drifterf
write python output to a excel field
Mon Jul 15, 2019 6:05 pm
hi, i currently have a script that when a proximity fob is presented to the reader it displays the fob number (PIGPIO wiegand script)
i would like to make a python script so when i run it and then present the access fob it automatically puts the output into the next un-used column of the csv file.
can anyone help please
drifterf
Re: write python output to a excel field
Mon Jul 15, 2019 6:07 pm
current script that accepts codes alredy programmed in the csv or denies if they are not
#!/usr/bin/env python
import pigpio, csv
FILE_TO_READ = '/home/pi/furniss_acu/database/database.csv'
CSV_ID_KEY = 'Number :'
class decoder:
   A class to read Wiegand codes of an arbitrary length.
   The code length and value are returned.
   EXAMPLE
   import time
   import pigpio
   import wiegand
   def callback(bits, code):
      print("bits={} code={}".format(bits, code))
   pi = pigpio.pi()
   w = wiegand.decoder(pi, 14, 15, callback)
   while True:
      time.sleep(60)
   w.cancel()
   pi.stop()
   def __init__(self, pi, gpio_0, gpio_1, callback, bit_timeout=5):
      Instantiate with the pi, gpio for 0 (green wire), the gpio for 1
      (white wire), the callback function, and the bit timeout in
      milliseconds which indicates the end of a code.
      The callback is passed the code length in bits and the value.
      self.pi = pi
      self.gpio_0 = gpio_0
      self.gpio_1 = gpio_1
      self.callback = callback
      self.bit_timeout = bit_timeout
      self.in_code = False
      self.pi.set_mode(gpio_0, pigpio.INPUT)
      self.pi.set_mode(gpio_1, pigpio.INPUT)
      self.pi.set_pull_up_down(gpio_0, pigpio.PUD_UP)
      self.pi.set_pull_up_down(gpio_1, pigpio.PUD_UP)
      self.cb_0 = self.pi.callback(gpio_0, pigpio.FALLING_EDGE, self._cb)
      self.cb_1 = self.pi.callback(gpio_1, pigpio.FALLING_EDGE, self._cb)
   def _cb(self, gpio, level, tick):
      Accumulate bits until both gpios 0 and 1 timeout.
      if level < pigpio.TIMEOUT:
         if self.in_code == False:
            self.bits = 1
            self.num = 0
            self.in_code = True
            self.code_timeout = 0
            self.pi.set_watchdog(self.gpio_0, self.bit_timeout)
            self.pi.set_watchdog(self.gpio_1, self.bit_timeout)
         else:
            self.bits += 1
            self.num = self.num << 1
         if gpio == self.gpio_0:
            self.code_timeout = self.code_timeout & 2 # clear gpio 0 timeout
         else:
            self.code_timeout = self.code_timeout & 1 # clear gpio 1 timeout
            self.num = self.num | 1
      else:
         if self.in_code:
               self.code_timeout = self.code_timeout | 1 # timeout gpio 0
            else:
               self.code_timeout = self.code_timeout | 2 # timeout gpio 1
            if self.code_timeout == 3: # both gpios timed out
               self.pi.set_watchdog(self.gpio_0, 0)
               self.pi.set_watchdog(self.gpio_1, 0)
               self.callback(self.bits, self.num)
   def cancel(self):
      Cancel the Wiegand decoder.
      self.cb_0.cancel()
      self.cb_1.cancel()
def readFile(filename):
   data = []
   with open(filename, 'r') as file:
      reader = csv.DictReader(file)
      data = [row for row in reader]
   return data
def authenticateFromFile(id):
   for row in readFile(FILE_TO_READ):
      if CSV_ID_KEY in row and row[CSV_ID_KEY] == id:
         return True
   return False
if __name__ == "__main__":
   import time
   import RPi.GPIO as GPIO
   import pigpio
   import wiegand
   GPIO.setmode(GPIO.BCM)
   GPIO.setwarnings(False)
   def callback(bits, value):
      if authenticateFromFile('{}'.format(value)):
         print("Wiegand bits={} Card Number={}".format(bits, value))
         file = open("/home/pi/ACU/www/events.txt", "w")
         file.write("Last Access: Wiegand bits={}\n".format(bits))
         file.write("\nCard value={}".format(value))
         GPIO.setup(18,GPIO.OUT)
         print("door released")
         GPIO.output(18,GPIO.LOW)
         time.sleep(5)
         print("door secure")
         GPIO.output(18, GPIO.HIGH)
      else:
         print("Access Denied = Wiegand bits={} Card Number={}".format(bits, value))
         file.write("Access Denied = Wiegand bits={} Card Number={}".format(bits, value))
   pi = pigpio.pi()
   while True:
      time.sleep(60)
   w.cancel()
   pi.stop()
ghp
Mon Jul 15, 2019 7:51 pm
drifterf
Tue Jul 16, 2019 5:26 am
thank you i will have a read
Return to “Python”
