Subprocessing? Calling and terminating a python script from another python script
Posted: Sat Jul 13, 2019 5:16 pm
by beemurt
Good Afternoon
Hopefully someone can help me. I am new-ish to python/programming.
I have a script which controls when another script gets called for an alarm system.
Basically i want to call tryingToSpawn.py if two vars in a database are set. If two different vars are set I want to kill/terminate tryingToSpawn.py. But I am having problems getting it to work.
The first subprocess is to establish if a phone is present on the LAN. This works perfectly! It is the second subprocess seems to work too. Its just when I try to stop it, it fails. The code and error is below
This is the code:
import subprocess
from subprocess import Popen, PIPE
import signal
import sys
import os
try:
# while loop checks status before the if statements are checked
    while True:
        # pull data from DB - SQL
        for row in records:
           #list of vars
# determine the location of the a mobile
            result = subprocess.check_output("sudo nmap -sn 192.168.0.0-50", shell = True)
            if (mac in result):
                deviceLocation = 1
            elif (mac not in result):
                deviceLocation = 2
            # if statements control the actions of the script
            if (routineStatus == 1) and (deviceTriggerLocation == deviceLocation):
                if componentsid == 5 and routineAction == 1:
                   proc1 = subprocess.Popen( "exec" 'python tryingToSpawn.py', shell=True)
                if componentsid == 5 and routineAction == 2:
                    os.kill(proc1.pid, signal.SIGINT)
            if routineStatus == 0:
                mySQLconnection.close()
                sys.exit()
# encase DB fails - trace error
except Error as e:
    print("Error while connecting to oh_Database-:", e)
# closing resources
finally:
    if(mySQLconnection.is_connected()):
I am just trying to run this from terminal. This is the error i get:
File "routineDevice.py", line 156, in <module>
NameError: name 'proc1' is not defined
I think I do understand that for some reason 'proc1' is out of scope as a var, inside the other if statements. Can anyone help, suggest a different way of doing this? I just need to have the parent script launch a child python script (the child needs to run in the background without hanging up the parent script) and then the parent needs to be able to stop the child using a few if statements.
Is this possible?
Many Thanks
B
Re: Subprocessing? Calling and terminating a python script from another python script
Posted: Sat Jul 13, 2019 5:47 pm
by MrYsLab
It is a little difficult to understand what the coding is actually doing, but I modified it so that proc1 is initialized to None at the top of the loop and to throw an exception if proc1 is None when a kill is called. This should at least point out where the issue is and you can correct from there:
import subprocess
import signal
import sys
import os
try:
    while True:
        # initialize proc1 to None
        proc1 = None
        for row in records:
            # list of vars
            result = subprocess.check_output("sudo nmap -sn 192.168.0.0-50", shell=True)
            if mac in result:
                deviceLocation = 1
            elif mac not in result:
                deviceLocation = 2
                    proc1 = subprocess.Popen("exec" 'python tryingToSpawn.py', shell=True)
                    if proc1:
                    else:
                        raise RuntimeError('Proc 1 is None: 1')
                if proc1:
                else:
                    raise RuntimeError('Proc 1 is None: 2')
                sys.exit()
except Error as e:
# closing resources
finally:
    if mySQLconnection.is_connected():
Posted: Sat Jul 13, 2019 6:11 pm
by beemurt
Thank you for the reply MrYsLab
I implemented the code you provided and got this response in terminal:
File "routineDevice.py", line 160, in <module>
RuntimeError: Proc 1 is None: 1
The DB is set so that it will hit - if componentsid == 5 and routineAction == 2:
So it appears it is still failing this section below:
                    if proc1:
                    else:
Posted: Sat Jul 13, 2019 6:26 pm
by MrYsLab
Again, I am not really sure what the code is supposed to do, but a possible solution is to replace the raise statements with continue to go to the next iteration of the loop:
                    if proc1:
                    else:
                        continue
                if proc1:
                    sys.exit()
                else:
                    continue
Posted: Sat Jul 13, 2019 6:54 pm
by beemurt
Unfortunately the continue statements just let the code run in a loop, they dont kill the child script.
The code is part of an alarm system. This is the sudo code for what i am trying to do:
Check if a device is on the LAN. If it is enter some if statements:
run the alarm.py script which waits for a PIR event.
Once PIR tripped alarm.py takes image with camera and sends a whatsapp message.
It stays live until the PIR event has been triggered
the alarm is to be disabled, if running (as a child) exit before a PIR event.
I hope that makes sense?
Posted: Sat Jul 13, 2019 8:08 pm
by Paeryn
In your original code, when you were getting the NameError: proc1 not defined, that was happening because at the point in time when the os.kill was trying to be executed, the preceding event which spawns it (and creates the proc1 variable) obviously hasn't happened, otherwise proc1 would have had a value.
You look to have an error when trying to spawn the subprocess
The string you are passing is the concatenation of the two strings, i.e. effectively
proc1 = subprocess.Popen('execpython tryingToSpawn.py', shell=True)
and I doubt there is a program called execpython, so the Popen() will not do anything.
Also, rather than using os.kill() to send a signal you should just send it with
proc1.send_signal(SIGINT)
And you should ideally call
proc1.wait()
afterwards to get the subprocess' return code and let the Kernel know that you have finished with it (although IIRC Python will put a Popen object into a private list when it goes out of scope and will automatically wait() on any in that list which have teminated if you don't do it yourself).
Posted: Sat Jul 13, 2019 8:43 pm
by beemurt
Evening Paeryn
Your correct, the subrprocess was wrong it should read:
process = subprocess.Popen('python alarmTest.py', shell=True)
And I think you are right my code inst logically correct either. I will take a look and see if i can fix it up
Thank you
