sudo pip3 install opencv-python fails...
Posted: Mon Jun 24, 2019 2:32 pm
by gordon77
using latest Raspbian...
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting opencv-python
  Could not find a version that satisfies the requirement opencv-python (from versions: )
No matching distribution found for opencv-python
Anyone know /explain why ?
Re: sudo pip3 install opencv-python fails...
Posted: Mon Jun 24, 2019 4:52 pm
by ben_nuttall
opencv don't release soirce distribution to PyPI, so there's nothing to build.
The only reason it's been available recently is that the piwheels project builds it from github and releases it.
We haven't built opencv for Buster yet. You'll have to be patient.
Ref:
https://pypi.org/project/opencv-python/
https://www.piwheels.org/project/opencv-python/
https://blog.piwheels.org/raspberry-pi- ... an-buster/
Posted: Mon Jun 24, 2019 4:57 pm
by gordon77
Thanks for the explanation.
Posted: Tue Jun 25, 2019 9:40 pm
by plugwash
You can also try the version from raspbian.
apt-get install python3-opencv
Posted: Wed Jun 26, 2019 7:03 am
by gordon77
Thanks, modified my install..
sudo apt-get install python3-opencv
sudo apt-get install libhdf5-dev
sudo apt-get install libhdf5-serial-dev
sudo apt-get install libatlas-base-dev
sudo apt-get install libjasper-dev
sudo apt-get install libqtgui4
sudo apt-get install libqt4-test
opencv now works, but gives a few anomalies on the image, lines, which I need to investigate.
but works OK when using pygame to display, opencv to capture (screen.jpg)
Posted: Wed Jun 26, 2019 12:49 pm
by ggNoOpenCV
This command is only for version 3.2.0, is there no way to get a higher version on buster currently? Is there any stable os that supports new versions of opencv?
Posted: Wed Jun 26, 2019 5:10 pm
by gordon77
Jessie and pip3 install opencv-python used to install v 3.4.4
