Henkel
label with textvariable doesn't refresh (tkinter)
Fri Jul 05, 2019 11:33 am
Hi guys and girls,
I got an Arduino Uno connected to a Raspberry Pi 3 B+.
The Arduino is writing all the time a random number in form of "0.00".
I wonna read that number on my Raspberry to print it on a label.
The code bellow is working so far but it doesn't refresh it's text.
I am very new to Python, Raspberry and Arduino so I am sorry for basic mistakes.
import serial
import time
from tkinter import *
HEIGHT = 500
WIDTH = 600
root = Tk()
s = serial.Serial('/dev/ttyUSB0', 9600) # Namen ggf. anpassen
s.isOpen()
time.sleep(5) # der Arduino resettet nach einer Seriellen Verbindung, daher muss kurz gewartet werden
def Main():
    var = StringVar()
    battery_frame = Frame(root, bg = '#80c1ff', bd = 5)
    battery_frame.place(relwidth= 1, relheight=1)
    getValue(var)
    battery_voltage= Label(battery_frame, textvariable = var)
    battery_voltage.place(relwidth=1, relheight=1)
    root.mainloop()
def getValue(var):
    InputValue = s.readline()
    var.set(InputValue)
    return var
Main()
I hope u can help me, a big thanks for ur effort. :D
MrYsLab
Re: label with textvariable doesn't refresh (tkinter)
Fri Jul 05, 2019 1:06 pm
I modified your code to just run the tkinter elements and it seems to work without issue.
If you print out the value of InputValue in your getValue function after the readline, what do you get?
Henkel
Fri Jul 05, 2019 1:23 pm
Hi MrYsLab,
thanks for ur answer.
When I run my programm the first time I get one number.
But the programm isn't refreshing so it stays all the time on the same number.
Henkel
Fri Jul 05, 2019 2:04 pm
I got a solution for my problem.
The Text(box) is now refreshing.
I wrote
root.mainloop()
to the last row of the code. (From row 27)
I added
root.after(1000, Main)
to the last row of def Main():
ghp
Fri Jul 05, 2019 4:54 pm
Hello as always there are alternate solutions.
Let me propose some code using a thread to read values from arduino serial line. In the thread, the StringVar is set and the window is updating.
A slight advantage over the root.after(1000, Main)-solution is that the thread is independent from the update frequency of the arduino, at least if not too fast.
import serial
import time
import threading
use_serial = True # set to False when simulation code is used.
HEIGHT = 500
WIDTH = 600
root = Tk()
if  use_serial:
    s.isOpen()
var = StringVar()
def Main():
    root.mainloop()
i = 0
def getValue():
    while True:
        if use_serial:
            var.set(InputValue)
        else:
            # some simulation of an input
            global i
            InputValue = "{v:6.2f}".format(v=i*3.1415)
            i+= 1
            var.set(InputValue)
            time.sleep(0.2)
readThread = threading.Thread(target=getValue)
readThread.start()
Main()
Return to “Python”
