dionryl1995
Pass and Fail counter with GPIO and tkinter
Fri Aug 02, 2019 3:40 pm
I need help.
I'm creating a code to build a counter for "PASSED AND FAILED counter" with GPIO and display the counter value using tkinter.
Here's the condition:
1. Pressing "Start Test" button it will ready for counting.
2. I need a condition that two GPIO input detect it will count specific counter:
a. GPIO.setup(11,GPIO.IN) and GPIO.setup(13,GPIO.IN) detects it will count the "CountPass".
b. GPIO.setup(11,GPIO.IN) and GPIO.setup(15,GPIO.IN) detects it will count the "CountFail".
3. by Pressing the button "End Test" reset all the counter.
Thank you,
Tkinter Display
I tried this code:
from tkinter import*
import RPi.GPIO as GPIO
import time
def Start_counter():
    global CountPass
    global CountFail
    GPIO.add_event_detect(13,11, GPIO.RISING, callback = buttonPressed)
    GPIO.add_event_detect(15,11, GPIO.RISING, callback = buttonFailed)
def buttonPressed():
    CountPass.set(CountPass.get() + 1)
def buttonFailed():
    CountFail.set(CountFail.get() + 1)
def End_counter():
    CountPass.set(0)
    CountFail.set(0)
root = Tk()
GPIO.setmode(GPIO.BOARD)
#========GPIO pin configuration===================
GPIO.setup(11,GPIO.IN) #EOT (Start Of Test) GPIO pin
GPIO.setup(13,GPIO.IN) #PASS  GPIO pin
GPIO.setup(15,GPIO.IN) #Fail GPIO pin
CountPass = IntVar()
CountPass.set(0)
CountFail = IntVar()
CountFail.set(0)
Button(root, text = "Start Test", command = Start_counter).grid(row = 0, column = 0)
Button(root, text = "End Test", command = End_counter).grid(row = 0, column = 1)
Label(root, text = "Passed counter:").grid(row = 1, column = 0,sticky = E,padx = 20, pady = 10)
Label(root, text = "Failed counter:").grid(row = 2, column = 0,sticky = E,padx = 20, pady = 10)
Label(root, textvariable = CountPass, bg = 'white', width = 10).grid(row = 1, column = 1,sticky = W,padx = 20, pady = 10)
Label(root, textvariable = CountFail,bg = 'white', width = 10).grid(row = 2, column = 1,sticky = W,padx = 20, pady = 10)
mainloop()
ghp
Re: Pass and Fail counter with GPIO and tkinter
Fri Aug 02, 2019 7:26 pm
Hmm, and where is the problem ?
gordon77
Sat Aug 03, 2019 11:34 am
Try this..
You have to click START button and then GPIO11 has to be pressed to count inputs on 13 and 15.
import time
ECT = 11
PASS = 13
FAIL = 15
    global CountPass
    global CountFail
    GPIO.add_event_detect(PASS, GPIO.RISING, callback = buttonPressed)
    GPIO.add_event_detect(FAIL, GPIO.RISING, callback = buttonFailed)
def buttonPressed(X):
    if GPIO.input(ECT) == 1:
def buttonFailed(X):
def End_counter():
    CountPass.set(0)
    CountFail.set(0)
root = Tk()
GPIO.setwarnings(False)
GPIO.setup(ECT,GPIO.IN,pull_up_down = GPIO.PUD_DOWN)  #ECT (Enable CounT) GPIO pin
GPIO.setup(PASS,GPIO.IN,pull_up_down = GPIO.PUD_DOWN) #PASS  GPIO pin
GPIO.setup(FAIL,GPIO.IN,pull_up_down = GPIO.PUD_DOWN) #Fail GPIO pin
CountPass.set(0)
CountFail.set(0)
mainloop()
dionryl1995
Sat Aug 03, 2019 1:11 pm
Thank u sir. I will try it and I ask again if not functioning
Return to “Python”
