RASelkirk
Using one button to cycle thru 3 scenarios
Thu Jan 24, 2019 5:35 pm
Hi All,
Constant errors with this code no matter what:
global btnclick
btnclick = 0
def do_cycle():
    If btnclick == 0:
        labeloffo.configure(image=picred)
        labeloffo.image=picred
        btnclick = btnclick + 1
    Elif btnclick == 1:
        labeloffc.configure(image=picgrn)
        labeloffc.image=picgrn
    Elif btnclick == 2:
        labeloffo.configure(image=picoff)
        labeloffo.image=picoff
        labeloffc.configure(image=picoff)
        labeloffc.image=picoff
        btnclick = 0
    Else:
I have one button that calls this function to cycle thru 3 graphic scenarios. It should increment by the "btnclick" variable switching 2 "LEDs" between off and on. Keep getting the invalid syntax error mark just after "btnclick" and the first "==". I've Googled the past hour and am not seeing the problem. Should be a straight comparison, if the counter is 0: do this, if it's 1, do this, etc...
Russ
pcmanbob
Re: Using one button to cycle thru 3 scenarios
Thu Jan 24, 2019 6:17 pm
If you want to use a global variable in your function then you have to include the line " global btnclick " as the first line in your function so the following code knows to use the global variable and not a local one just in the function.
OutoftheBOTS
Thu Jan 24, 2019 10:48 pm
to elaborate a little more.
When a function is called it will create/allocate any variables that are used within the function that are not declared global then when the function returns it will destroy/de-allocate all variables that are not global.
So every time you call your function it creates a new variable that is equal to zero. If you declare it as global then it will only create it once and use it each time the function is called :)
RASelkirk
Thu Jan 24, 2019 11:43 pm
OK, I put it inside the loop and I still get the same error. Both "global btnclick" with/without "btnclick = 0". Small "g" and capital "G". Even so, how will this ever increment if it's declared as 0? Please show a working example so my ancient (65 year old) mind can comprehend this mess...
Russ
PS- I really don't care about the scope of the variable, I just want it increment!
OutoftheBOTS
Fri Jan 25, 2019 8:34 am
global btnclick
btnclick = 0
def do_cycle():
	global btnclick
    if btnclick == 0:
    elif btnclick == 1:
    elif btnclick == 2:
        btnclick = 0
pcmanbob
Fri Jan 25, 2019 12:20 pm
Russ
well it works for me, so using you code as a base this little test program runs you function as if a button was being pressed.
import time
loop = 0
btnclick = 0
def do_cycle():
    global btnclick
    if btnclick == 0:
        print ("first if statment" , btnclick)
    elif btnclick == 1:
        print ("second if statment" , btnclick)
    elif btnclick == 2:
        print ("third if statment" , btnclick)
        btnclick = 0
        print ("end of if statments ", btnclick)
while loop < 7:
    print (" this is were you push your button")
    do_cycle()
    time.sleep(3)
    loop = loop + 1
after looping through the function twice it stops.
this is the result
pi@StretchTest:~ $ python3 gloop.py
first if statment 0
second if statment 1
third if statment 2
end of if statments  0
first if statment 0
third if statment 2
first if statment 0
pi@StretchTest:~ $
RASelkirk
Fri Jan 25, 2019 5:59 pm
Geeze Louise! :shock: After another hr of wasting time, it turned out to be a simple issue of improper case on the if/elif statements. :oops:
Sorry for the bother, all good now!
Russ
Return to “Python”
