GPIOzero button Migrating from RPi.GPIO
Posted: Tue Mar 12, 2019 7:48 pm
by bw1pi
I have a simple RPi.GPIO that Blinks an output and reads that as an input.
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
# Variable for the BCM GPIO pin number
READ_1 = 2
LED_1 = 16
# Setup the GPIO pins for output
GPIO.setup(READ_1, GPIO.IN)
GPIO.setup(LED_1, GPIO.OUT)
# Loop to blink our LEDs
try:
  while True:
    print("On 1")
    GPIO.output(LED_1, GPIO.HIGH)
    time.sleep(1)
    IN1 = GPIO.input(READ_1)
    print("On 1 reads : ",IN1)
    GPIO.output(LED_1, GPIO.LOW)
    time.sleep(1)
    print("Off 1 reads : ",IN1)
except KeyboardInterrupt: # Ctrl-C to stop
    GPIO.cleanup(LED_1)
    pass
Now I am trying to migrate to GPIOzero.
The LED outputs work fine, but the button value has had issue.
The First gpiozero button issue with error "Failed to add edge detection"
is fixed thanks to : bcroston commented on Nov 3, 2018
Now the code is the issue.
I do not want to wait, just read the current state, so I think the correct usage is:
button.value
Using the button as a switch from GND to pin2 works.
Using the button as a LED output pin sense stay FALSE with the output turning on an LED through a resistor?
I tried pull_up=True/False with no difference?
from gpiozero import LED, Button
from time import sleep
button = Button(2)
LED_1 =	LED(16)
try:
  while True:
    print("On 1")
    LED_1.on()
    sleep(1)
    read1 = button.value
    print("On 1 read ",read1)
    print("Off 1")
    LED_1.off()
    sleep(1)
    print("Off 1 read ",read1)
    LED_1.off()
    print("Clean up done")
    pass
Re: GPIOzero button Migrating from RPi.GPIO
Posted: Fri Mar 15, 2019 12:36 am
by ben_nuttall
You can't pull-down GPIO2 or GPIO3 as there are physical pull-up resistors on those pins.
Try just using the button on its own and see if you can get the right results:
from gpiozero import Button
button = Button(2)
while True:
    if button.is_pressed:
        print("pressed")
    else:
        print("released")
If that works, you're good. If not, try another pin (not 2 or 3) and see if pull_up makes a difference.
You can use:
- button.is_pressed
- button.value
- button.wait_for_press()
- button.wait_for_release()
Also try led.blink() to save yourself from trying to blink in a loop.
Your button doesn't seem to do anything in the script except print when it's pressed. Try:
led = LED(16)
button = Button(2)
while True:
        print("pressed")
        led.on()
    else:
        print("released")
        led.off()
