rpiboy
Need help understanding this code
Sat Feb 16, 2019 11:27 pm
class EvenOnly(list):
    def append(self, integer):
        if not isinstance(integer, int):
            raise TypeError("Only integers can be added")
        if integer % 2:
            raise ValueError("Only even numbers can be added")
        super().append(integer)
e = EvenOnly()
e.append(2)
I'm trying to understand this code and what I don't understand is " if integer % 2:
raise ValueError("Only even numbers can be added")"
If 2 % 2 which 2 is an even number shouldn't it raise an error since it is true?
Idahowalker
Re: Need help understanding this code
Sun Feb 17, 2019 12:24 am
        if integer % 2:
e = EvenOnly()
e.append(2)
Even number as integer modulo 2 = 0.
Odd number as integer modulo 2 = 1
0 = false
1 = true = raise an error
Without knowing why you are deleting my postings, I will not know how...
hippy
Sun Feb 17, 2019 12:43 am
I would have written it as ...
if ( integer % 2 ) != 0:
or more likely ...
if ( integer & 1 ) != 0:
They are all the same, but these two help avoid the sort of confusion it has caused you.
Return to “Python”
