FreakShow!
Remove Python2?
Fri Jul 12, 2019 9:33 pm
I'm getting back to learning Python and am chipping my way along. One issue I keep hitting is running Python v2.7.16 instead of Python v3.7.3. It's an easy mistake to make, but is there a way I can make Python 3 and Pip 3 the default when typing python/pip?
Andyroo
Re: Remove Python2?
Fri Jul 12, 2019 9:44 pm
Not wise as lots of bits use Python 2 - in fact there have been posts here saying do not do it.
The safest way may be to make it local to you by putting a line into ~/.bashrc
alias python='/usr/bin/pythonx.x.x
where x.x.x is the executable name you want to use
Once done, log in again to activate the alias.
FreakShow!
Re: Remove Python2?
Fri Jul 12, 2019 11:54 pm
Ah, I guess I should have realised that. I assume the alias is just for when I call it in terminal, but won't affect anything else calling python to do whatever it needs?
Andyroo
Re: Remove Python2?
Sat Jul 13, 2019 12:55 am
Basically yes.
Thonny (the GUI editor) is set to Python 3 now.
You can also add a shebang as the first line, chmod the file to be executable and not use the python command as an option :lol:
Have a read of https://www.raspberrypi.org/forums/view ... 2&t=241830 for a bit more background.
FreakShow!
Re: Remove Python2?
Sat Jul 13, 2019 12:09 pm
Thanks for your help :)
Return to “Python”
