rpiboy
How to print without newline
Tue Jun 11, 2019 6:05 pm
raise TypeError("""The sentence should be of type str
                                                  and not {}""".format(type(sentence)))
That code prints on two different lines. How do I get it to print on the same line?
TypeError: The sentence should be of type str
                                                  and not <class 'int'>
PhatFil
Re: How to print without newline
Tue Jun 11, 2019 6:48 pm
try
raise TypeError("""The sentence should be of type str and not {}""".format(type(sentence)))
and remove the unwanted white spaces, tabs and cr or lf from between the 2 text elements
rpiboy
Tue Jun 11, 2019 6:51 pm
try
I know I can put it on one line and it'll print without a newline. I am wondering how I can get the code to print on the same line when I have it on two separate lines?
ghp
Tue Jun 11, 2019 7:29 pm
Hello, by using the triple quotes all whitespace and newline is in the string. You can't avoid it.
So either use a different statement, single line is already mentioned, or remove it.
#remove whitespace
import re
raise TypeError( re.sub(r" *[\n] *", " ",
# concat lines
raise TypeError("The sentence should be of type str" +
                " and not {}".format(type(sentence)))
# single line, see comments above.
raise TypeError("The sentence should be of type str and not {}".format(type(sentence)))
Paeryn
Tue Jun 11, 2019 9:52 pm
Or use the fact that two string literals with only whitespace between them are implicitly converted into a single string at compile time rather than at run time (and you can use different quotation marks for each part if you want).
$ cat strings.py
print("This string is entered in two parts on separate lines "
        'but is really one string')
$ python3 strings.py
This string is entered in two parts on separate lines but is really one string
Or, using your original lines :-
raise TypeError("The sentence should be of type str "
                                                  "and not {}".format(type(sentence)))
Aydan
Thu Jun 13, 2019 1:44 pm
Another way is to use a "\" before the linebreak like so:
raise TypeError("The sentence should be of type str \
johnlenon
Sat Jun 15, 2019 2:16 pm
Following is the program referred from crazygeeks for printing without newline:
# Python 3 code for printing without newline
print("Apple"),
print("Pineapple")
# array
a = [1, 2, 3, 4, 5, 6, 7]
# printing a element in same
# line
for i in range(7):
    print(a[i]),
Return to “Python”
