AlexanderAlexander
I'm having trouble with my code turning my relays on and of repeating any suggestions?
Tue Jun 04, 2019 2:55 am
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
# Relay pin numbers
pinList = [2, 3, 4, 17, 27, 22, 10, 9, 11, 5, 6, 13, 19, 26, 21, 20]
#Turn ON relays in the start
for i in pinList:
GPIO.setup(i, GPIO.OUT)
GPIO.output(i, GPIO.LOW)
# Time after which relays will turn OFF i have set it to 5 seconds.
SleepTimeL = 1
try:
while True:
time.sleep(SleepTimeL);
for i in pinList:
GPIO.output(i, GPIO.HIGH)
for i in pinList:
# End program with ctrl+C with keyboard
except KeyboardInterrupt:
print " Quit"
I figured out print and quit and I turn it on with sudo python relay but when they all turn on they wont turn off I want them to fire repeatedly any help
ghp
Re: I'm having trouble with my code turning my relays on and of repeating any suggestions?
Tue Jun 04, 2019 4:06 am
Identation is important in python. Please re-edit your post and add Code-Tag viewtopic.php?f=32&t=84477
Which relay-board are you using and how are the connections between RPi and the board ?
pcmanbob
Tue Jun 04, 2019 6:32 am
Your relay board is probably active low and its control circuit is probably running at 5v , so the problem is caused by the 3.3v gpio .
see this explanation : viewtopic.php?f=91&t=83372&p=1225448#p1225448
if you tell us which relay board you have ( post a link to were you purchased it from or its data sheet ) we can help with an interface circuit to make it work.
some other points
you don't need sudo to run your example code
please use code tags when posting code to preserve the indentation
Add [code] at the top
code goes here
and [/code] at the bottom.
Return to “Python”
