tornado stuff now and starting to understand it a bit more.
how would it be possible to open a .html file i have already created when the "Release Door" link is pressed?
the current code is below
import tornado.web
import subprocess
    def get(self):
class MyOpenDoorHandler(tornado.web.RequestHandler):
    def get(self):
        self.write("""Released The Door""")
        pid = subprocess.Popen(["python", "opendoor.py"]).pid
        print(pid)
    def get(self):
                           <body>
                           </body>
                           <a href="/opendoor">Release Door</a>
                      </html>""")
    def post(self):
        self.write("Door Released" + self.get_body_argument("message"))
        print(pid)
def make_app():
        ( r"/opendoor", MyOpenDoorHandler),
    app = make_app()
    app.listen(8787)
ghp
Sun Aug 04, 2019 8:30 am
Static files can be handled with (drum fill) StaticFileHandler.
        ( r"/", MyFormHandler           ),
        ( r"/myform", MyFormHandler       ),
        ( r"/sample", MySampleHandler         ),
        ( r"/success/?(.*)", tornado.web.StaticFileHandler, {"path": "html/success/" , "default_filename": "success.html"} ),
Place success.html in path ./html/success/.
With URL localhost:8888/success this file should be delivered. Or with localhost:8888/success/success.html.
Then in the request handler of your link, place a redirect as last statement.
    def get(self):
        print("MySampleHandler")
        ... some other actions ...
        self.redirect("/success")
The regular expression "/success/?(.*)", matches "/success", "/success/", for both the default_filename applies. Or with "/success/success.html", the group (.*) applies and provides a file name for StaticFileHandler. See the StaticFileHndler docs for the details.
drifterf
Sun Aug 04, 2019 8:45 am
thank you, i now get this error for some reason. have i done something wrong ?
File "server.py", line 19
pid = subprocess.Popen["python", "opendoor2.py"]).pid
SyntaxError: invalid syntax
import tornado.web
import subprocess
    def get(self):
    def get(self):
        self.write("""Released The Door - Relay 1""")
        print(pid)
class MyOpenDoor2Handler(tornado.web.RequestHandler):
    def get(self):
        print("Relay 2 Script")
        print(pid)
    def get(self):
                           <body>
                           </body>
                           <br>
                           <a href="/opendoor2">Release Door - Relay 2</a>
                      </html>""")
    def post(self):
        print(pid)
def make_app():
        ( r"/opendoor2/?(.*)", tornado.web.StaticFileHandler, {"path": "html/success/" , "default_filename": "success.html"} ),
ghp
Sun Aug 04, 2019 11:29 am
Brackets come in pairs.
drifterf
Sun Aug 04, 2019 12:43 pm
thank you, im such a dumbass (should of put me contact lenses in lol)
this works great now except it dosent launch my .py script in the handler ?
it redirects to the page i require but dosent actually launch the .py script (opendoor2.py)
import tornado.web
import subprocess
    def get(self):
    def get(self):
        print(pid)
    def get(self):
        self.write("""Released The Door - Relay 2""")
        pid = subprocess.Popen(["python", "opendoor2.py"]).pid
        print(pid)
        self.redirect("/opendoor2")
    def get(self):
                           <body>
                           </body>
                           <br>
                      </html>""")
    def post(self):
        print(pid)
def make_app():
        ( r"/opendoor2/?(.*)", tornado.web.StaticFileHandler, {"path": "/home/pi/ACU/html/" , "default_filename": "index.html"} ),
        ( r"/opendoor2", MyOpenDoor2Handler),
    app = make_app()
    app.listen(8787)
drifterf
Sun Aug 04, 2019 3:16 pm
no one help with this ? so close but stuck at moment, been trying all day for something im sure is simple :(
ghp
Mon Aug 05, 2019 4:35 am
- the last line of code is missing tornado.ioloop.IOLoop.current().start()
- html code usually has links inside <body>... here goes the page ...</body>. Your page works unexpectedly.
- in the Popen, add ", shell=True". Or try using /usr/bin/python which is more precise.
- the url mappings contain r"/opendoor2/?(.*)" AND r"/opendoor2". So MyOpenDoor2Handler will not be called. Better tu use different names for the url.
When in doubt how to use the subprocess.Popen, then write a short script with these statements only and run this on its own.
Return to “Python”
